White Field Boss Tractor 2-75 Parts Catalog 43336900
Brand: White
Type of Machine: Field Boss Tractor
Model: White 2-75 Field Boss Tractor
Part Number: 43336900
Number of Pages: 179 Pages
Cylinder Head And Valve Cover
Cylinder Block And Tachometer Drive
Timing Gear Case
Flywheel Housing
Oil Pan And Filler
Oil Pump
Camshaft And Valve Train
Engine Oil And Fuel Filters
Engine Oil Tubes
Water Pump And Engine Oil Cooler
Intake And Exhaust Manifold
Injection Nozzle And Lines
Engine Hanger And Attaching Parts
Fuel Injection Pump
Alternator And Starter
Feed Pump - Injection Pump
Starter
Muffler
Air Cleaner
Accelerator Pedal Linkage
Engine And Pto Clutch
Clutch Pedal And Linkage
Pto And Throttle Controls
Front And Rear Transmission Cases
Pto Drive
Gear Shift
Auxiliary, Creeper And Pto Shift Linkage
Pto Shaft And Shift Linkage
Pto Inter-Lock And 1000 Rpm Pto Shaft
Shift Levers And Linkage
Transfer Drive - 4wd
Drive Shaft - 4wd
Differential Lock And Linkage
Rear Axle Housing And Rear Wheel
Planetary And Sun Gear
Disc Brake
Parking Brake, Brake Pedal And Linkage
Power Steering Pump, Filter And Lines
Front Axle - 2wd
Axle Bracket And Power Steering Cylinder
Axle Support - 4wd
Steering Wheel And Column
Front Wheel And Hub - 2wd
Front Axle Housing - 4wd
Drive Hub Case And Tie Rod - 4wd
Front Differential - 4wd
Final Drive - 4wd
Planetary Final Drive - 4wd
Hydraulic Housing And Valves
Hydraulic Lift Arms And Cylinder
Draft And Position Control Levers
Internal Draft Sensitivity
Hydraulic Pump, Flow Divider Valve And Lines
Auxiliary Control Valve And Lines
Remote Coupling, Cylinder And Hoses
Cylinder - 2-1 2 Inch
Depth Stop Cylinder - 3-1 2 Inch
Remote Valve Hydraulic System
Three - Point Hitch
Hood, Side Panels And Grille
Front Frame
Side Panel And Grille Seals
Instrument Panel
Engine Heat Shield
Fender And Step Support Noounting
Fenders And Steps
Seat, Seat Suspension And Sonsole
Battery Box
Lamps
Instruments And Switches
Decals And Emblems
Drawbar
Gear Pump - Hydraulic
Tool Box And Tools
Clutch Pressure Plate
Restrictor Valve
Control Valve
Pto Flow Divider Valve
Roll Bar And Canopy
Seat And Suspension
