White Field Boss Tractor 2-150 Parts Catalog 43322200
Brand: White
Type of Machine: Field Boss Tractor
Model: White 2-150 Field Boss Tractor
Part Number: 43322200
Number of Pages: 251 Pages
Decals And Name Plates
Cylinder Block, Cylinder Head And Breather
Camshaft, Rocker Arms, Valves, Push Rods And Tappets
Crankcase
Crankshaft, Connecting Rod, Pistons, Rings & Flywheel
Gear Case And Water Pump
Base Pan
Oil Cooler And Filter
Oil Pump
Intake And Exhaust Manifolds
Muffler
Manifold Preheater
Coolant Heater
Air Cleaner
Precleaner - Aspirator
Throttle Controls
Main Fuel Tank
Main Fuel Tank Lines And Filter
Wheel Guard Fuel Tanks
Wheel Guard Fuel Tank Lines
Auxiliary Fuel Tank And Lines
Fuel Injection Pump
Ignition And Starter
Starting Motor
Battery Box And Cables
Fan And Pulley
Water Manifolds And Thermostat
Center Frame
Transmission Pressure Lube System
Transmission Lube Pump
Rear Main Frame
Gear Shift
Brake Pedals And Linkage
Brake Valve And Lines
Brake Valve
Hand Brake
Brakes
Over Under Hydraul-Shift Lever And Linkage
Over Under Hydraul-Shift Cover, Filter And Pump
Over Under Hydraul-Shift Oil Pump
Over Under Oil Cooler
Power Take-Off
Power Take-Off - Clutch And Drive
Valve - Power Take-Off
Hydraulic Housing And Cover
Hydraulic Pump, Filter And Lines
Hydraulic Oil Filter
Pressure Valve
Hydraulic Hand Controls
Pressure Detent Valve
Servo Valve
Float Valve
Hydraulic External Draft Sensitivity
Lift Cylinder
Cylinders, Hoses And Connections
Depths Stop Cylinder - 4 Inch
Depths Stop Cylinder - 3-1 2 Inch
Pressure Lube, Hydraulic And Cooler Pump Drive
Hydraulic Oil Cooler And Lines
Rear Wheels And Rims
Dual Wheels
Front Wheels
Lights
Head Lamp
Warning Lamp
Tail Lamp
Turn Signal Flasher
Drawbar
Wide Drawbar
6,000-Lb Lift Hitch (Category 3)
Clutch And Drive
Clutch Pedal And Linkage
Clutch Cover - 14
Rear Axle - Planetary Drive
Planetary Hub
Wheel Guards
Platform
Suspension
Roll Bar And Canopy
Front Frame Weights
Power Steering
Steering Column
Control Unit
Power Steering Cylinder And Lines
Steering Shaft Housing
Steering Mechanism
Tie Rod
Front Axle
Hood, Side Panels And Grille (S N 257899 Thru 259665)
Hood, Side Panels And Grille (S N 259666 And Later)
Instrument Panel
Speedometer
Tachourmeter
Tool Box
Cab Glass Specifications
Cab Mounting
Cab Electrical System
Cab Air Conditioner - Evaporator And Heater Housing
Cab Blower And Wiring
Cab Heater
Cab Air Conditioner - Condenser And Electrical Controls
Cab Air Conditioner - Compressor And Evaporator
Air Conditioner Compressor And Drive Pulley
Brand: White
Crankcase
Base Pan
Oil Pump
Muffler
Manifold Preheater
Coolant Heater
Air Cleaner
Throttle Controls
Main Fuel Tank
Fuel Injection Pump
Starting Motor
Fan And Pulley
Center Frame
Rear Main Frame
Gear Shift
Brake Valve
Hand Brake
Brakes
Power Take-Off
Pressure Valve
Servo Valve
Float Valve
Lift Cylinder
Dual Wheels
Front Wheels
Lights
Head Lamp
Warning Lamp
Tail Lamp
Turn Signal Flasher
Drawbar
Wide Drawbar
Clutch And Drive
Clutch Cover - 14
Planetary Hub
Wheel Guards
Platform
Suspension
Roll Bar And Canopy
Front Frame Weights
Power Steering
Steering Column
Control Unit
Steering Mechanism
Tie Rod
Front Axle
Instrument Panel
Speedometer
Tachourmeter
Tool Box
Cab Mounting
Cab Heater
