White Planters 8302-Rigid 8342-Flex Parts Catalog 00725886
Brand: White
Type of Machine: Planters
Model:
White 8302-Rigid Planters
White 8342-Flex Planters
Part Number: 00725886
Number of Pages: 277 Pages
Publication Information
Drives - Hydraulic Drive
Drives - Hydraulic Drive (Continued)
Drives - Driveline Assembly, (N856741 Driveline Assembly), (S.N. Hk43200112 Thru Hp43200123)
Drives - Driveline Assembly, (S.N. Hr43200101 And Later)
Drives - Hydraulic Drive Sensor
Drives - Row Unit Drive-Left (8302)
Drives - Row Unit Drive-Left (8302) Continued
Drives - Row Unit Drive-Right (8302)
Drives - Row Unit Drive-Right (8302) Continued
Drives - Row Unit Drive-Left (8342), (S.N. Hk34200112 Thru Hm34200100)
Drives - Row Unit Drive-Left (8342) Continued, (S.N. Hk34200112 Thru Hm34200100)
Drives - Row Unit Drive-Left (8342), (S.N. Hm34200101 And Later)
Drives - Row Unit Drive-Left (8342) Continued, (S.N. Hm34200101 And Later)
Drives - Row Unit Drive-Right (8342), (S.N. Hk34200112 Thru Hm34200100)
Drives - Row Unit Drive-Right (8342) Continued, (S.N. Hk34200112 Thru Hm34200100)
Drives - Row Unit Drive-Right (8342), (S.N. Hm34200101 And Later)
Drives - Ground Drive Transmission
Drives - Ground Drive Transmission Assembly-Cont.
Drives - Drive Chains
Air Tubes - Air Duct-8302 (Left)
Air Tubes - Air Duct-8302 (Right)
Air Tubes - Air Duct-Center (8342), (Ground Drive)
Air Tubes - Air Duct Assembly-Center (8342), (Hydraulic Drive)
Air Tubes - Air Duct-Left (8342)
Air Tubes - Air Duct-Right (8342)
Air Tubes - Air Gauge And Mounting
Electrical - Transport Light, (S.N. Hk30200101 Thru Hm30200100), (S.N. Hk34200112 Thru Hm34200100)
Electrical - Transport Light, (S.N. Hm30200101 And Later), (S.N. Hm34200101 And Later)
Electrical - Valve Driver And Blower Harness
Electrical - Electronic Sensor Harness Assembly
Electrical - Sm1500 Monitor And Mounting-12 Row
Electrical - Monitor And Mounting-16 Row (Sm4000)
Electrical - Sm4000 Harness (High Rate)
Electrical - Harness-Sm4000 (Seed Smart)
Electrical - Harness-Adapter, Sm4000 (Seed Smart)
Electrical - Sensor Harness-Extensions (Seed Smart)
Electrical - Radar Y Harness
Electrical - Magnetic Distance Sensor And Mounting
Electrical - Radar Distance Sensor And Mounting
Electrical - Sensor And Tube (Seed Smart)
Electrical - Sensor And Tube (High Rate)
Electrical - Rate Controller
Electrical - Rate Controller Harness
Electrical - Controller Extension
Electrical - Electrical Harness Service Parts
Row Units - Row Unit (With Angles)
Row Units - Row Unit (With Front Bracket)
Row Units - Row Unit Chain Tightener
Row Units - Row Unit-Lower
Row Units - Disc Assembly, (700164107 Disc Assembly)
Row Units - Row Unit Lockup, (S.N. Hk34200112 Thru Hp34200123)
Row Units - Row Unit Lockup, (S.N. Hr34200101 And Later)
Row Units - Gauge Wheel Mounting
Row Units - Depth Adjustment
Row Units - Gauge Wheel-Left
Row Units - Gauge Wheel-Right
Row Units - Gauge Wheel Assembly, (N859182 Gauge Wheel Assembly)
Row Units - 2 Bushel Hopper And Mounting
Row Units - 3 Bushel Hopper And Mounting
Row Units - Seed Meter
Row Units - Closing Wheel And Mounting (Rubber), (S.N. Hk---00112 Thru Hp---00123)
Row Units - Closing Wheel And Mounting (Rubber), (S.N. Hr---00101 And Later)
Row Units - Closing Wheel Assembly (Rubber), (854262 Closing Wheel Assembly)
Row Units - Closing Wheel And Mounting (Cast), (S.N. Hk---00112 Thru Hp---00123)
Row Units - Closing Wheel And Mounting (Cast), (S.N. Hr---00101 And Later)
Row Units - Closing Wheel Assembly (Cast), (854077 Closing Wheel Assembly), (Left Shown, Right Opposite)
Row Units - Single Closing Wheel
Row Units - Seed Disc Identification Chart
Markers - Marker-Left, (S.N. Hk30200101 Thru Hm30200100), (S.N. Hk34200112 Thru Hm34200100)
Markers - Marker-Right, (S.N. Hk30200101 Thru Hm30200100), (S.N. Hk34200112 Thru Hm34200100)
