702,019
White Field Boss Tractor 2-60 Parts Catalog 43326100
Brand: White
Type of Machine: Field Boss Tractor
Model: White 2-60 Field Boss Tractor
Part Number: 43326100
Number of Pages: 254 Pages
Decals And Name Plates
Crankshaft & Flywheel
Crankshaft And Cylinder Head
Oil Pan & Crankcase Rear Cover
Crankcase Front Cover
Connecting Rods & Pistons
Camshaft Drive
Vibration Damper
Camshaft, Rocker Arms And Valves
Oil Pump, Filter And Level Gauge
Oil Pump
Intake And Exhaust Manifolds
Muffler
Muffler - Vertical Exhaust
Low Temperature Starting Aid
Air Cleaner
Air Cleaner Assembly
Air Cleaner (S N 768387 And Later)
Pre-Cleaner (S N 768387 And Later)
Fuel Injection System
Fuel Pump
Nozzle Holder
Injection Pump Drive
Accelerator Control Linkage
Engine Starting Equipment
Starting Motor
Starting Motor (Not Illus.)
Battery Holder
Current Generating System
Alternator Support
Lighting System
Tail Lamp Assembly
Flood Lamp
Head Lamp
Auxiliary Light Connector
Turn Signal Flasher
Horn
Fan, Belt And Drive
Water Pump And Connections
Rear Main Frame
Clutch And Transmission Housing
Engine Clutch And Release Controls
Clutch
Transmission Gear Shift Lever
Transmission Shifter Rods And Forks
Reduction Gears
Reduction Gears - Creeper Drive
Reduction Gear Control
Reduction Gear Control - Creeper Drive
Brakes And Controls
Hand Brake
Differential Lock (S N 000001 And Later)
Rear Axle
Rear Axle Carrier
Rear Final Drive Gears
Rear Wheels And Weights
Rear Wheels And Weights - Powerjuster
Power Take-Off Disconnect
Pto Clutch Release Controls
Power Take-Off
Belt Pulley
Control Lever - 4wd
Idler Gear Case - 4wd
Idler Gear - 4wd
Drive Shaft - 4wd
Front Axle - Four Wheel Drive
Front Axle Shaft - Four-Wheel Drive
Front Planetary Drive Gears And Case
Differential - Four-Wheel Drive
Steering Knuckle - Four-Wheel Drive
Front Wheels And Weights - Two Wheel Drive
Front Wheels And Weights - Four-Wheel Drive
Steering Gear
Steering Box
Power Steering Pump, Cylinder And Lines - Four-Wheel Drive
Power Steering Cylinder - 4wd
Power Steering Linkage - 4wd
Power Steering Pump, Filter And Lines - 2wd
Power Steering Pump
Tank - Power Steering
Power Steering Cylinder - 2wd
Steering Linkage - 2wd
Front Axle
Hydraulic Lift
Hydraulic Lift Outer Controls
Hydraulic Lift Inner Controls
Distributor Valve
Hydraulic Lift Body
Hydraulic Lift Ram And Links
Hydraulic And Power Steering Pump Drive
Hydraulic Lift Additional Power Outlet Unit
Optional Hydraulic Lift Additional Power Outlet Unit
Hydraulic Cylinders, Hoses And Connections
Power Lift Cylinder
Hydraulic Lift Cylinder
Drawbar
Three-Point Hitch Drawbar
Three-Point Hitch - Category I And Ii
Leveling Gear
Wheel Guards And Steps - Heavy Duty
Roll Bar And Canopy
Front Frame Weights
Hood And Instrument Panel
Grille
Instruments And Multimeter Drive
Tool Box
