White Field Boss Tractor 2-70 Parts Catalog 43325900
Brand: White
Type of Machine: Field Boss Tractor
Model: White 2-70 Field Boss Tractor
Part Number: 43325900
Number of Pages: 255 Pages
Decals And Name Plates
Front Main Frame
Cylinder Head Cover And Breather
Rocker Arm And Push Rods
Cylinder Head And Valves
Crankcase
Crankshaft And Related Parts
Camshaft
Oil Pan And Pump
Engine Oil Pump
Engine Oil Filter - Gas
Engine Oil Filter - Diesel
Manifold - Gas
Manifold - Diesel
Manifold Preheater - Diesel
Muffler
Air Cleaner - Gas
Air Cleaner - Diesel
Air Cleaner
Pre-Cleaner
Main Fuel Tank
Fuel Strainer
Engine Fuel Filter - Diesel
Throttle Controls - Gas And Diesel
Governor Controls - Gas
Governor Housing
Governor Shaft
Carburetor
Governor Controls - Diesel
Injection Pump, Injectors And Accessory Drive - Diesel
Fuel Injection Pump
Ignition And Starter
Starting Motor
Distributor
Water Pump, Fan And Fan Belt
Coolant Heater
Rear Main Frame
Transmission Pressure Lube System
Transmission Pressure Lube Pump
Transfer Drive - Four Wheel Drive
Transfer Drive
Gear Shift
Brake Pedals And Linkage
Brakes
Over Under Hydraul-Shift Oil Cooler
Over Under Shift Cover, Lever And Linkage
Over Under Hydraul-Shift Oil Pump
Power Take-Off
Power Take-Off Control
Power Take-Off Clutch
Hydraulic Housing, Pump And Filter - Internal Valve
Demand Flow Divider
Hydraulic Pump - Internal Valve
Hydraulic Housing Cover - Internal Valve
Hydraulic Controls - Internal Valve
Hydraulic Draft Sensitivity - Internal Valve
Servo Valve
Hydraulic Internal Valve System Draft Sensitivity
Hydraulic Housing, Pump And Filter - External Valve
Hydraulic Pump - External Valve
Hydraulic Valves And Control Levers - External Valve
Control Valve - Double Acting
Float Valve
Cylinder, Hoses And Connections - Internal Valve
Cylinder, Hoses And Connections - External Valve
Depth Stop Cylinder - 3-1 2 Inch
Hydraulic Oil Cooler
Bypass Valve
Rear Wheel Rims
Front Frame Weights
Front Wheels And Hubs
Lights
Flood Lamp
Tail Lamp
Flood Lamp - Rear
Turn Signal Flasher
Drawbar
Three-Point Hitch
Clutch
Clutch Cover
Rear Axles
Wheel Guards
Platforms And Step
Seat Suspension
Roll Bar And Canopy
Power Steering
Steering Column
Control Unit
Power Steering Cylinder And Lines - Two Wheel Drive
Adjustable Front Axle Power Steering Mechanism
Wheatland Power Steering Mechanism
Wheatland Front Axle
Tie Rod
Tie Rod Assembly
Power Steering Cylinders And Lines - Four Wheel Drive
Front Axle, Carrier And Supports - Four Wheel Drive
Front Axle - 4 Wd
Front Axle Drive Shaft
Hood, Side Panels And Grille
Instrument Panel
Instruments And Gauges
Speed-O-Tac
Tool Box And Tools
Head Lamp
