White Field Boss Tractor 2-105 Parts Catalog 43322000
Brand: White
Type of Machine: Field Boss Tractor
Model: White 2-105 Field Boss Tractor
Part Number: 43322000
Number of Pages: 424 Pages
Decals And Nameplates
Front Main Frame
Cylinder Head, Camshaft And Valves (S N 255216 Thru 297446)
Cylinder Head, Camshaft And Valves (S N 297447 And Later)
Cylinder Head Cover (S N 255216 Thru 297446)
Cylinder Head Cover, Breather And Oil Filter
Crankcase And Flywheel Housing - (S N 255216 Thru 297446)
Crankcase And Flywheel Housing - (S N 297447 And Later)
Crankshaft And Pistons (S N 255216 Thru 297446)
Crankshaft And Pistons (S N 297447 And Later)
Timing Gear And Auxiliary Drive (S N 255216 Thru 297446)
Timing Gear And Auxiliary Drive (S N 297447 And Later)
Oil Pan And Oil Pump (S N 255216 Thru 297446)
Oil Pan And Oil Pump (S N 297447 And Later)
Oil Filter (S N 255216 Thru 297446)
Oil Filter And Oil Cooler (S N 297447 And Later)
Intake And Exhaust Manifolds (S N 255216 Thru 297446)
Intake And Exhaust Manifolds (S N 297447 And Later)
Turbocharger And Lines (S N 297447 And Later)
Turbocharger
Muffler
Manifold Preheater (S N 255216 Thru 276761)
Thermostart (S N 276762 Thru 297446)
Ether Cold Starting
Air Cleaner (S N 276762 Thru 297446)
Vertical Air Intake Package (S N 255216 Thru 276761)
Air Cleaner (S N 297447 And Later)
Air Cleaner
Aspirated Pre-Cleaner (S N 276762 Thru 297446)
Aspirated Pre-Cleaner (S N 297447 And Later)
Fuel Filter, Fuel Pump And Lines (S N 255216 Thru 297446)
Fuel Filter, Fuel Pump And Lines (S N 297447 And Later)
Fuel Pump
Water Separator And Line (S N 297447 And Later)
Governor Hand Lever
Governor Controls
Injection Pump, Injectors And Lines (S N 255216 Thru 297446)
Injection Pump, Injectors And Lines (S N 297447 And Later)
Alternator And Starter (S N 255216 Thru 297446)
Alternator And Starter (S N 297447 And Later)
Starting Motor
Step, Battery Box And Cables
Cooling System (S N 255216 Thru 297446)
Water Pump, Fan And Fan Belt (S N 255216 Thru 297446)
Water Pump, Fan And Fan Belt (S N 297447 And Later)
Coolant Heater (S N 255216 Thru 297446)
Coolant Heater (S N 297447 And Later)
Upper Fuel Tank Lines
Upper Fuel Tank
Lower Fuel Tank And Lines (S N 255216 Thru 287001)
Upper Tank To Lower Tank Transfer Kit
Lower Fuel Tank And Lines (S N 287002 And Later)
Wheel Guard Fuel Tanks
Wheel Guard Fuel Tank Lines
Transmission Pressure Lube System
Transmission Pressure Lube Switch
Transmission Pressure Lube Pump
Rear Main Frame
Transmission Input Shaft
Transmission Countershaft And Reverse Idler
Transmission Pinion Shaft
Transfer Drive - 4wd
Transfer Drive
Gear Shift
Brake Pedals And Linkage
Brake Valve And Lines
Brake Valve
Hand Brake (S N 255216 Thru 282110)
Hand Brake (S N 282111 And Later)
Brakes
Over Under Hydraul-Shift Lever And Linkage
Over Under Hydraul-Shift Cover, Filter, And Pump
Over Under Hydraul-Shift Oil Pump
Over Under Oil Cooler
Power Take-Off
Pto Valve, Linkage And Lines
Power Take-Off Clutch And Drive
Power Take-Off Valve
Hydraulic Housing And Cover
Hydraulic Pump, Pressure Valve, Filter And Lines
Hydraulic Oil Filter
Pressure Valve
Hydraulic Hand Controls
Pressure Detent Valve
Servo Valve
Float Valve
Hydraulic Internal Draft Sensitivity - Category Ii
Hydraulic External Draft Sensitivity - Category Iii
Lift Cylinder
Cylinder, Hoses And Connections
Depth Stop Cylinder - 4 Inch
Depth Stop Cylinder - 3-1 2 Inch
Hydraulic Cooler And Lines
Transmission Lube, Hydraulic And Cooler Pump Drive
Rear Wheels Rims
Rear Wheels Weights
Front Wheel And Hub
Lights
Head Lamp
Flood Lamp
Tail Lamp
Warning Lamp
Turn Signal Flasher
Drawbar
Wide Drawbar
Safety Chain
Three-Point Hitch - Category Ii
6,000-Lb. Lift Hitch - Category Iii
Clutch
Clutch Cover - 13 Inch
Clutch Pedal And Linkage
Rear Axle
Wheel Guards
Platform
Instrument Panel
Seat - Without Cab (S N 255216 Thru 293284)
Seat - With Cab (S N 255216 Thru 279943)
Seat With Cab (S N 279944 Thru 293119)
Seat And Suspension (S N 293120 And Later)
Seat Suspension
Roll Bar And Canopy (S N 255216 Thru 280301)
Front Frame Weights
Roll Bar And Canopy (S N 280302 And Later)
Power Steering
Steering Column
Control Unit
Steering Control Unit
Power Steering Cylinder And Lines - 2wd
Adjustable Front Axle Power Steering Mechanism
Wheatland Power Steering Mechanism
Wheatland Front Axle
Tie Rod
Tie Rod Assembly
Front Axle Carrier And Supports - 4wd
Power Steering And Connections - 4wd
Power Steering And Connections - 4wd (S N 297447 And Later)
Front Axle - 4wd
Power Steering Clylinder
Front Axle Drive Shaft - 4wd
Hood, Side Panels And Grille (S N 255216 Thru 276761)
Hood And Side Panels (S N 276762 And Later)
Grille (S N 276762 And Later)
Speedometer
Tachourmeter
Tool Box
Cab (S N 255216 Thru 276761)
Cab (S N 276762 And Later)
Cab Door And Windows
Cab Glass Specifications
Cab Roof Bird Guards (S N 296878 And Later)
Windshield Wiper
Cab Mounting (S N 255216 Thru 276761)
Cab Mounting (S N 276762 And Later)
Cab Electrical System (S N 255216 Thru 276761)
Cab Electrical System (S N 276762 And Later)
Cab Air Conditioner - Evaporator And Heater Housing
Cab Blower (S N 276762 And Later)
Cab Heater (S N 255216 Thru 276761)
Cab Heater (S N 276762 And Later)
Cab Air Conditioner - Condenser And Electrical Controls
Cab Air Conditioner - Compressor And Evaporator
Cab Air Conditioner - Compressor, Condenser And Evaporator
Tecumseh Air Conditioner Compressor And Drive Pulley
York Air Conditioner Compressor And Drive Pulley
