White Articulated Tractor A4T 1400 A4T 1600 Series Parts Catalog PCR2214M
Brand: White
Type of Machine: Articulated Tractor
Model:
White A4T 1400 Series Tractor
White A4T 1600 Series Tractor
Part Number: PCR2214M
Number of Pages: 199 Pages
Crankcase (For 504b-6 Lp Gas Engine)
Crankcase (For D504-6 Diesel Engine)
Crankcase Group I (For D585-6 Diesel Engine)
Crankcase Group Ii (For D585-6 Diesel Engine)
Gear Case And Water Pump
Base Pan, Oil Filter And Oil Pump Group 1
504b-6 And D585-6 Base Pan And Oil Filter Group Ii
Oil Pump Group 2 (Used On 504b-6 Lp Gas Engines)
Cylinder Block, Cylinder Head And Breather
Cylinder Block, Cylinder Head, Energy Cells And Breather
Camshaft, Rocker Arms, Valves, Push Rods, And Tappets
Camshaft, Rocker Arms, Valves, Push Rods And Tappets
Crankshaft, Connecting Rod Pistons, Rings And Flywheel
Crankshaft, Connecting Rod, Pistons, Rings And Flywheel
Gas Manifold And Muffler (For 504b-6 And D504a-6 Engine)
Manifolds And Muffler (For D585-6 Diesel Engine)
Air Cleaner (For D504a-6 And 504b-6 Engines)
Air Cleaner (For D585-6 Diesel Engine)
Carburetor And Regualtor (Lp Gas)
Lp Gas Fuel Tank, Valves And Filter
Roosa-Master Fuel Injection Pump (For D504-6 Diesel Engines)
Turbocharger (For D504a-6 Engines)
Roosa-Master Fuel Injection Pump (For D585-6 Diesel Engines)
Diesel Fuel Tank And Filter
Governor And Control Rod - Lp Gas
Distributor, Ignition Coil, Cables And Spark Plugs
Throttle Controls
Fan And Hub
Water Manifolds And Thermostat
Grille And Hood (Group I)
Grille And Hood (Group 2)
Instrument Panel And Instruments
Alternator And Starting Motor
Lamps And Wires
Transmission Case
Clutch
Transmission Gears And Shafts
Gear Shifting
Drop Box
Drop Box Shifting And Linkage
Drive Shafts
Differential Front Wheel Drive
Differential (Rear Wheel Drive)
Drive Axles And Bull Gears (Front And Rear Drive)
Drive Wheels (Group I)
Drive Wheels (Group 2)
Brake Pedal And Master Cylinder
Brakes
Steering Wheel, Orbitol Control Cylinders And Lines
Power Steering Pump, Oil Cooler And Lines
Power Steering Pump
Seat And Underride
Wheeel Guard And Hand Railing
Pto Disconnect Drive Shafts And Pump
Pto Dropbox
Pto Drive Shafts
Rear Power Take-Off (1000 Rpm)
Lube Pump - Rear
Closed Center Hydraulic Pump
Hydraulic Reservoir And Lines (Group I)
Closed Center And Type G Hydraulic Reservoir And Lines
Closed Center Valve And Lever Housing
Closed Center Valve Linkage
Auxiliary And 3-Point Hitch Control Levers
Closed Center Auxiliary Valve And Couplers
Auxiliary Valves (Closed Center Hydraulic System)
Control Valve And Couplers (Type G Hydraulic System)
Control Valve And Couplers (Type G Hydraulic System) - Control Valve And Couplers (Type G Hydraulic System)
Control Valve (Type G Hydraulic System)
Hydraulic Cylinder
3-Point Hitch (Common Parts)
3-Point Hitch
3-Point Hitch Cylinders And Lines
Semi-Mounted Plow Hitch (Quick Coupler)
20 Deg. Swinging Drawbar For 3-Point Hitch
30 Deg. Swinging Drawbar
Frame
Parts For Factory Installed Cab
Brand: White
Model:
Throttle Controls
Fan And Hub
Lamps And Wires
Transmission Case
Clutch
Gear Shifting
Drop Box
Drive Shafts
Brakes
Power Steering Pump
Seat And Underride
Pto Dropbox
Pto Drive Shafts
Lube Pump - Rear
Hydraulic Cylinder
3-Point Hitch
Frame
