White Field Boss Tractor 4-225 Parts Catalog 43337500
Brand: White
Type of Machine: Field Boss Tractor
Model: White 4-225 Field Boss Tractor
Part Number: 43337500
Number of Pages: 232 Pages
Decals And Emblems
Front Frame
Ether Cold Starting
Air Cleaner
Muffler
Main Fuel Tank And Lines
Wheel Guard Fuel Tank Lines
Wheel Guard Fuel Tanks
Water Separator
Throttle Linkage
Alternator And Starter
Starting Motor
Step, Battery Box And Cables
Clutch
Clutch Pedal And Linkage
Over Under Transmission Lever And Linkage
Over Under Transmission Cover, Filter And Pump
Over Under Transmission Oil Pump
Remote Mounted Engine Oil Pressure Sending Unit
Over Under And Hydraulic Oil Cooler And Lines
Front Main Frame
Transmission Drive Shaft
Transmission Input Shaft
Transmission Countershaft And Reverse Idler
Transmission Pinion Shaft
Gear Shift
Park Lock Lever And Linkage
Brake Pedal And Linkage
Brakes
Brake Valve And Lines
Brake Valve
Front Differential And Differential Lock
Drive Axles And Planetary
Drive Wheels, Centers And Hubs
Dual Wheels
Rear Main Frame
Rear Main Drive Shaft, Ring Gear And Pinion
Rear Differential And Differential Lock
Power Take-Off Drive And Transfer Pump
Power Take-Off Drive Shaft
Lube, Breather And Transfer Pump Lines
Power Take-Off Clutch And Brake
Power Take-Off
Power Take-Off Control Lever And Linkage
Power Take-Off And Differential Lock Valve And Lines
Hydraulic Housing And Cover
Hydraulic And Lube Charge Pump Drive
Hydraulic Oil Filter
Hydraulic Pump, Pressure Valve And Lines
Pressure Control Valve
Remote Valve Control Levers And Linkage
Remote Valves
Pressure Detent Valve
Float Valve
Remote Hydraulic Lever Couplings, Cylinders And Hoses
Depth Stop Cylinder - 4 Inch
Dept Stop Cylinder - 3-1 2 Inch
Three-Point Hitch Draft Sensing And Arm
Three-Point Hitch Draft Sensitivity Linkage
Servo Valve And Hitch Response Control Levers And Linkage
Servo Valve
Rockshaft And Lift Cylinder
Three-Point Hitch - Category Iii
Increased Capacity Three-Point Hitch - Category Iii
Lift Cylinder
Category Ii And Iii Narrow And Category Iii Wide Quick-Hitch
Drawbar
Safety Chain
Wide Drawbar
Center Frame - Articulating
Center Frame Steering - Articulating
Steering Cylinder
Steering Wheel, Steering Column And Pedal Support
Power Steering
Steering Control Unit
Lights
Head Lamp
Flood Lamp
Flood And Tail Lamp
Auxiliary Light Connector
Instrument Panel
Rh Instrument Panel Monitors, Sending Units And Switches
Seat And Suspension Mounting
Seat And Suspension
Hood And Side Panels
Grille
Tool Box
Cab Body
Cab Headliner And Foam Panels
Radio
Cab Door And Windows
Cab Glass Specifications
Windshield Wiper
Cab Mounting
Cab Control Lever Console
Cab Electrical System
Cab Heater
Cab Blower
Cab Air Recirculation Filter & Cover
Cab Air Conditioning-Evaporator, Condenser And Line
Air Conditioning Service Parts
Air Conditioner Compressor
Air Conditioner Compressure Clutch
