White Field Boss Tractor 2-135 2-155 Series 3 Parts Catalog 43337000
Brand: White
Type of Machine: Field Boss Tractor
Model:
White 2-135 Field Boss Tractor
White 2-155 Series 3 Field Boss Tractor
Part Number: 43337000
Number of Pages: 323 Pages
Decals And Emblems
Front Main Frame
Cylinder Head Cover And Breather
Rocker Arms And Push Rods
Cylinder Head And Valves
Crankcase
Crankshaft And Pistons
Camshaft
Oil Pan And Oil Pump
Oil Pump
Oil Filter And Oil Cooler
Intake And Exhaust Manifolds
Turbocharger
Muffler
Manifold Preheater
Air Cleaner
Aspirated Precleaner
Precleaner Screener
Lower Fuel Tank And Lines
Upper Fuel Tank And Lines
Fuel Filter, Water Separator And Lines
Hand Primer Pump
Throttle Controls
Injection Pump, Injectors And Lines
Nozzle And Holder Assembly
Alternator And Starter
Starting Motor
Step, Battery Box And Cables
Water Pump, Fan And Fan Belt
Engine Cooling System
Coolant Heater
Clutch
Clutch Cover
Clutch Pedal And Linkage
Over Under Transmission Shift Lever And Linkage
Over Under Transmission Cover, Filter And Pump
Over Under Transmission Oil Pump
2-135 Over Under Transmission
2-155 Over Under Transmission
Over Under And Hydraulic Oil Cooler And Lines
Rear Main Frame
Transmission Input Shaft
2-135 Transmission Countershaft And Reverse Idler
2-155 Transmission Countershaft And Reverse Idler
2-135 Transmission Pinion Shaft
2-155 Transmission Pinion Shaft
Gear Shift
Park Lock Lever And Linkage
Brakes
Brake Pedals And Linkage
Brake Valve And Lines
Brake Valve
Differential And Differential Lock
Rear Axle And Planetary
Rear Wheels, Centers And Hub
Dual Wheels
Pto Drive Shafts, Clutch And Brake
2-135 Dual Speed Power Take-Off
2-155 1000 Rpm Power Take-Off
Pto And Differential Lock Valve, Controls And Lines
Hydraulic And Lube Charge Pump Drive
Hydraulic Oil Filter
Hydraulic Pump, Pressure Control Valve And Lines
Servo Valve, Control Lever And Linkage
Servo Valve
Remote Valves, Control Levers And Linkage
Float Valve
Pressure Detent Valve
Remote Hydraulic Level Couplings, Cylinders And Hoses
Hydraulic Lever Couplings
Depth Stop Cylinder - 4 Inch
Depth Stop Cylinder - 3-1 2 Inch
Three-Point Hitch Draft Sensitivity
Rockshaft, Lift Arms And Lift Cylinder
Three-Point Hitch - Category Iii
Increased Capacity Three-Point Hitch - Category Iii
Lift Cylinder
Category Ii And Iii Narrow And Category Iii Wide Quick-Hitch
Drawbar
Safety Chain
Wide Drawbar
Steering Wheel, Steering Column And Pedal Support
Power Steering Control Unit And Lines
Power Steering Cylinder And Lines - 2wd
Front Axle Carrier And Tie Rod - 2wd
Tie Rod
Adjustable Front Axle
Front Wheels
Transfer Drive - 4wd
Control Linkage - 4wd
Power Steering Cylinders And Lines - 4wd
Power Steering Cylinder - 4wd
Front Axle, Carrier And Supports - 4wd
Drive Shaft - 4wd
Tie Rod - 4wd
Front Axle - 4wd
Differential Carrier - 4wd
Pivot And Spindle - 4wd
Planetary Wheel End - 4wd
Lights
Head Lamp
Flood Lamp
Tail Lamp
Auxiliary Light Connector
Ashtray And Lighter
Instrument Panel
Rh Instrument Panel Gauges, Warning Lights And Switches
Lh And Lower Instrument Panel Switches
Seat And Suspension
Seat Suspension
Hood And Side Panels
Grille
Tool Box
Front Frame Weights
Rops Platform And Canopy
Cab Body (S N 300928 Thru 302158)
Cab Body (S N 302159 And Later)
Cab Headliner And Foam Panels
Cab Radio And Speaker Plates And Grilles
Cab Doors And Windows
Cab Glass Specifications
Cab Roof Bird Guards (S N 300928 Thru 302158)
Windshield Wiper
Cab Mounting
Cab Electrical System (S N 300928 Thru 400417)
Cab Electrical System (S N 400418 And Later)
Cab Air Conditioner - Evaporator And Heater Housing
Cab Heater (S N 300928 Thru 400417)
Cab Heater (S N 400418 And Later)
Cab Blower
Cab Air Conditioner - Condenser And Evaporator
Cab Air Conditioner Compressor, Clutch And Pulley
Air Conditioner Compressor Clutch
Warning Lamp
Brand: White
Model:
Decals And Emblems
Front Main Frame
Crankcase
Camshaft
Oil Pump
Turbocharger
Muffler
Manifold Preheater
Air Cleaner
Precleaner Screener
Hand Primer Pump
Throttle Controls
Starting Motor
Coolant Heater
Clutch
Clutch Cover
Rear Main Frame
Gear Shift
Brakes
Brake Valve
Dual Wheels
Servo Valve
Float Valve
Lift Cylinder
Drawbar
Safety Chain
Wide Drawbar
Tie Rod
Front Wheels
Drive Shaft - 4wd
Tie Rod - 4wd
Front Axle - 4wd
Lights
Head Lamp
Flood Lamp
Tail Lamp
Ashtray And Lighter
Instrument Panel
Seat And Suspension
Seat Suspension
Grille
Tool Box
Front Frame Weights
Windshield Wiper
Cab Mounting
Cab Blower
Warning Lamp
