[WebTIC_RU] CLAAS WebTIC Offline RU_Russian 4.0.5 11.2021 Operator, Repair Manual & Service Documentation DVD
Size: 50.8 Gb (Winrar Files)
Document Language: Russian
Type of vehicle: Agricultural
Type of software: CLAAS WEBTIC Repair Manual, Assembly Instruction, Time Schedule, Miscellaneous, Technical System, Training Document, Operator Manual.
Make: Claas Agricultural
Amount of DVD: 1 DVD
Version: WebTIC Offline 4.0.5
Database updated: November 2021
Date: 11.2021
OS: Windows 7, Windows 8, Windows 10 32 & 64 bit(Tested on window 10 pro 1607 64bit & Window 7 ultimate 64bit)
Print Functions: Present
Installation: Multiple PCs
CLAAS WebTIC Offline DVD gives you easy and quick access to technical information for CLAAS machines. All documents, instructions, catalogs for this equipment will be at your fingertips, that is, they will be freely available on your computer. This will provide you with offline access to documents and information at any time. Namely, you can familiarize yourself with this information (Document type):
Date: 11.2021
- CLAAS Parts DOC 2018 FULL
- CLAAS WebTIC Offline [02.2020] Repair and Service Documentation
- CLAAS WebTIC Offline [11.2020] Operator Manual & Repair Manual and Service Documentation
