White Planters 8604 8606 8608 8616 Parts Catalog 00722039
Brand: White
Type of Machine: Planters
Model: 8604, 8606, 8608, 8616
Part Number: 00722039
Number of Pages: 245 Pages
Publication Information
Drives - Transmission Assembly
Drives - Transmission Assembly-Continued
Drives - Wheel Drive (8604)
Drives - Wheel Drive-Left (8606)
Drives - Wheel Drive-Right (8606)
Drives - Wheel Drive-Left (8616 8608)
Drives - Wheel Drive-Right (8616 8608)
Drives - Row Unit Drive Assembly (8604)
Drives - Row Unit Drive (8606 Narrow)
Drives - Row Unit Drive (8616)
Drives - Row Unit Drive (8608 Narrow)
Drives - Drive Chain
Drives - Row Unit Extension
Air Tubes - Air Duct (8604)
Air Tubes - Air Duct (8604 W Interplant)
Air Tubes - Air Duct (8606 8616)
Air Tubes - Air Duct (8606 W Interplant)
Air Tubes - Air Duct (8608)
Air Tubes - Air Duct (8608 W Interplant)
Air Tubes - Air Gauge And Mounting
Electrical - Transport Light
Electrical - Electrical Harness Service Parts
Electrical - Harness (8604)
Electrical - Harness (8606)
Electrical - Harness (8608)
Electrical - Y Harness-Sm4000 (Up To 16 Row)
Electrical - Monitor-Up To 16 Row (Sm4000)
Electrical - Sm4000 Harness-Up To 16 Row (High Rate)
Electrical - Sm4000 Harness (Seed Smart)
Electrical - Sm4000 Harness-Adapter (Seed Smart)
Electrical - Sensor Harness-3 Foot (Seed Smart)
Electrical - Sensor And Tube (High Rate)
Electrical - Sensor Harness-30 Foot (Seed Smart)
Electrical - Sm4000-Magnetic Distance Sensor Harness
Electrical - Sensor Harness-15 Foot (Seed Smart)
Electrical - Sensor Harness-20 Foot (Seed Smart)
Electrical - Sensor And Tube (Seed Smart)
Electrical - Sm1500 Monitor And Harness-12 Row
Electrical - Radar Y Harness
Electrical - Radar Distance Sensor And Mounting
Electrical - Magnetic Distance Sensor
Row Units - Row Unit Mounting
Row Units - Tightener-Row Unit
Row Units - Row Unit-Lower
Row Units - Disc Assembly, (700155037 Disc Assembly)
Row Units - Seed Meter
Row Units - Seed Disc Identification Chart
Row Units - 2 Bushel Hopper, (Earlier Than Hp Serial Numbers)
Row Units - 2 Bushel Hopper Handle
Row Units - 2 Bushel Hopper, (Hp Serial Number And Later)
Row Units - 3 Bushel Hopper, (Earlier Than Hp Serial Numbers)
Row Units - 3 Bushel Hopper Handle
Row Units - 3 Bushel Hopper, (Hp Serial Numbers And Later)
Row Units - Seed Meter Funnel
Row Units - Gauge Wheel Mounting
Row Units - Gauge Wheel-Left
Row Units - Gauge Wheel Assembly-Right
Row Units - Gauge Wheel Assembly, (N859182 Gauge Wheel Assembly)
Row Units - Depth Adjustment Assembly
Row Units - Closing Wheel And Mounting (Rubber), (S.N. Hl---00101 Thru Hp---00114)
Row Units - Closing Wheel And Mounting (Rubber), (S.N. Hr---00101 And Later)
Row Units - Closing Wheel Assembly (Rubber), (854262 Closing Wheel Assembly)
Row Units - Closing Wheel And Mounting (Cast), (S.N. Hl---00101 Thru Hp---00114)
Row Units - Closing Wheel And Mounting (Cast), (S.N. Hr---00101 And Later)
Row Units - Closing Wheel Assembly (Cast), (854077 Closing Wheel Assembly)
Row Units - Single Closing Wheel And Mounting