Markers - Marker-Left, (S.N. Hm30200101 And Later), (S.N. Hm34200101 And Later)
Markers - Marker-Right, (S.N. Hm30200101 And Later), (S.N. Hm34200101 And Later)
Markers - Marker Hub Assembly
Tongue, Frame And Wheels - Hitch And Tongue (8302)
Tongue, Frame And Wheels - Hitch And Tongue (8342)
Tongue, Frame And Wheels - Mainframe-8302
Tongue, Frame And Wheels - Tool Bar And Swing Arm-8302
Tongue, Frame And Wheels - Mainframe-8342
Tongue, Frame And Wheels - Tool Bar And Swing Arm (8342)
Tongue, Frame And Wheels - Row Unit Mounting-Center
Tongue, Frame And Wheels - Row Unit Mounting-Left
Tongue, Frame And Wheels - Row Unit Mounting-Right
Tongue, Frame And Wheels - Lift Wheel And Mounting, (With Transmission)
Tongue, Frame And Wheels - Wheel Hub Assembly
Tongue, Frame And Wheels - Depth Wheel Lift
Tongue, Frame And Wheels - Jack Assembly, (400731 Jack Assembly)
Hydraulics - Hydraulic Control Box
Hydraulics - Hydraulic Control Valve Assembly, (Ba5228 Control Valve Assembly)
Hydraulics - Hydraulic Sequencing Valve Assembly, (Ba0282 Hyd. Sequencing Valve Assembly)
Hydraulics - Hydraulic-Left Wing
Hydraulics - Hydraulic-Right Wing
Hydraulics - Hydraulic Cylinder Assembly-Wing Fold, (N855106 Hydraulic Cylinder Assembly), (Inner)
Hydraulics - Hydraulic Cylinder Assembly-Wing Fold, (855107 Hydraulic Cylinder Assembly), (Outer)
Hydraulics - Marker Hydraulic-Left
Hydraulics - Marker Hydraulic-Right
Hydraulics - Marker Hydraulic Cylinder Assembly, (855104 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Wheel Lift-8302 (Left)
Hydraulics - Hydraulic Wheel Lift-8302 (Right)
Hydraulics - Hydraulic Wheel Lift-Left (8342), (S.N. Hk34200112 Thru Hk34200141)
Hydraulics - Hydraulic Wheel Lift-Right (8342), (S.N. Hk34200112 Thru Hk34200141)
Hydraulics - Hydraulic Wheel Lift-Left (8342), (S.N. Hl34200101 And Later)
Hydraulics - Hydraulic Wheel Lift-Right (8342), (S.N. Hl34200101 And Later)
Hydraulics - Hydraulic Cylinder Assembly-Flex, (N857748 Hydraulic Cylinder Assembly)
Hydraulics - Hydraulic Cylinder Assembly-Wheel Lift, (855100 Hydraulic Cylinder Assembly), (Center)
Hydraulics - Hydraulic Cylinder Assembly-Wheel Lift, (N857748 Hydraulic Cylinder Assembly), (Left)
Hydraulics - Hydraulic Cylinder Assembly-Wheel Lift, (N857747 Hydraulic Cylinder Assembly), (Right)
Hydraulics - Blower And Hydraulic Drive-8342
Hydraulics - Hydraulic Motor Assembly, (854428 Hydraulic Motor Assembly)
Hydraulics - Hydraulic Valve Assembly, (N858339 Hydraulic Valve Assembly)
Hydraulics - Blower-Hydraulic Drive (8342)
Hydraulics - Hydraulic Blower Motor Assembly, (W247830b Hydraulic Blower Motor Asm.)
Hydraulics - Hydraulic Flow Control Valve (Blower), (N856657 Hydraulic Valve Assembly)
Hydraulics - Blower Hydraulic-Ground Drive (8342)
Hydraulics - Blower-Ground Drive (8342)
Hydraulics - Blower Flow Control Valve Assembly, (W247849b Blower Control Valve Assembly)
Hydraulics - Filter Assembly (Ground Drive), (W247850b Filter Assembly)
Hydraulics - Pto Pump And Mount-Ground Drive(540 Rpm)
Hydraulics - Pto Pump Assembly (540 Rpm), (W247844b Pto Pump Assembly)
Hydraulics - Pto Pump & Mount-Ground Drive (1000 Rpm), (1-3 8 Inch Shaft)
Hydraulics - Pto Pump Assembly (1000 Rpm,1-3 8 Shaft), (W247845b Pto Pump Assembly)
Hydraulics - Pto Pump & Mount-Ground Drive (1000 Rpm), (1-3 4 Inch Shaft)
Hydraulics - Pto Pump Assembly (1000 Rpm,1-3 4 Shaft), (855009 Pto Pump Assembly)
Hydraulics - Hydraulic Direct Drive (Ground Drive)
Decals And Kits - Decal Location
Decals And Kits - Decal Location (Continued)
Decals And Kits - Transport Chain And Mounting
Decals And Kits - Slow Moving Vehicle Emblem
Decals And Kits - Seed Rate Chart Decal And Mounting
Decals And Kits - Seed Meter Funnel Kit, (6000628 Seed Meter Funnel Kit)
Decals And Kits - Seed Disc Identification Chart
Recommended Dealer Stock - Recommended Dealer Stock
Brand: White
Model:
