702,019
White Field Boss Tractor 4-270 Parts Catalog 43337400
Brand: White
Type of Machine: Field Boss Tractor
Model: White 4-270 Field Boss Tractor
Part Number: 43337400
Number of Pages: 249 Pages
Decals And Emblems
Front Frame
Ether Cold Starting
Air Cleaner
Muffler
Fuel Tank And Lines
Water Separator
Throttle Controls
Alternator And Starter
Starting Motor
Step, Battery Boxes And Cables
Coolant Conditioner And Lines
Main Drive Shafts
Clutch Pedal And Linkage - 4 X 4 Powershift Valve
Shift Lever And Linkage - 4 X 4 Powershift Valve
4 X 4 Powershift Valve, Filter And Lines
4 X 4 Powershift Control Valve
4 X 4 Powershift Pressure And Lube Pump
4 X 4 Powershift Oil Pressure Regulator, Filter And Lines
Transmission Oil Filters
4 X 4 Powershift Housing
Output Shaft - 4 X 4 Powershift
Transmission Brake
Rh Countershaft And Scavenge Pump - 4 X 4 Powershift
Lh Countershaft - 4 X 4 Powershift
Rh And Lh Countershafts - 4 X 4 Powershift
Transmission And Hydraulic Oil Cooler And Lines
Front Main Frame
Input Shaft - Manual Shift Transmission
Countershaft - Manual Shift Transmission
Pinion Shaft - Manual Shift Transmission
Rear Pinion Drive Shaft
Gear Shift Lever And Linkage - Manual Transmission
Gear Shift Cross Shafts, Rails And Forks - Manual Transmission
Park Lock Lever And Linkage
Brakes
Brake Pedal And Linkage
Brake Valves And Lines
Brake Valve
Front Differential And Differential Lock
Front Differential Lock Valve And Lines
Drive Axles And Planetary
Drive Wheels, Centers And Hubs
Rear Main Frame
Rear Pinion And Power Take-Off Drive Shafts - Articulation Joint
Power Take-Off U-Joint Drive Shaft
Rear Pinion Shaft And Ring Gear
Rear Differential And Differential Lock
Power Take-Off And Hydraulic Pump Drive
Power Take-Off Clutch And Brake
1000 Rpm Power Take-Off
Power Take-Off Control Lever And Linkage
Power Take-Off And Rear Differential Lock Valve And Lines
Power Take-Off And Differential Lock Valve
Hydraulic Housing And Cover
Hydraulic And Line Charge Pump Drive
Hydraulic Oil Filter
Hydraulic Pump, Pressure Control Valve And Lines
Remote Valve Control Levers And Linkage
Remote Valves
Pressure Detent Valve
Float Valve
Remote Hydraulic Lever Couplings, Cylinders And Hoses
Depth Stop Cylinder - 4 Inch
Depth Stop Cylinder - 3-1 2 Inch
Three-Point Hitch Draft Sensing Shaft And Arm
Three-Point Hitch Draft Sensitivity Linkage
Servo Valve And Hitch Response Control Levers And Linkage
Servo Valve
Rockshaft, Lift Arms And Lift Cylinders
Lift Cylinder
Three-Point Hitch
Category Iii Quick Coupler
Category Iv And Iv Narrow Quick Couplers
Drawbar With Three-Point Hitch
Wide Swinging Drawbar
Center Frame - Articulating
Center Frame Steering - Articulating
Power Steering Cylinder
Steering Wheel, Steering Column And Pedal Support
Power Steering Control Unit And Lines
Steering
Lights And Light Wiring Harnesses
Head Lamp
Flood Lamp
Tail Lamp
Flood And Tail Lamp
Auxilary Light Connector
Instrument Panel
Rh Instrument Panel Monitors, Sending Units And Switches
Lh And Lower Instrument Panel, Switches And Circuit Breakers
Seat And Suspension Mounting
Seat And Suspension
Hood And Side Panels
Grille
Tool Box
Safety Chain
Cab Body
Cab Headliner And Foam Panels
Radio
Cab Door And Windows
Cab Glass Specifications
Windshield Wiper
Cab Mounting
Cab Control Lever Console
Cab Electrical System
Cab Heater
Cab Blower
Cab Recirculation Filter & Cover
Cab Air Conditioner - Evaporator, Condenser And Lines
Cab Air Conditioner Compressor, Clutch And Pulley
Air Conditioner Compressure Clutch
