White Field Boss Tractor 2-180 Parts Catalog 43329200
Brand: White
Type of Machine: Field Boss Tractor
Model: White 2-180 Field Boss Tractor
Part Number: 43329200
Number of Pages: 272 Pages
Decals And Name Plates
Front Main Frame
Valve Mechanism
Camshaft
Front Housing
Engine Support - Front
Cylinder Block And Cover
Cylinder Head And Valves
Crankshaft Pulley And Seals
Flywheel, Flywheel Housing And Cover
Connecting Rods And Pistons
Oil Pan And Dipstick
Oil Lines - Rear Sump
Oil Pump And Filters
Water Pump Drive Group
Fan Drive Group
Water Lines
Air Inlet Manifold
Exhaust Manifold
Positive Crankcase Ventilation Valve
Governor And Fuel Pump Drive
Governor Control
Fuel Injection System
Governor And Fuel Injection Pump - Part 1
Governor And Fuel Injection Pump - Part 2
Governor And Fuel Injection Pump - Part 3
Governor And Fuel Injection Pump - Part 4
Electric Shut-Off
Torque Control
Fuel Injection Lines
Fuel Filter Lines
Fuel Priming Pump
Pre-Cleaner - Aspirated
Air Cleaner
Muffler And Exhaust Pipes
Manifold Preheater
Auxiliary Fuel Tank And Lines
Main Fuel Tank
Main Fuel Tank Lines
Throttle Control
Ignition And Starter
Starting Motor
Step, Battery Box And Cables
Coolant Heater
Clutch
Clutch Pedal And Linkage
Over Under Hydraul-Shift Lever And Linkage
Over Under Hydraul-Shift Cover, Filter And Pump
Over Under Hydraul-Shift Oil Pump
Over Under And Hydraulic Oil Cooler And Lines
Rear Main Frame
Transmission Input Shaft
Transmission Countershaft And Reverse Idler
Transmission Pinion Shaft
Gear Shift
Park Lock Lever And Linkage
Brakes
Brake Pedals And Linkage
Brake Valve And Lines
Brake Valve
Differential And Differential Lock
Rear Axle And Planetary
Rear Wheels, Centers And Hubs
Dual Wheels
Front Frame Weights
Pto Drive Shafts, Clutch And Brake
Power Take-Off
Pto And Differential Lock Valve, Controls And Lines
Hydraulic Housing And Cover
Hydraulic And Lube Charge Pump Drive
Hydraulic Pump, Filter And Lines
Pressure Valve
Servo Valve, Control Lever And Linkage
Servo Valve
Remote Valves, Control Levers And Linkage
Float Valve
Pressure Detent Valve
Cylinders, Hoses And Connections
Depth Stop Cylinder - 4 Inch
Depth Stop Cylinder - 3-1 2 Inch
Hydraulic Internal Draft Sensitivity
Rockshaft And Lift Cylinder
Three-Point Hitch (Category Iii)
Category Ii-Iii Narrow And Category Iii Wide Quick Hitches
Drawbar
Wide Drawbar
Power Steering
Steering Column
Steering Control Unit
Power Steering Mechanism And Lines
Tie Rod
Front Axle
Front Wheels
Lights
Head Lamp
Flood Lamp
Tail Lamp
Warning Lamp
Instrument Panel
Instruments And Switches
Seat And Suspension
Seat Suspension
Hood And Side Panels
Grille
Tool Box
Cab Door And Windows
Cab Glass Specifications
Windshield Wiper
Cab Mounting
Cab Electrical System
Cab Air Conditioner - Evaporator And Heater Housing
Cab Blower
Cab Heater
Cab Air Conditioner - Compressor, Condenser And Evaporator
York Air Conditioner Compressor And Drive Pulley
Brand: White
Front Main Frame
Valve Mechanism
Camshaft
Front Housing
Fan Drive Group
Water Lines
Air Inlet Manifold
Exhaust Manifold
Governor Control
Electric Shut-Off
Torque Control
Fuel Filter Lines
Fuel Priming Pump
Air Cleaner
Manifold Preheater
Main Fuel Tank
Throttle Control
Starting Motor
Coolant Heater
Clutch
Rear Main Frame
Gear Shift
Brakes
Brake Valve
Dual Wheels
Front Frame Weights
Power Take-Off
Pressure Valve
Servo Valve
Float Valve
Drawbar
Wide Drawbar
Power Steering
Steering Column
Tie Rod
Front Axle
Front Wheels
Lights
Head Lamp
Flood Lamp
Tail Lamp
Warning Lamp
Instrument Panel
Seat And Suspension
Seat Suspension
Grille
Tool Box
Windshield Wiper
Cab Mounting
Cab Blower
Cab Heater
