White Field Boss Tractor 2-30 2-35 Parts Catalog 43331700
Brand: White
Type of Machine: Field Boss Tractor
Model:
White 2-30 Field Boss Tractor
White 2-35 Field Boss Tractor
Part Number: 43331700
Number of Pages: 162 Pages
Name Plates, Decals And Hood Ornament
Crankcase - Upper
Timing Gear Case And Tachourmeter Drive
Oil Pan And Lower Crankcase
Crankshaft And Flywheel
Camshaft And Valve Train
Intake And Exhaust Manifolds
Injection Pump, Nozzle And Lines
Mechanical Governor - Injection Pump
Feed Pump - Injection Pump
Fuel Filter And Lines
Engine Oil Pump, Oil Filter And Line
Oil Pump
Oil Filter
Alternator And Starter
Starter
Exhaust And Intake System
Air Cleaner
Fuel Tank, Filter And Lines
Throttle Control And Linkage
Clutch Housing
Clutch
Clutch Pedal And Linkage
Transmission Case
Transmission Gears
Power Take-Off
Gear Shift
Rear Axle Housing
Rear Wheel
Brakes
Step, Brake Pedal And Linkage
Steering Wheel - Manual
Steering Gear Box - Manual
Steering Wheel - Power
Steering Gear Box - Power
Hydraulic And Power Steering Pump And Lines - 2wd
Hydraulic And Power Steering Pump And Lines - 4wd
Hydraulic Gear Pump With Manual Steering
Hydraulic Gear Pump With Power Steering
Axle Bracket And Balance Weight - 2wd
Front Axle - 2wd
Front Wheel - 2wd
Axle Housing And Bevel Case - 4wd
Final Case And Tie Rods - 4wd
Transfer Drive - 4wd
Drive Shaft System - 4wd
Differential Gears - 4wd
Axle Bracket And Balance Weight - 4wd
Front Wheels And Drive - 4wd
Hydraulic Lift And Controls
Hydraulic Control Valve
Auxiliary Hydraulic Valve And Hoses
Remote Coupling, Cylinder And Hoses
Cylinder - 2-1 2 X 8 Inch
Three-Point Hitch
Drawbar And Pto Cover
Hood And Grille
Hood Supports And Fan Covers
Instrument Panel
Roll Bar And Canopy
Seat And Fenders
Battery
Lights
Instrument And Switches
Wiring Harnesses
