White Field Boss Tractor 160 185 Parts Catalog 43338200
Brand: White
Type of Machine: Field Boss Tractor
Model:
White 160 Field Boss Tractor
White 185 Field Boss Tractor
Part Number: 43338200
Number of Pages: 300 Pages
Decals And Emblems
Front Main Frame
Oil Pan And Oil Pump
Crankshaft And Damper Pulley
Front Gear Cover
Camshaft
Connecting Rod And Pistion - Model 185
Cylinder Head And Rocker Levers
Engine Oil Cooler And Filter
Valve Cover And Crankcase Breather
Fuel Injection Pump, Injectors And Lines - Model 160
Fuel Injection Pump, Injectors And Lines - Model 185
Fuel Filter And Lift Pump
Flywheel And Flywheel Housing
Turbocharger And Exhaust Manifold - Model 160
Turbocharger, Aftercooler And Exhaust Manifold - Model 185
Water Pump And Fan Drive
Corrosion Resistor - Model 185 - 400 659 - 401 014
Thermostat Housing And Corrosion Resistor -
Air Cleaner
Ether Cold Starting
Muffler And Exhaust Pipes
Lower Fuel Tank And Lines
Upper Fuel Tank And Lines
Throttle Controls
Alternator And Starting Motor
Starting Motor
Step, Battery, Box And Cables
Fan, Radiator And Hoses
Clutch
Clutch Pedal And Linkage
Over Under Transmission Shift Lever And Linkage
Over Under Transmission Cover, Filter And Pump
Over Under Transmission Oil Pump
Over Under And Hydraulic Oil Cooler And Lines
Rear Main Frame
Transmission Input Shaft
Transmission Countershaft And Reverse Idler
Transmission Pinion Shaft
Gear Shift
Park Lock Lever And Linkage
Brakes
Brake Pedals And Linkage
Brake Valve And Lines
Brake Valve
Differential And Differential Lock
Rear Axle And Planetary
Rear Wheels, Centers And Hub
Duel Wheels, Centers And Hubs
Pto And Differential Lock Valve, Controls And Lines
Hydraulic Housing And Cover
Hydraulic And Lube Charge Pump Drive
Hydraulic Oil Filter
Hydraulic Pump, Pressure Control Valve And Lines
Servo Valve, Control Lever And Linkage
Servo Valve
Remote Valves, Control Levers And Linkage
Remote Valve
Remote Hydraulic Lever Couplings, Cylinders And Hoses
Remote Cylinder - 4 Inch
Remote Cylinder - 3-1 2 X 8
Three-Point Hitch Draft Sensitivity
Rockshaft, Lift Arms And Lift Cylinder
Three-Point Hitch - Category
Increased Capacity Three-Point Hitch - Category Iii
Lift Cylinder
Category Ii And Iii Narrow And Category Iii Wide Quick-Hitch
Drawbar
Safety Chain
Wide Swing Drawbar
Steering Wheel, Steering Column And Pedal Support
Power Steering Control Unit And Lines
Power Steering Cylinders And Support - 2wd
Tie Rod
Adjustable Front Axle And Carrier - 2wd
Front Wheels - All 2wd Pfa - Pfa - 400659 - 401023
Wheels - Pfa - 401024
Transfer Drive - Pfa
Control Linkage - Pfa
Power Steering Cylinders And Lines - Pfa - 400659 - 401023
Power Steering Cylinders And Lines - Pfa - 401024 And Later
Power Steering Cylinder - Pfa - 400659 - 401023
Power Steering Cylinder - Pfa - 401024
Front Axle, Carrier And Supports - Pfa - 400659 - 401023
Front Axle And Supports - Pfa - 401024 And Later
Front Axle Drive Shaft - Pfa - 400659 Thru 401023
Tie Rod - Pfa - 400659 - 401023
Front Axle - Pfa - 400659 - 401023
Differential Carrier - Pfa - 400659 - 401023
Pivot And Spindle - Pfa - 400659 - 400023
Planetary Wheel End - Pfa - 400659 - 401023
Differential Carrier, Ring Gear And Pinion - Pfa - 401024
Limit Slip Differential - Pfa - 401024 And Later
Axle Housing, Axle Shaft And Tie Rod - Pfa - 401024 -
Joint Housing And Steering Arm - Pfa - 401024 -
Wheel Hub, Spindle And Planetary Drive - Pfa - 401024 -
Lights
Head Lamp
Flood Lamp
Tail Lamp
Warning Lamp
Auxiliary Light Connector
Ashtray & Lighter
Instrument Panel - Model 185 - 400659 Thru 401045
Instrument Panel - Model 160 And 185 - 401046
Rh Instrument Panel Gauges, Warning Lights And Switches
Lh And Lower Instrument Panel Switches, Controls And Circuit
Seat And Suspension
Seat Suspension
Air Ride Seat And Suspension
Hood And Side Panels
Grille
Toolbox
Front Frame Weights
Cab Body
Cab Headliner And Foam Panels
Cab Radio And Speaker Plates And Grilles
Cab Door And Windows
Cab Glass Specifications
Windshield Wiper
Cab Mounting
Cab Electrical System
Cab Heater
Cab Blower
Cab Air Conditioner - Condenser And Evaporator
Cab Air Conditioner Compressor, Clutch And Pulley
Air Conditioner Compressor Clutch
