White Planters 8516 8523 8524 8531 Parts Catalog 00727143
Brand: White
Type of Machine: Planters
Model: 8516, 8523, 8524, 8531
Part Number: 00727143
Number of Pages: 508 Pages
Publication Information
Drives - Upper Drive (30 And 40 Foot Frame)
Drives - Upper Drive (45 Foot Frame)
Drives - Driveline Assembly, (700722933 Driveline Assembly), (Prior To S.N. Hr)
Drives - Driveline Assembly, (700724804 Driveline Assembly), (S.N. Hr And Later)
Drives - Upper Drive (60 Foot Frame)
Drives - Row Unit Drive-Center, L (30 Foot Frame)
Drives - Row Unit Drive-Center, R (30 Foot Frame)
Drives - Wing Row Unit Drive-L (30 Foot Frame)
Drives - Wing Row Unit Drive-R (30 Foot Frame)
Drives - Wing Drive Idler (8523 And 8531)
Drives - Row Unit Drive (30 40 45 Foot Frame)
Drives - Row Unit Drive-Center, L (40 Foot Frame)
Drives - Row Unit Drive-Center, R (40 Foot Frame)
Drives - Wing Row Unit Drive-L (40 Foot Frame)
Drives - Wing Row Unit Drive-R (40 Foot Frame)
Drives - Row Unit Drive-Shield (8516)
Drives - Row Unit Drive-Center (45 Foot Frame)
Drives - Wing Row Unit Drive-L (45 Foot Frame)
Drives - Wing Row Unit Drive-R (45 Foot Frame)
Drives - Wing Idler (40 And 45 Foot Frame)
Drives - Row Unit Drive-Center, L (60 Foot Frame)
Drives - Row Unit Drive-Center, R (60 Foot Frame)
Drives - Wing Row Unit Drive-Left (60 Foot Frame)
Drives - Wing Row Unit Drive-Right(60 Foot Frame)
Drives - Row Unit Drive (60 Foot Frame)
Drives - Row Unit Drive Tightener (60 Foot Frame)
Drives - Drive Chains
Air Tubes - Air Ducts-Center, Left (40 Foot Frame), (8516-30 Inch Row Spacing)
Air Tubes - Air Ducts-Center, Right (40 Foot Frame), (8516-30 Inch Row Spacing)
Air Tubes - Wing Air Ducts-Left (40 Foot Frame), (8516-30 Inch Row Spacing)
Air Tubes - Wing Air Ducts-Right (40 Foot Frame), (8516-30 Inch Row Spacing)
Air Tubes - Air Ducts-Center, Left (30 Foot Frame), (8523-15 Inch Row Spacing)
Air Tubes - Air Ducts-Center, Right (30 Foot Frame), (8523-15 Inch Row Spacing)
Air Tubes - Air Ducts-Center, Left (30 Foot Frame), (8523 8531-15 Inch Row Spacing)
Air Tubes - Air Ducts-Center, Right (30 Foot Frame), (8523 8531-15 Inch Row Spacing)
Air Tubes - Wing Air Ducts-Left (30 Foot Frame), (8523-15 Inch Row Spacing)
Air Tubes - Wing Air Ducts-Right (30 Foot Frame), (8523-15 Inch Row Spacing)
Air Tubes - Air Ducts-Center, Left (40 Foot Frame), (8524-20 Inch Row Spacing), (8531-15 Inch Row Spacing)
Air Tubes - Air Ducts-Center, Right (40 Foot Frame), (8524-20 Inch Row Spacing), (8531-15 Inch Row Spacing)
Air Tubes - Air Ducts-Center, L R (40 Foot Frame), (8524-20 Inch Row Spacing)
Air Tubes - Wing Air Ducts-Left (40 Foot Frame), (8524-20 Inch Row Spacing)
Air Tubes - Wing Air Ducts-Right (40 Foot Frame), (8524-20 Inch Row Spacing)
Air Tubes - Air Ducts-Center, Left (45 Foot Frame), (8524-22 Inch Row Spacing)
Air Tubes - Air Ducts-Center, Right (45 Foot Frame), (8524-22 Inch Row Spacing)
Air Tubes - Air Ducts-Center, L R (45 Foot Frame), (8524-22 Inch Row Spacing)
Air Tubes - Wing Air Ducts-Left (45 Foot Frame), (8524-22 Inch Row Spacing)
Air Tubes - Wing Air Ducts-Right (45 Foot Frame), (8524-22 Inch Row Spacing)
Air Tubes - Air Ducts-Center, Left (60 Foot Frame), (8524-30 Row Spacing)
Air Tubes - Air Ducts-Center, Right (60 Foot Frame), (8524-30 Inch Row Spacing)
