White Tractor 1255 Parts Catalog 43320900
Brand: White
Model: White 1255 Tractor
Part Number: 43320900
Number of Pages: 315 Pages
Power Lift Cylinder
Decals And Name Plate (Not Illus.)
Crankcase And Cylinder Head
Crankshaft And Flywheel
Connecting Rods And Pistons
Camshaft Drive
Camshaft, Rocker Arms And Valves
Oil Pan And Crankcase Covers
Oil Pump, Filter And Level Gauge
Oil Pump
Intake And Exhaust Manifolds
Muffler
Muffler - Vertical Exhaust
Low Temperature Starting Aid
Air Cleaner
Fuel Injection System
Fuel Pump
Nozzle Holder
Injection Pump Drive
Accelerator Control Linkage
Battery Holder
Engine Starting Equipment
Starting Motor
Current Generating System
Alternator Assembly
Alternator Support Assembly
Lighting System
Lighting System - Vineyard Tractor
Tail Lamp Assembly
Tail And Flood Lamp
Warning Lamp
Head Lamp Assembly
Coolant Heater
Fan, Belt And Drive
Water Pump And Connections
Tractor Body, Castings And Cover
Reduction Gears
Reduction Gear - Creeper Drive
Creeper Drive
Gear Shift - Inner
Gear Shift - Inner - Creeper Drive
Reduction Unit Control - Creeper Drive
Gear Shift - Outer
Gear Shift - Outer - Creeper Drive
Propeller Shaft
Hand Brake
Brakes And Controls
Differential Lock
Differential Lock - Creeper Drive
Transfer Drive Engagement Controls - Four Wheel Drive
Transfer Drive Case And Convers - Four Wheel Drive
Transfer Drive Idler Unit Gears - Four Wheel Drive
Transfer Drive Shaft And Clutch
Belt Pulley
Power Take-Off And Pulley Controls
Power Take-Off
Hydraulic Lift
Hydraulic Lift Additional Power Outlet Unit
Hydraulic Lift Hoses And Connections
Power Lift Coupling
Front Wheels
Rear Wheels And Weights
Front Wheels - Four Wheel Drive
Rear Wheels An Weights - Vineyard Tractor
Drawbar
Three-Point Hitch Drawbar
Three-Point Hitch Drawbar - Vineyard Tractor
Three-Point Hitch - Vinryard Tractor
Three-Point Hitch Category 1
Three-Point Hitch Category 1 And 2
Leveling Gear Assembly
Clutch
Clutch Release System
Rear Axle Carrier
Rear Axle Carrier - Vineyard Tractors
Rear Axle
Final Drive Gears
Wheel Guards And Platforms
Wheel Guards And Platforms - Vineyard Tractor
Steering Gear
Steering Linkage
Steering Linkage - Four Wheel Drive
Power Steering And Linkage
Power Steering Cylinder
Pump
Tie Rod Socket
Power Steering - Two Wheel Drive - With Oil Reservoir
Power Steering Pump
Tank
Front Axle
Front Axle And Axle Shafts - Four Wheel Drive
Front Axle Differential Gear - Four Wheel Drive
Front Axle Knuckle - Four Wheel Drive
Front Axle Truss Rod - Four Wheel Drive
Instruments And Tachometer Drive
Hood And Instrument Panel
Radiator Grille And Inserts
Tool Box
Front Frame Weights
