White Tractor 1365 1370 Parts Catalog 43320000
Brand: White
Model:
White 1365 Tractor
White 1370 Tractor
Part Number: 43320000
Number of Pages: 299 Pages
Decals (Not Illus.)
Crankshaft And Flywheel
Crankcase And Cylinder Head
Oil Pan And Crankcase Rear Cover
Crankcase Front Cover
Connecting Rods And Pistons
Camshaft Drive
Vibration Damper
Camshaft, Rocker Arms And Valves
Oil Pump, Filter And Level Gauge
Oil Pump
Intake And Exhaust Manifolds
Muffler
Muffler - Vertical Exhaust
Low Temperature Starting Aid (S N 000001 -)
Air Cleaner
Fuel Tank And Lines (S N 000001 -)
Fuel Injection System
Primer Pump
Nozzle Holder
Injection Pump Drive
Accelerator Control Linkage (S N 000001 -)
Engine Starting Equipment
Battery Holder
Starting Motor
Current Generating System
Alternator Assembly
Alternator Support Assembly
Lighting System (S N 000001 -)
Tail Lamp Assembly
Head Lamp
Warning Lamp
Horn
Radiator (S N 000001 -)
Fan, Belt And Pulleys (S N 000001 -)
Water Pump And Connections
Rear Main Frame
Clutch And Transmission Housing
Engine Clutch And Release Controls
Clutch
Transmission Gear Shift Lever (S N 000001 -)
Transmission Shifter Rods And Forks (S N 000001 -)
Reduction Gears (S N 000001 -)
Reduction Gears - Creeper Drive (S N 000001 -)
Reduction Gear Control (S N 000001 -)
Reduction Gear Control - Creeper Drive (S N 000001 -)
Brakes And Controls
Hand Brake (S N 000001 -)
Differential Lock (S N 000001 -)
Differential Rear
Rear Planetary Drive Gears
Rear Axle Carrier
Rear Axle
Rear Wheels And Weights
Pto Clutch Release Controls
Power Take-Off Disconnect (S N 000001 -)
Power Take-Off (S N 000001 -)
Belt Pulley (S N 000001 -)
Control Lever - 4wd (S N 000001 -)
Idler Gear Case (S N 000001 - 767375)
Idler Gear Case (S N 767376 -)
4wd Idler Gears (S N 000001 - 721487)
4wd Idler Gears (S N 721488 - 767375)
4wd Idler Gears (S N 767376 -)
Driveshaft - 4wd
Front Axle - 4wd
Front Axle Shafts - 4wd (S N 000001 - 767375)
Front Axle Shafts - 4wd (S N 767376 -)
Front Planetary Drive Gears And Case - 4wd
Front Planetary Drive Gears And Case - 4wd (S N 767376 -)
Differential - 4 Wd (S N 000001 - 711590)
Differential - 4wd (S N 711591 - 767375)
Differential - 4wd (S N 767376 -)
Steering Knuckle - 4wd (S N 000001 - 767375)
Steering Knuckle - 4wd (S N 767376 -)
Front Wheels - 4wd
Power Steering Pump, Cylinder, And Lines - 4wd
Power Steering Cylinder - 4wd
Power Steering Linkage - 4wd
Hydraulic Lift System
Hydraulic Lift Outer Controls
Hydraulic Lift Inner Controls
Distributor Valve
Hydraulic Lift Body
Hydraulic Lift Ram And Links
Hydraulic And Power Steering Pump Drive
Hydraulic Lift Additional Power Outlet Unit (S N 000001 -)
Hydraulic Lift Hoses And Connections
Power Lift Coupling
Power Lift Cylinder
Drawbar (S N 000001 -)
Three-Point Hitch Drawbar (S N 000001 -)
Three-Point Hitch - Category 1 And 2 (S N 000001 - 721487)
Three-Point Hitch - Category 1 And 2 (S N 721488 -)
Three-Point Hitch - Category 1 And 2 - High Clearance
Leveling Gear
Wheel Guards And Steps
Deluxe Seat
Front Frame Weights (S N 000001 -)
Steering Gear
Power Steering Pump, Cylinder And Lines - 2wd (S N 000001 -)
Power Steering Pump
Power Steering Reservoir
Power Steering Linkage (S N 000001 -)
Front Axle - 2wd (S N 000001 -)
Front Wheels And Weights - 2wd
Instruments And Multimeter Drive (S N 000001 -)
Hood And Instrument Panel (S N 000001 -)
Grille And Side Panels (S N 000001 -)
Tool Box (S N 000001 -)
Brand: White
Model:
White 1365 Tractor
White 1370 Tractor
Decals (Not Illus.)
Camshaft Drive
Vibration Damper
Oil Pump
Muffler
Air Cleaner
Primer Pump
Nozzle Holder
Battery Holder
Starting Motor
Alternator Assembly
Tail Lamp Assembly
Head Lamp
Warning Lamp
Horn
Rear Main Frame
Clutch
Brakes And Controls
Differential Rear
Rear Axle Carrier
Rear Axle
Driveshaft - 4wd
Front Axle - 4wd
Front Wheels - 4wd
Distributor Valve
Hydraulic Lift Body
Power Lift Coupling
Power Lift Cylinder
Leveling Gear
Deluxe Seat
Steering Gear
Power Steering Pump
