White Field Boss Tractor 2-45 Parts Catalog 43333800
Brand: White
Type of Machine: Field Boss Tractor
Model: White 2-45 Field Boss Tractor
Part Number: 43333800
Number of Pages: 175 Pages
Decals And Nameplates
Crankcase
Timing Gear Case, Water Pump And Fan Drive
Camshaft
Intake And Exhaust Manifold
Oil Lines
Fuel Pump, Injection Nozzles And Lines
Oil Pump
Oil Filter
Muffler And Exhaust Pipe
Air Cleaner
Fuel Tank, Filter And Lines
Accelerator Pedal And Linkage
Engine And Pto Clutch
Clutch Pedal And Linkage
Clutch Cover
Pto Clutch
Pto And Throttle Controls
Front Transmission Case
Rear Transmission Case
Pto Drive
Gear Shift
Auxiliary Creeper And Pto Shift Linkage
Power Take-Off
Shift Lever And Linkage
Pto Shield And Hydraulic Oil Filter
Differential Lock
Rear Axle Housing And Rear Wheel
Planetary And Sun Gear
Disc Brake
Brake Actuator
Brake Pedal And Linkage
Parking Brake And Linkage
Power Steering Pump, Filter And Lines
Front Axle - 2wd
Front Axle Housing - 4wd
Front Differential - 4wd
Power Steering
Power Steering Cylinder
Axle Support - 4wd
Steering Wheel And Column
Steering Column And Control Shaft
Front Wheel And Hub - 2wd
Final Drive - 4wd
Planetary Final Drive - 4wd
Transfer Drive - 4wd
Drive Shaft - 4wd
Hydraulic Housing And Valves
Restrictor Valve
Hydraulic Lift Arm And Cylinder
Control Valve
Cylinder, Hoses And Connections
Depth Stop Cylinder - 2-1 2 X 8
External Draft Sensitivity
Internal Draft Sensitivity
Hydraulic Pump, Valve And Lines
Flow Divider
Auxiliary Control Valve And Lines
Three-Point Hitch
Hood, Side Panels And Grille
Front Frame
Instrument Panel
Engine Heat Shield
Fender And Step Support Mounting
Fender And Step Mounting
Seat, Seat Suspension And Console
Seat And Suspension
Battery And Battery Box
Lights
Instrument And Switches
Stoplight, Safety Start Switch And Wiring Harness
Nameplates
Drawbar
Tools
