White Industrial Wheeler UTI UTIL Parts Catalog R1145A00
Brand: White
Type of Machine: Industrial Wheeler
Model:
White UTI Industrial Wheeler
White UTIL Industrial Wheeler
Part Number: R1145A00
Number of Pages: 85 Pages
Crankcase And Gear Case
Cylinder Block, Head And Breather
Camshaft, Rocker Arms, Valves, Push Rods & Tappets
Crankshaft, Connecting, Rods, Pistons And Flywheel
Gas Manifold And Carburetor
Carburetor
Air Cleaner
Fuel Tank, Supports And Strainer
Hood, Grille And Muffler
Distributor, Coil, Cables, Spark Plugs
Governor (Group 1)
Governor (Group 2)
Oil Filter
Oil Pump
Water Pump And Water Inlet Manifold
Fan, Radiator, Thermostat & Water Outlet Manifold
Generator, Starting Motor, Battery Cover & Lamps
Instrument Panel, Instruments And Wires
Clutch, Clutch Shaft And Shifting (Uti Tractor)
Clutch, Clutch Shaft And Shifting (Util Tractor)
Midship Housing And Reverse Gear Shifting
Throttle Controls
Countershaft (Upper And Lower)
Gear Shifting And Transmission Case
Differential (Group 1)
Differential (Group 2)
Brakes
Belt Pulley Drive, Housing, Etc.
Steering Mechanism
Power Steering (Group 1)
Power Steering (Group 2)
Power Steering (Group 3) Reservoir
Front Axle
Front Wheels
Rear Axle, Housing And Bull Gear
Wheel Guard, Pintle Hook And Drawbar (Special)
Seat, Starting Crank, Tool Box And Tools And Decals
Rear Power Take-Off
Front Power Take-Off