Air Tubes - Air Ducts-Center, Left (60 Foot Frame), (8524-30 Inch Row Spacing)
Air Tubes - Wing Air Ducts-Left (60 Foot Frame), (8524-30 Inch Row Spacing)
Air Tubes - Wing Air Ducts-Right (60 Foot Frame), (8524-30 Inch Row Spacing)
Air Tubes - Air Pressure Gauges And Mounting
Electrical - Transport Lights-Front (30 Foot Frame)
Electrical - Transport Lights-Rear (30 Foot Frame)
Electrical - Transport Lights-Front(40 45 Foot Frame)
Electrical - Transport Lights-Rear (40 45 Foot Frame)
Electrical - Transport Lights-Front (60 Foot Frame)
Electrical - Transport Lights-Rear (60 Foot Frame)
Electrical - Valve Driver Harness-Front
Electrical - Valve Driver Harness-Rear
Electrical - Control Box Assembly, (Sn12321 Control Box Assembly)
Electrical - Marker Tongue Fold Valve Harness-Front
Electrical - Lift And Lower Valve Harness-Rear
Electrical - Switch Assembly
Electrical - Rate Controller And Mounting (Pc4000)
Electrical - Rate Controller Harness
Electrical - Radar Y Harness
Electrical - Radar Distance Sensor And Mounting
Electrical - Monitor Assembly-Up To 32 Row (Sm4000)
Electrical - Sm4000 Harness-32 Row (High Rate)
Electrical - Monitor Harness Asm-16 Row (High Rate), (30 Inch Row Spacing)
Electrical - Monitor Harness-23 Row (High Rate), (15 Inch Row Spacing)
Electrical - Monitor Harness Asm-24 Row (High Rate), (20 Inch Row Spacing)
Electrical - Monitor Harness Asm-24 Row (High Rate), (22 Inch Row Spacing)
Electrical - Monitor Harness Asm-24 Row (High Rate), (30 Inch Row Spacing)
Electrical - Monitor Harness Asm-31 Row (High Rate), (15 Inch Row Spacing)
Electrical - Sensor And Tube (High Rate)
Electrical - Harness-Sm4000 (Seed Smart)
Electrical - Harness-Adapter, Sm4000 (Seed Smart)
Electrical - Sensor Harness-Extensions (Seed Smart)
Electrical - Sensor And Tube (Seed Smart)
Electrical - Speed Sensor (30, 40 And 45 Foot Frame)
Electrical - Speed Sensor (60 Foot Frame)
Electrical - Electrical Service Parts
Row Units - Row Unit
Row Units - Row Unit-With Extension
Row Units - Tightener
Row Units - Row Unit-Lower
Row Units - Disc Assembly, (700155037 Disc Assembly)
Row Units - Row Unit Lockup
Row Units - Seed Meter
Row Units - Seed Disc Identification Chart
Row Units - Gauge Wheel Mounting
Row Units - Depth Adjustment
Row Units - Gauge Wheel Assembly-Left
Row Units - Gauge Wheel Assembly-Right
Row Units - Gauge Wheel Assembly, (N859182 Gauge Wheel Assembly)
Row Units - Closing Wheel Assembly (Rubber), (S.N. Hl-------- Thru Hp--------)
Row Units - Closing Wheel Assembly (Rubber), (854262 Closing Wheel Assembly)
Row Units - Closing Wheel Assembly (Rubber), (S.N. Hr------- And Later)
Row Units - Closing Wheel Assembly (Cast), (S.N. Hl-------- Thru Hp--------)
Row Units - Closing Wheel Assembly (Cast), (854077 Closing Wheel Assembly), (Left Side Shown, Right Side Opposite)
Row Units - Closing Wheel Kit (Cast), (S.N. Hr------- And Later)
Row Units - Single Closing Wheel Assembly
Row Units - Seed Module And Mounting
Row Units - Seed Tubes And Manifolds
Row Units - Seed Tubes And Mounting
Row Units - Seed Tube Dividers And Mounting (8531), (40 Foot Frame)
Row Units - Meter Cover
Row Units - Seed Module Blower Assembly, (700724688 Blower Assembly)
Row Units - 2 Bushel Hopper And Mounting
Row Units - 3 Bushel Hopper And Mounting
Row Units - Seed Meter Funnel
Markers - Marker Assembly-Left (30 Foot Frame)
Markers - Marker Assembly-Right (30 Foot Frame)
Markers - Marker Mounting-L R (30 Foot Frame)
Markers - Marker-Left (40 Foot Frame)
Markers - Marker-Left, Continued (40 Foot Frame)
Markers - Marker-Right (40 Foot Frame)
Markers - Marker-Right, Continued (40 Foot Frame)
Markers - Marker-Left (45 Foot Frame)
Markers - Marker-Left, Continued (45 Foot Frame)
Markers - Marker-Right (45 Foot Frame)
Markers - Marker-Right, Continued (45 Foot Frame)
Markers - Marker Disc-Notched And Mounting
Markers - Markers-Left And Right (60 Foot Frame)
Markers - Markers-L R, Continued (60 Foot Frame), (Left Shown, Right Opposite)
Markers - Marker Gauge Wheel Assembly-Left Right, (45 And 60 Foot Frame), (Right Side Shown, Left Side Opposite)
Markers - Marker Hub Assembly-Left And Right, (700157278 Marker Hub Assembly)
Tongue, Frame And Wheels - Hitch And Tongue Braces
Tongue, Frame And Wheels - Tongue, Hitch, Latch And Safety Chain, (30 Foot Frame)
Tongue, Frame And Wheels - Tongue, Hitch, Latch And Safety Chain, (40 Foot Frame)
Tongue, Frame And Wheels - Tongue, Hitch, Latch And Safety Chain, (45 Foot Frame)
Tongue, Frame And Wheels - Tongue, Hitch, Latch And Safety Chain, (60 Foot Frame)
Tongue, Frame And Wheels - Mainframe And Wings (30 40 Foot Frame)
Tongue, Frame And Wheels - Mainframe And Wings (45 Foot Frame)
Tongue, Frame And Wheels - Mainframe And Wings (60 Foot Frame)
Tongue, Frame And Wheels - Wings-Left And Right (30 Foot Frame)
Tongue, Frame And Wheels - Wings-Left And Right (40 Foot Frame)
Tongue, Frame And Wheels - Wings-Left And Right (45 Foot Frame)
Tongue, Frame And Wheels - Wings-Left And Right (60 Foot Frame)
Tongue, Frame And Wheels - Lift Wheel And Mounting
Tongue, Frame And Wheels - Hub Assembly
Tongue, Frame And Wheels - Center Frame And Row Unit Mounting, (8516-30 Inch Row Spacing)
Tongue, Frame And Wheels - Center Frame And Row Unit Mounting, (8524-20 Inch Row Spacing), (8531-15 Inch Row Spacing)
Tongue, Frame And Wheels - Center Frame And Row Unit Mounting(8524), (8524-22 Inch Row Spacing)
Tongue, Frame And Wheels - Wing Frame & Row Unit Mounting-L R(8516), (8516-40 Foot Frame,30 Inch Row Spacing)
Tongue, Frame And Wheels - Wing Frame & Row Unit Mounting-L R(8523), (8523-30 Foot Frame,15 Inch Row Spacing)
Tongue, Frame And Wheels - Wing Frame & Row Unit Mounting-L R(8524), (8524-20 Inch Row Spacing)
Tongue, Frame And Wheels - Wing Frame & Row Unit Mounting-L R(8524), (8524-22 Inch Row Spacing)
Tongue, Frame And Wheels - Wing Frame & Row Unit Mounting-L R(8531), (8531-40 Foot Frame,15 Inch Row Spacing)
Tongue, Frame And Wheels - Tube Mounting Supports
Tongue, Frame And Wheels - Seed Module Frame, Rails And Mounting
Hydraulics - Hydraulic Pto Drive And Pump Mounting, (30, 40 And 45 Foot Frame)
Hydraulics - Hydraulic Pto Drive And Pump Mounting, (60 Foot Frame)
Hydraulics - Pto Hydraulic Drive And Pump Mounting
Hydraulics - Hydraulics-Rear (30 Foot Frame)
Hydraulics - Hydraulics-Rear (40 Foot Frame)
Hydraulics - Hydraulics-Rear (45 Foot Frame)
Hydraulics - Hydraulics-Rear (60 Foot Frame)
Hydraulics - Hydraulic Valve Assembly, (N858339 Hydraulic Valve Assembly)
Hydraulics - Hydraulic Valve Assembly, (700724543 Hydraulic Valve Assembly)
Hydraulics - Blower
Hydraulics - Hydraulic Blower Motor Assembly, (W247830b Hydraulic Blower Motor Asm.)
