White Tractor 1450 Parts Catalog 43307400
Brand: White
Model: White 1450 Tractor
Part Number: 43307400
Number of Pages: 181 Pages
Group A - Front Main Frame
Group A - Decals And Name Plate
Group B - Engine And Supports (S N 132382 -)
Group B - Crankcase And Cylinder Head
Group B - Crankshaft And Flywheel (S N 132382 -)
Group B - Connecting Rods And Pistons (S N 132382 -)
Group B - Oil Pan And Crankcase Covers
Group B - Cam Shaft, Rocker Arms And Valves (S N 132382 -)
Group B - Camshaft Drive (S N 132382 -)
Group B - Oil Pump, Filter And Gauges (S N 132382 -)
Group B - Exhaust Manifold And Muffler (S N 132382 -)
Group B - Air Cleaner And Intake Manifold (S N 132382 -)
Group B - Fuel Tank
Group B - Fuel Injection System (S N 132382 -)
Group B - Injection Pump Drive (S N 132382 -)
Group B - Accelerator Control Linkage (S N 132382 -)
Group B - Battery Holder (S N 132382 -)
Group B - Engine Starting Equipment (S N 132382 -)
Group B - Current Generating System
Group B - Lighting System
Group B - Lighting System (S N 132382 -)
Group B - Horn (S N 132382 -)
Group B - Fan And Belt (S N 132382 -)
Group B - Radiator
Group B - Water Pump And Connections (S N 132382 -)
Group B - Coolant Heater (S N 132382 -)
Group C - Rear Main Frame And Clutch Housing
Group C - Transmission
Group C - Amplicouple
Group C - Gear Shift - Outer (S N 132382 -)
Group C - Gear Shift - Inner (S N 132382 -)
Group C - Reduction Unit Controls (S N 132382 -)
Group C - Propeller Shaft
Group C - Brakes
Group C - Hand Brake Controls (S N 132382 -)
Group C - Differential
Group C - Differential Lock (S N 132382 -)
Group C - Transfer Drive Engagement Controls
Group C - Transfer Drive Case And Covers - Four Wheel Drive
Group C - Transfer Drive Gears - Four Wheel Drive
Group C - Transfer Drive Shaft - Four Wheel Drive
Group D - Belt Pulley (S N 132382 -)
Group E - Power Take-Off And Pulley Controls -
Group F - Hydraulic Lift (S N 132382 -)
Group F - Hydraulic Lift Additional Tank (S N 132382 -)
Group F - Hydraulic Lift Additional Power Outlet Unit
Group F - Rear Wheels And Weights (S N 132382 -)
Group L - Front Wheels (S N 132382 -)
Group L - Front Wheels - Four Wheel Drive (S N 132382 -)
Group P - Drawbar
Group P - Tow Hook (S N 132382 -)
Group P - Three-Point Hitch
Group Q - Clutch Release System - Two Wheel Drive
Group Q - Clutch Release System - Four Wheel Drive
Group R - Rear Axle Carrier (S N 132382 -)
Group R - Rear Axle (S N 132382 -)
Group R - Final Drive Gears
Group S - Wheel Guards And Platforms
Group T - Seat
Group T - Seat (S N 144964 -)
Group T - Front Frame Weights (S N 132382 -)
Group U - Steering Gear (S N 132382 -)
Group U - Steering Linkage
Group U - Steering Linkage - Four Wheel Drive (S N 132382 -)
Group U - Power Steering Linkage (S N 132382 -)
Group U - Power Steering Linkage - Four Wheel Drive
Group U - Front Axle (S N 132382 -)
Group U - Front Axle And Axle Shafts - Four Wheel Drive
Group U - Front Axle Knuckle - Four Wheel Drive
Group U - Front Axle Differential Gear - Four Wheel Drive
Group W - Hood
Group W - Radiator Panel And Grille (S N 132382 -)
Group W - Instrument Panel (S N 132382 -)
Group W - Multimeter And Drive (S N 132382 -)
Group X - Tool Box (S N 132382 -)
Group X - Tools (S N 132382 -)
Group X - Metric Hardware Kit
Group Y - Weather Break (S N 132382 -)
Brand: White
Group B - Fuel Tank
Group B - Radiator
Group C - Brakes
Group P - Drawbar
Group T - Seat
Group W - Hood