Row Units - Row Unit Lockup
Markers - Marker-Left (Rigid)
Markers - Marker-Right (Rigid)
Markers - Folding Marker-Left (8616 8608)
Markers - Folding Marker-Right (8616 8608)
Markers - Folding Marker Chain And Pin, Left Side Shown Right Side Opposite
Markers - Notched Marker Disc
Markers - Solid Marker Disc (8604 8606)
Markers - Solid Marker Disc (8608 8616)
Tongue, Frame And Wheels - Hitch And Tongue (8604 8606)
Tongue, Frame And Wheels - Hitch And Tongue (8608 8616)
Tongue, Frame And Wheels - Frame, (Prior To S.N. Hp)
Tongue, Frame And Wheels - Frame, (S.N. Hp And Later)
Tongue, Frame And Wheels - Wheel Mounting
Tongue, Frame And Wheels - Wheel Arm
Tongue, Frame And Wheels - Wheel Hub
Hydraulics - Hydraulic Direct Drive (Ground Drive)
Hydraulics - Pto Pump Asm.-Ground Drive (540 Rpm)
Hydraulics - Pto Pump Assembly (540 Rpm), (W247844b Pto Pump Assembly)
Hydraulics - Pto Pump Kit (1000 Rpm), (1-3 8 Inch Shaft)
Hydraulics - Pto Pump Asm. (1000 Rpm, 1-3 8 Shaft), (W247845b Pto Pump Assembly)
Hydraulics - Pto Pump Kit (1000 Rpm), (1-3 4 Inch Shaft)
Hydraulics - Pto Pump Assembly (1000 Rpm), (855009 Pto Pump Assembly), (1-3 4 Inch Shaft)
Hydraulics - Wheel Lift Hydraulic-Left (8604)
Hydraulics - Wheel Lift Hydraulic-Right (8604)
Hydraulics - Wheel Lift Hydraulic-Left (8606 08)
Hydraulics - Wheel Lift Hydraulic-Right (8606 8608)
Hydraulics - Wheel Lift Hydraulic-Left (8616)
Hydraulics - Wheel Lift Hydraulic-Right (8616)
Hydraulics - Marker Hydraulic
Hydraulics - Hydraulic Cylinder Assembly, (853541 Hydraulic Cylinder Assembly), (Earlier Than Hp S.N.)
Hydraulics - Hydraulic Cylinder Assembly, (700724408 Hydraulic Cylinder Assembly), (S.N. Hp And Later)
Hydraulics - Hydraulic Cylinder Assembly (Wheel Lift), (N857749 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Cylinder Assembly (Wheel Lift), (N857750 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Sequence Valve Assembly, (N851998 Hydraulic Sequence Valve Asm.)
Hydraulics - Hydraulic Cylinder Assembly (Wheel Lift), (853916-Hydraulic Cylinder Assembly), (S.N. Hp And Later)
Hydraulics - Blower Hose
Hydraulics - Blower Assembly
Hydraulics - Hydraulic Blower Motor Assembly, (W247830b Hydraulic Blower Motor Asm.)
Hydraulics - Blower Flow Control Valve Assembly, (W247849b Flow Control Valve Assembly)
Hydraulics - Filter Assembly (Ground Drive), (W247850b Filter Assembly)
Hydraulics - Interplant Blower Remote (8604)
Hydraulics - Interplant Blower Remote (8606), (6 Row Narrow)
Hydraulics - Interplant Blower Remote (8616 8608), (8616-6 Row Wide, 8608-8 Row Narrow)
Decals And Kits - Decal Location Diagram
Decals And Kits - Decal And Location Diagram (Hoppers)
Decals And Kits - Transport Chain And Mounting
Decals And Kits - Jack Assembly, (400731 Jack Assembly)
Decals And Kits - Frame Jack Stand
Decals And Kits - Seed Rate Chart Decal And Mounting
Decals And Kits - Seed Meter Funnel Kit, (6000628 Seed Meter Funnel Kit)
Decals And Kits - Slow Moving Vehicle Emblem
Recommended Dealer Stock - Recommended Dealer Stock