Hydraulics - Hydraulic Drive Motor And Mounting, (30, 40 And 45 Foot Frame)
Hydraulics - Hydraulic Drive Motor And Mounting, (60 Foot Frame)
Hydraulics - Row Unit Hydraulic Drive Motor Assembly, (854428 Hydraulic Motor Assembly)
Hydraulics - Center Fill Blower Hydraulics, (30 Foot Frame)
Hydraulics - Center Fill Blower Hydraulics, (40, 45 And 60 Foot Frame)
Hydraulics - Blower Hydraulic Control Valve Assembly, (700723571 Blower Control Valve Asm.)
Hydraulics - Tongue Lift Hydraulics
Hydraulics - Tongue Lift Hydraulic Cylinder Assembly, (N857145 Hydraulic Cylinder Assembly)
Hydraulics - Lift And Lower Hydraulics, (30 Foot Frame)
Hydraulics - Lift And Lower Hydraulics, (40, 45 And 60 Foot Frame)
Hydraulics - Hydraulic Flow Divider Assembly, (Sn12354 Hydraulic Flow Divider Asm.), (30 Foot Frame)
Hydraulics - Hydraulic Flow Divider Assembly, (Sn10977 Hydraulic Flow Divider Asm.), (40, 45 And 60 Foot Frame)
Hydraulics - Lift And Lower Hydraulics-Left, (30 Foot Frame)
Hydraulics - Lift And Lower Hydraulics-Right, (30 Foot Frame)
Hydraulics - Lift And Lower Hydraulics-Left, (40 Foot Frame)
Hydraulics - Lift And Lower Hydraulics-Right, (40 Foot Frame)
Hydraulics - Lift And Lower Hydraulics-Left, (45 Foot Frame)
Hydraulics - Lift And Lower Hydraulics-Right, (45 Foot Frame)
Hydraulics - Lift And Lower Hydraulics-Left, (60 Foot Frame)
Hydraulics - Lift And Lower Hydraulics-Right, (60 Foot Frame)
Hydraulics - Fold Hydraulics-Left, (30 Foot Frame)
Hydraulics - Fold Hydraulics-Right, (30 Foot Frame)
Hydraulics - Fold Hydraulics-Left, (40 Foot Frame)
Hydraulics - Fold Hydraulics-Right, (40 Foot Frame)
Hydraulics - Fold Hydraulics-Left, (45 Foot Frame)
Hydraulics - Fold Hydraulics-Right, (45 Foot Frame)
Hydraulics - Fold Hydraulics-Center, (30, 40 And 45 Foot Frame)
Hydraulics - Hydraulic Cylinder Assembly-Fold, (N857064 Hydraulic Cylinder Assembly), (30, 40 And 45 Foot Frame)
Hydraulics - Fold Hydraulics-Left, (60 Foot Frame)
Hydraulics - Fold Hydraulics-Right, (60 Foot Frame)
Hydraulics - Fold Hydraulics-Center, (60 Foot Frame)
Hydraulics - Hydraulic Cylinder Assembly-Fold, (700723886 Hydraulic Cylinder Assembly), (60 Foot Frame)
Hydraulics - Wheel Lift Hydraulics-Center, Left, (30 Foot Frame)
Hydraulics - Wheel Lift Hydraulics-Center, Right, (30 Foot Frame)
Hydraulics - Wheel Lift Hydraulics-Center, Left, (40, 45 And 60 Foot Frame)
Hydraulics - Wheel Lift Hydraulics-Center, Right, (40, 45 And 60 Foot Frame)
Hydraulics - Wing Wheel Lift Hydraulics-Left Right, (30 Foot Frame)
Hydraulics - Wing Wheel Lift Hydraulics-Left Right, (40, 45 And 60 Foot Frame)
Hydraulics - Hydraulic Cylinder Assembly-Wheel Lift, (N857162 Cylinder Assembly-Hydraulic)
Hydraulics - Hydraulic Flow Divider Asm.-Wheel Lift, (N857568 Hydraulic Flow Divider Asm.)
