White Tractor 1355 Parts Catalog 43319900
Brand: White
Model: White 1355 Tractor
Part Number: 43319900
Number of Pages: 306 Pages
Decals And Name Plate (S N 503289 -) (Not Illus.)
Crankshaft And Flywheel (S N 503289 -)
Crankcase And Cylinder Head (S N 503289 -)
Connecting Rods And Pistons (S N 503289 -)
Camshaft Drive
Camshaft, Rocker Arms And Valves (S N 503289 -)
Vibration Damper (S N 503289 -)
Oil Pan And Crankcase Covers (S N 503289 -)
Oil Pump, Filter, And Level Gauge (S N 503289 -)
Oil Pump
Intake And Exhaust Manifolds (S N 503289 -)
Muffler (S N 503289 -)
Muffler - Vertical Exhaust (S N 503289 -)
Low Temperature Starting Aid (S N 503289 -)
Air Cleaner (S N 503289 -)
Air Cleaner
Fuel Tank (S N 503289 -)
Fuel Injection System (S N 503289 -)
Fuel Pump
Injection Nozzle Holder
Injection Pump Drive (S N 503289 -)
Accelerator Control Linkage (S N 503289 -)
Battery Holder (S N 503289 -)
Engine Starting Equipment (S N 503289 -)
Starting Motor
Current Generating System (S N 503289 -)
Alternator Assembly
Alternator Support Assembly
Lighting System (S N 503289 -)
Tail Lamp Assembly
Tail And Flood Lamp
Warning Lamp
Horn (S N 503289 -)
Coolant Heater (S N 503289 -)
Radiator (S N 503289 -)
Fan, Belt And Drive (S N 503289 -)
Water Pump And Connections (S N 503289 -)
Rear Main Frame And Clutch Housing (S N 503289 -)
Transmission (S N 503289 -)
Reduction Gears (S N 503289 -)
Reduction Gears - Creeper Drive (S N 503289 -)
Gear Shift - Inner (S N 503289 -)
Gear Shift - Outer (S N 503289 -)
Reduction Gear Control (S N 503289 -)
Reduction Gear Control - Creeper Drive (S N 503289 -)
Brakes And Controls
Hand Brake (S N 503289 -)
Differential Lock (S N 503289 -)
Differential Lock - Orchard (S N 503289 -)
Transfer Drive Engagement Controls - Four Wheel Drive
Transfer Drive Case And Covers - Four Wheel Drive
Transfer Drive Idler Unit Gears - Four Wheel Drive
Transfer Drive Shaft Assembly - 4wd
Belt Pulley (S N 503289 -)
Power Take-Off Pulley Controls (S N 503289 -)
Power Take-Off (S N 503289 -)
Hydraulic Lift
Lifter
Hydraulic Lift Additional Power Outlet Unit (S N 503289 -)
Hydraulic Lift Additional Power Outlet Unit - Orchard
Hydraulic Lift Hoses And Connections (S N 503289 -)
Power Lift Cylinder
Power Lift Coupling
Rear Wheels And Weights (S N 503289 -)
Front Wheels And Weight (S N 503289 -)
Drawbar (S N 503289 -)
Three-Point Hitch Drawbar (S N 503289 -)
Three-Point Hitch - Category 1 And 2 (S N 503289 -)
Three-Point Hitch - Category 1 And 2 - High Clearance
Three-Point Hitch - Category 1 And 2 - Orchard (S N 503289-)
Leveling Gear Assembly
Clutch Controls (S N 503289 -)
Clutch
Rear Axle Carrier (S N 503289 -)
Rear Axle Carrier - Orchard (S N 503289 -)
Rear Axle (S N 503289 -)
Final Drive Gears (S N 503289 -)
Wheel Guards And Steps (S N 503289 -)
Wheel Guards And Steps - Orchard (S N 503289 -)
Seat (S N 503289 -)
Steering Gear (S N 503289 -)
Steering Linkage (S N 503289 -)
Power Steering - Two Wheel Drive (S N 503289 -)
Power Steering - Two Wheel Drive - With Oil Reservoir
Power Steering Pump
Power Steering Cylinder
Power Steering - Orchard (S N 503289 -)
Power Steering - Four Wheel Drive
Power Steering - Four Wheel Drive (S N 503289 -)
Tie Rod Socket
Tank
Front Axle (S N 503289 -)
Front Axle And Axle Shafts - Four Wheel Drive (S N 503289 -)
Front Axle Knuckle - Four Wheel Drive
Front Axle Differential Gear - Four Wheel Drive
Front Axle Truss Rod - Four Wheel Drive (S N 503289 -)
Front Frame Weights (S N 503289 -)
Hood And Instrument Panel (S N 503289 -)
Radiator Grille And Inserts (S N 503289 -)
Instruments And Multimeter Drive (S N 503289 -)
Tools (S N 503289 -)
Tool Box (S N 503289 -)
