White Field Boss Tractor 2-135 2-155 Parts Catalog 43328200
Brand: White
Type of Machine: Field Boss Tractor
Model:
White 2-135 Field Boss Tractor
White 2-155 Field Boss Tractor
Part Number: 43328200
Number of Pages: 370 Pages
Decals And Name Plates
Front Main Frame
Cylinder Head Cover And Breather
Rocker Arms And Push Rods
Cylinder Head And Valves
Crankcase
Oil Pressure Regulator Housing
Crankshaft And Pistons
Camshaft
Oil Pan And Oil Pump
Oil Pump
Engine Oil Lines (S N 272595 Thru 296610)
Oil Filter And Oil Cooler
Intake And Exhaust Manifolds
Turbocharger
Muffler
Manifold Preheater
Air Cleaner
Aspirated Precleaner
Pre-Cleaner Screener
Lower Fuel Tank And Lines (S N 272595 Thru 278026)
Lower Fuel Tank And Lines (S N 278027 And Later)
Upper Tank To Lower Tank Transfer Kit
Upper Fuel Tank
Upper Fuel Tank Lines (S N 272595 Thru 278026)
Fuel Filter, Water Separator And Lines
Hand Primer Pump
Throttle Control
Injection Pump, Injectors And Lines
Nozzle And Holder Assembly
Alternator And Starter
Starting Motor
Step, Battery Box And Cables
Water Pump, Fan And Fan Belt
Engine Cooling System
Coolant Heater
Clutch
Clutch Cover
Clutch Pedal And Linkage
Over Under Transmission Shift Lever And Linkage
Over Under Transmission Cover, Filter And Pump
Over Under Transmission Oil Pump
Over Under Transmission - 2-155 (S N 287812 And Later)
Over Under And Hydraulic Oil Cooler And Lines
Rear Main Frame
Transmission Input Shaft
Transmission Countershaft And Reverse Idler - 2-135
Transmission Countershaft And Reverse Idler - 2-155
Transmission Pinion Shaft - 2-135
Transmission Pinion Shaft - 2-155
Gear Shift
Park Lock Lever And Linkage
Brakes
Brake Pedals And Linkage
Brake Valve And Lines
Differential And Differential Lock
Rear Axle And Planetary
Rear Wheels, Centers And Hub
Dual Wheels
Front Frame Weights
1000 Rpm Single Speed Power Take-Off - 2-135
Single And Dual Speed Power Take-Off - 2-135
1000 Rpm Power Take-Off - 2-155
Pto And Differential Lock Valve, Controls And Lines
Hydraulic Housing And Cover
Hydraulic And Lube Charge Pump Drive
Hydraulic Oil Filter
Hydraulic Pump, Pressure Control Valve And Lines
Servo Valve, Control Lever And Linkage
Servo Valve
Remote Valves, Control Levers And Linkage
Float Valve
Pressure Detent Valve
Remote Hydraulic Couplings, Cylinders And Hoses
Remote Hydraulic Lever Couplings And Hoses
Depth Stop Cylinder - 4 Inch
Depth Stop Cylinder - 3-1 2 Inch
Three-Point Hitch Draft Sensitivity
Rockshaft, Lift Arms And Lift Cylinder
Three-Point Hitch - Category Iii
Increased Capacity Three-Point Hitch - Category Iii
Lift Cylinder
Category Ii And Iii Narrow And Category Iii Wide Quick-Hitch
Drawbar
Safety Chain
Wide Drawbar
Power Steering
Steering Column
Steering Control Unit
Power Steering Cylinder And Lines
Front Axle Carrier And Tie Rod - 2wd
Tie Rod
Adjustable Front Axle
Front Wheels - 2wd And 4wd
Transfer Drive - 4wd
Control Linkage - 4wd
Power Steering Cylinders And Lines - 4wd
Power Steering Cylinder - 4wd
Front Axle, Carrier And Supports - 4wd
Drive Shaft - 4wd
Tie Rod - 4wd
Front Axle - 4wd
Differential Carrier - 4wd
Pivot And Spindle - 4wd
Planetary Wheel End - 4wd
Lights
Head Lamp
Flood Lamp
Tail Lamp
Warning Lamp
Auxiliary Light Connector
2-135 Instrument Panel
2-155 Instrument Panel
2-135 Instruments And Switches
2-155 Instruments And Switches
Seat And Suspension - 272595 - 293408
Seat And Suspension - 293409 -
Seat Suspension
2-135 Hood And Side Panels
2-155 Hood And Side Panels
Grille
Digital Monitor
Electric Speedometer
Tool Box
Cab - 272595 - 272916
Cab - S N 272917 And Later
Cab Door And Windows
Cab Glass Specifications
Cab Roof Bird Guards - 296878
Winshield Wiper
Cab Mounting
Cab Electrical System
Cab Air Conditioner - Evaporator And Heater Housing
Cab Air Conditioner - Evaporator And Heating Housing -272917
Cab Blower
Cab Heater
Cab Air Conditioner - Compressor, Evaporator And Condensor
Compressor Drive Belt Idler Pulley - S N 272595 - 278026
Cab Air Conditioner - Compressor, Condenser And Evaporator
Sankyo Compressor And Drive - S N 299208 -
207101165 Sankyo Conversion Kit Mounting Parts
Tecumseh Air Conditioner Compressor And Drive Pulley
York Air Conditioner Compressor And Drive Pulley
Air Conditioner Compressor Clutch
Brand: White
Model:
Front Main Frame
Crankcase
Camshaft
Oil Pump
Turbocharger
Muffler
Manifold Preheater
Air Cleaner
Upper Fuel Tank
Hand Primer Pump
Throttle Control
Starting Motor
Coolant Heater
Clutch
Clutch Cover
Rear Main Frame
Gear Shift
Brakes
Dual Wheels
Front Frame Weights
Servo Valve
Float Valve
Lift Cylinder
Drawbar
Safety Chain
Wide Drawbar
Power Steering
Steering Column
Tie Rod
Drive Shaft - 4wd
Tie Rod - 4wd
Front Axle - 4wd
Lights
Head Lamp
Flood Lamp
Tail Lamp
Warning Lamp
Seat Suspension
Grille
Digital Monitor
Tool Box
Winshield Wiper
Cab Mounting
Cab Blower
Cab Heater
