White Tractor 1265 1270 Parts Catalog 43320500
Brand: White
Model:
White 1265 Tractor
White 1270 Tractor
Part Number: 43320500
Number of Pages: 241 Pages
Decals (Not Illus.)
Crankshaft And Flywheel
Crankcase And Cylinder Head
Connecting Rods And Pistons
Camshaft Drive
Oil Pan And Crankcase Covers
Camshaft, Rocker Arms And Valves
Oil Pump, Filter And Level Gauge
Oil Pump
Intake And Exhaust Manifolds
Muffler - Optional
Muffler - Vertical Exhaust - Opitional
Air Cleaner
Low Temperature Starting Aid
Fuel Injection System
Fuel Pump
Injection Pump Drive
Accelerator Control Linkage
Battery Holder
Engine Starting Equipment
Starting Motor
Current Generating System
Alternator Asy.
Lighting System
Tail Lamp Asy.
Head Lamp
Warning Lamp
Horn
Fan, Belt And Drive
Water Pump And Connections
Coolant Heater
Tractor Body - Castings And Cover
Reduction Gears
Reduction Gears - Creeper Drive
Creeper Drive
Gear Shift - Outer
Gear Shift - Inner
Gear Shift - Inner - Creeper Drive
Reduction Unit Control - Creeper Drive
Propeller Shaft
Brakes
Hand Brake
Differential Lock
Control Lever - 4wd
Idler Gears And Case - 4wd
Drive Shaft - 4wd
Drive Shaft - 4wd - Greaseless
Power Take-Off And Pulley Controls
Belt Pulley
Power Take-Off
Hydraulic Lift
Hydraulic Lift Power Outlet Unit
Hydraulic Lift Hoses And Connections
Power Lift Coupling
Coupling - Snap On
Power Lift Cylinder
Rear Wheels And Weights
Front Wheels
Front Wheels - 4wd
Drawbar
Three - Point Hitch Drawbar
Three - Point Hitch - Category 1
Three - Point Hitch - Category 1 And 2
Leveling Gear
Clutch
Clutch Release System
Rear Axle Carrier
Rear Axle
Final Drive Gears
Final Drive Gears - 4wd
Wheel Guards And Platforms
Front Frame Weights
Steering Gear
Steering Linkage
Steering Linkage - Standard - 4wd
Power Steering Linkage - 4wd
Power Steering
Pump
Tank
Cylinder
Hydraulic System - Power Steering - 4wd
Power Steering Cylinder - 4wd
Front Axle
Front Axle - 4wd
Front Axle Shafts - 4wd
Steering Knuckle - 4wd
Differential - 4wd
Hood And Instrument Panel
Radiator Grille And Inserts
Instruments And Multimeter Drive
Tool Box
Tools
Brand: White
Model:
White 1265 Tractor
White 1270 Tractor
Decals (Not Illus.)
Camshaft Drive
Oil Pump
Muffler - Optional
Air Cleaner
Fuel Pump
Battery Holder
Starting Motor
Alternator Asy.
Lighting System
Tail Lamp Asy.
Head Lamp
Warning Lamp
Horn
Fan, Belt And Drive
Coolant Heater
Reduction Gears
Creeper Drive
Gear Shift - Outer
Gear Shift - Inner
Propeller Shaft
Brakes
Hand Brake
Differential Lock
Control Lever - 4wd
Drive Shaft - 4wd
Belt Pulley
Power Take-Off
Hydraulic Lift
Power Lift Coupling
Coupling - Snap On
Power Lift Cylinder
Front Wheels
Front Wheels - 4wd
Drawbar
Leveling Gear
Clutch
Rear Axle Carrier
Rear Axle
Final Drive Gears
Front Frame Weights
Steering Gear
Steering Linkage
Power Steering
Pump
Tank
Cylinder
Front Axle
Front Axle - 4wd
Differential - 4wd
Tool Box
Tools
