James Rodrigues
169
1,658,231
[WebTIC_RU] CLAAS WebTIC Offline RU_Russian 4.0.5 11.2021 Operator, Repair Manual & Service Documentation DVD
Size: 50.8 Gb (Winrar Files)
Document Language: Russian
Type of vehicle: Agricultural
Type of software: CLAAS WEBTIC Repair Manual, Assembly Instruction, Time Schedule, Miscellaneous, Technical System, Training Document, Operator Manual.
Make: Claas Agricultural
Region: WorldWide
Amount of DVD: 1 DVD
Version: WebTIC Offline 4.0.5
Database updated: November 2021
Date: 11.2021
OS: Windows 7, Windows 8, Windows 10 32 & 64 bit(Tested on window 10 pro 1607 64bit & Window 7 ultimate 64bit)
Print Functions: Present
Instruction: Present
Medicine: Present
Installation: Multiple PCs
High-Speed Link Download
CLAAS WebTIC Offline DVD gives you easy and quick access to technical information for CLAAS machines. All documents, instructions, catalogs for this equipment will be at your fingertips, that is, they will be freely available on your computer. This will provide you with offline access to documents and information at any time. Namely, you can familiarize yourself with this information (Document type):
Fitting instructions
Operators manual
Repair manual
Time schedule
Miscellaneous
Technical system
Training document
Conversion instructions
Assembly instructions
Combines
Forage Harvester
Tractors
Balers
Mowers
Tedders
Swathers
Loader Wagons
Telehandlers
Wheel Loaders
EASY
Miscellaneous
