White Field Boss Tractor 4-180 Parts Catalog 43321900
Brand: White
Type of Machine: Field Boss Tractor
Model: White 4-180 Field Boss Tractor
Part Number: 43321900
Number of Pages: 265 Pages
Front Frame
Name Plates And Decal Set
Valve Mechanism (S N 90n6121 And Later)
Camshaft (S N 90n6121 And Later)
Front Housing (S N 90n6121 And Later)
Engine Support - Front (S N 90n6121 And Later)
Cylinder Block And Cover
Cylinder Head And Valves
Crankshaft (S N 90n6121 And Later)
Crankshaft Pulley And Seals (S N 90n6121 And Later)
Flywheel, Flywheel Housing And Cover (S N 90n6121 And Later)
Connecting Rods And Pistons (S N 90n6121 And Later)
Oil Pan And Dipstick (S N 90n6121 And Later)
Oil Lines - Rear Sump (S N 90n6121 And Later)
Oil Pump And Filter (S N 90n6121 And Later)
Oil Cooler (S N 90n6121 And Later)
Water Pump (S N 90n6121 And Later)
Water Lines (S N 9046121 And Later)
Inlet Manifold (S N 90n6121 And Later)
Exhaust Manifold (S N 90n6121 And Later)
Positive Crankshaft Ventilation Valve
Crankshaft Ventilation Valve (S N 90n6121 And Later)
Governor And Fuel Pump Drive (S N 90n6121 And Later)
Governor Control (S N 90n6121 And Later)
Fuel Injection System (S N 90n6121 And Later)
Governor & Fuel Injection Pump - Part 1
Governor & Fuel Injection Pump - Part 2
Governor & Fuel Injection Pump - Part 3
Governor & Fuel Injection Pump - Part 4
Electric Shut-Off (S N 90n6121 And Later)
Torque Control (S N 90n6121 And Later)
Fuel Injection Lines (S N 90n6121 And Later)
Fuel Filter (S N 90n6121 And Later)
Fuel Filter Lines (S N 90n6121 And Later)
Fuel Priming Pump (S N 90n6121 And Later)
Valve Cover
Muffler And Exhaust Pipes
Preheater
Air Cleaner
Main Fuel Tank Lines
Wheel Guard Fuel Tanks
Throttle Control
Alternator And Starter
Starting Motor
Transmission Pressure Lube System - Front Frame
Relief Valve
Transmission Pressure Lube System - Rear Frame
Pressure Lube Pump - Front
Transmission Lube Pump - Rear
Front Main Frame
Transmission Drive Shaft - S N 256587 Thru 275079
Transmission Drive Shaft - S N 275080 And Later
Gear Shift
Brake Controls
Brakes
Differential - Front Frame
Rear Main Frame
Rear Main Drive And Differnetial
Drive Shaft
Two-Speed Shift Lever And Linkage
Two-Speed Transmission
Two-Speed Oil Cooler
Cooler And Hydraulic Pump Drive
Cooler And Hydraulic Pump Drive Shaft
Hydraulic Housing And Cover
Hydraulic Pump, Filter And Lines
Filter Assembly
Pressure Valve
Hydraulic Valves And Controls
Pressure Detent Valve
Valve - Servo
Float Valve
Control Levers
Hydraulic External Lifting Linkage
Cylinder
Cylinder, Hoses And Connections
Depth Stop Cylinder - 4 Inch
Depth Stop Cylinder - 3-1 2 Inch
Pressure Lube, Hydraulic And Cooler Pump Drive
Hydraulic Oil Cooler And Lines
Wheels And Rims
Lights
Head Lamp - 2 Beam
Warning Lamp
Drawbar - With Three-Point Hitch
Wide Drawbar
6,000 Lb Lift Hitch - Category 3
Clutch And Controls
Clutch
Planetary Final Drive
Planetary Hub
Seat And Suspension
Suspension
Bucket Seat
Center Frame - Articulation
Steering Cylinder
Power Steering
Steering Column
Unit Control
Hood, Side Panels And Grille
Instrument Panel
Tachourmeter
Tool Box
Cab Door & Windows
Cab Blower
Cab Pressurizer
Cab Heater
Air Conditioner Compressor And Drive Pulley
Cab Glass Specifications
Power Take-Off
Power Take-Off Clutch
Power Take-Off Valve
Flood Lamp
Catergor Ii & Iii Narrow And Categor Iii Wide Quick Hitch
Wheel Guard Fuel Tank Lines
Transmission Lube Switch
Brand: White
Front Frame
Valve Cover
Preheater
Air Cleaner
Throttle Control
Starting Motor
Relief Valve
Front Main Frame
Gear Shift
Brake Controls
Brakes
Rear Main Frame
Drive Shaft
Filter Assembly
Pressure Valve
Valve - Servo
Float Valve
Control Levers
Cylinder
Wheels And Rims
Lights
Head Lamp - 2 Beam
Warning Lamp
Wide Drawbar
Clutch And Controls
Clutch
Planetary Hub
Seat And Suspension
Suspension
Bucket Seat
Steering Cylinder
Power Steering
Steering Column
Unit Control
Instrument Panel
Tachourmeter
Tool Box
Cab Door & Windows
Cab Blower
Cab Pressurizer
Cab Heater
Power Take-Off
Flood Lamp