Hydraulics - Marker Hydraulics-Front (30 40 45 Frame)
Hydraulics - Marker Hydraulics-Front (60 Foot Frame)
Hydraulics - Sequencing Valve Assembly, (Ba0282 Hydraulic Sequencing Valve Asm.), (30, 40 And 45 Foot Frame)
Hydraulics - Sequencing Valve Assembly, (700157702 Hydraulic Valve Assembly), (60 Foot Frame)
Hydraulics - Hydraulic Valve Assembly-Marker Fold, (Sn12313 Hydraulic Valve Assembly)
Hydraulics - Marker Hydraulics-Left (30 Foot Frame)
Hydraulics - Marker Hydraulics-Right (30 Foot Frame)
Hydraulics - Marker Hydraulics-Left (40 Foot Frame)
Hydraulics - Marker Hydraulics-Right (40 Foot Frame)
Hydraulics - Marker Hydraulics-Left (45 Foot Frame)
Hydraulics - Marker Hydraulics-Right (45 Foot Frame)
Hydraulics - Marker Hydraulics-Left (60 Foot Frame)
Hydraulics - Marker Hydraulics-Right (60 Foot Frame)
Hydraulics - Marker Hydraulics-Mounting, Left Right, (30 Foot Frame)
Hydraulics - Marker Hydraulic Cylinder Assembly, (855104 Hydraulic Cylinder Assembly), (30 Foot Frame)
Hydraulics - Marker Mounting Hydraulics, (40 And 45 Foot Frame)
Hydraulics - Marker Hydraulic Cylinder Assembly, (N857082 Hydraulic Cylinder Assembly), (40 And 45 Foot Frame)
Hydraulics - Marker Mounting Hydraulics, (60 Foot Frame)
Hydraulics - Marker Hydraulic Cylinder Assembly, (Sn12427 Hydraulic Cylinder Assembly), (60 Foot Frame)
Decals And Kits - Decals-Frame And Tongue (8523), (30 Foot Frame)
Decals And Kits - Decals-Frame And Tongue (8524 8531), (40 And 45 Foot Frame)
Decals And Kits - Decals-Tongue And Frame (8524), (60 Foot Frame)
Decals And Kits - Decals-Center Fill System
Decals And Kits - Decals-Hoppers (Center)
Decals And Kits - Decals-Hopper (Wings)
Decals And Kits - Decals-Center Fill System (Center)
Decals And Kits - Decals-Center Fill System (Wings)
Decals And Kits - Decals-Marker (8523), (Left Shown, Right Opposite)
Decals And Kits - Decals-Marker (8524), (40 And 45 Foot Frame)
Decals And Kits - Decals-Marker (8524), (60 Foot Frame)
Decals And Kits - Seed Meter Funnel Kit, (6000628 Seed Meter Funnel Kit)
Decals And Kits - Pto Coupler Kit-1000 Rpm, 1-3 8 Inch, (6000748 Pto Coupler Kit-1000 Rpm)
Decals And Kits - Pto Coupler Kit-1000 Rpm, 1-3 4 Inch, (6000747 Pto Coupler Kit-1000 Rpm)
Decals And Kits - Seed Disc Identification Chart
Recommended Dealer Stock - Recommended Dealer Stock
Brand: White
Hydraulics - Blower
