White Tractor 1250-A Parts Catalog 43307900
Brand: White
Model: White 1250-A Tractor
Part Number: 43307900
Number of Pages: 204 Pages
Group A - Decals And Name Plate (1250-A) (S N 360745 -)
Group B - Engine (1250-A) (S N 360745 -)
Group B - Crankcase And Cylinder Head (1250-A) (S N 360745-)
Group B - Crankshaft And Flywheel (1250-A) (S N 360745 -)
Group B - Connecting Rods And Pistons (1250-A) (S N 360745-)
Group B - Oil Pan And Crankcase Covers (1250-A)
Group B - Camshaft, Rocker Arms And Valves (1250-A)
Group B - Camshaft Drive (1250-A) (S N 360745 -)
Group B - Oil Pump, Filter And Level Gauge (1250-A)
Group B - Intake And Exhaust Manifolds (1250-A)
Group B - Muffler (1250-A) (S N 360745 -)
Group B - Muffler - Vertical Exhaust (1250-A) (S N 360745 -)
Group B - Air Cleaner (1250-A) (S N 360745 -)
Group B - Low Temperature Starting Aid (1250-A)
Group B - Fuel Tank (1250-A) (S N 360745 -)
Group B - Fuel Injection System (1250-A) (S N 360745 -)
Group B - Injection Pump Drive (1250-A) (S N 360745 -)
Group B - Accelerator Control Linkage (1250-A) (S N 360745-)
Group B - Battery Holder (1250-A) (S N 360745-)
Group B - Engine Starting Equipment (1250-A) (S N 360745 -)
Group B - Current Generating System (1250-A) (S N 360745 -)
Group B - Lighting System (1250-A) (S N 360745 -)
Group B - Lighting System - Vineyard Tractor (1250-A)
Group B - Fan, Belt And Drive (1250-A) (S N 360745 -)
Group B - Radiator (1250-A) (S N 360745 -)
Group B - Water Pump And Connections (1250-A) (S N 360745 -)
Group B - Coolant Heater (1250-A) (S N 360745 -)
Supplement - Coolant Heater - 8-10-72 - B&Q Engine & Clutch
Group C - Tractor Body, Castings And Covers (1250-A)
Group C - Transmission (1250-A) (S N 360745 -)
Group C - Reduction Gears (1250-A) (S N 360745 -)
Group C - Reduction Gears - Creeper Drive (1250-A)
Group C - Gear Shift - Outer (1250-A) (S N 360745 -)
Group C - Gear Shift - Outer - Creeper Drive (1250-A)
Group C - Gear Shift - Inner (1250-A) (S N 360745 -)
Group C - Gear Shift - Inner - Creeper Drive (1250-A)
Group C - Reduction Unit Control - Creeper Drive (1250-A)
Group C - Propeller Shaft (1250-A) (S N 360745 -)
Group C - Brakes (1250-A) (S N 360745 -)
Group C - Hand Brake (1250-A) (S N 360745 -)
Group C - Differential (1250-A) (S N 360745 -)
Group C - Differential Lock (1250-A) (S N 360745 -)
Group C - Differential Lock - Creeper Drive (1250-A)
Group C - Transfer Drive Engagement Controls - Four Wheel
Group C - Transfer Drive Case And Covers - Four Wheel
Group C - Transfer Drive Idler Unit Gears - Four Wheel Drive
Group C - Transfer Drive Shaft - Four Wheel Drive (1250-A)
Group D - Belt Pulley (1250-A) (S N 360745 -)
Group E - Power Take-Off And Pulley Controls (1250-A)
Group E - Power Take-Off (1250-A) (S N 360745 -)
Group F - Hydraulic Lift (1250-A) (S N 360745 -)
Group F - Hydraulic Lift Additional Power Outlet Unit
Group F - Hydraulic Lift Additional Power Outlet Unit -
Group H - Rear Wheels And Weights (1250-A) (S N 360745 -)
Group H - Rear Wheels And Weights - Vineyard Tractor
Group L - Front Wheels (1250-A) (S N 360745 -)
Group L - Front Wheels - Four Wheel Drive (1250-A)
Group P - Drawbar (1250-A) (S N 360745 -)
Group P - Three Point Hitch Drawbar (1250-A) (S N 360745 -)
Group P - Three Point Hitch Drawbar - Vineyard Tractor
Group P - Three Point Hitch Category 1 (1250-A)
Group P - Three Point Hitch Category 1 And 2 (1250-A)
Group P - Three Point Hitch - Vineyard Tractor (1250-A)
Group Q - Clutch Release System (1250-A) (S N 360745 -)
Group Q - Clutch (1250-A) (S N 360745 -)
Group R - Rear Axle Carrier (1250-A) (S N 360745 -)
Group R - Rear Axle Carrier - Vineyard Tractor (1250-A)
Group R - Rear Axle (1250-A) (S N 360745 -)
Group R - Final Drive Gears (1250-A) (S N 360745 -)
Group S - Wheel Guards And Platforms (1250-A) (S N 360745 -)
Group S - Wheel Guards And Platforms - Vineyard Tractor
Group T - Seat (1250-A) (S N 360745 -)
Group U - Steering Gear (1250-A) (S N 360745 -)
Group U - Steering Linkage (1250-A) (S N 360745 -)
Group U - Steering Linkage - Four Wheel Drive (1250-A)
Group U - Power Steering And Linkage (1250-A) (S N 360745 -)
Group U - Front Axle (1250-A) (S N 360745 -)
Group U - Front Axle And Axle Shafts - Four Wheel Drive
Group U - Front Axle Knuckle - Four Wheel Drive (1250-A)
Group U - Front Axle Differential Gear - Four Wheel Drive
Group U - Front Axle Truss Rod - Four Wheel Drive (1250-A)
Group W - Hood And Instrument Panel (1250-A) (S N 360745 -)
Group W - Radiator Grille And Inserts (1250-A) (S N 360745 -)
Group W - Instruments And Tachometer Drive (1250-A)
Group X - Tool Box (1250-A) (S N 360745 -)
Supplement - Breakdown For Service For Starter Motor
Brand: White
