Ricardoman
15
1,908
Vims pc 2013a
Download this document, you need 600 Gallons
Hi I'm Ricardo from Chile, I speak Spanish.
this is my first contribution, just change the format of the database. this does not limit
note: I need someone to help me with "caterpillar factory password" urgent need that software. for versions 2009B, 2011A or 2014A, I need help please
VIMSpc 2013A – Release Notes
August 7, 2013
Versions Shipped with this release
* VIMSpc version: 2013A build 4.7.1.0
* Database version: 3.0.5
* Master database version: 13.0.0
New Software Features and Updates
New VIMSpc software is now available. VIMSpc version 2013A contains functionalities of the following existing software products and serves as replacement for them.
* All previous versions of VIMSpc, including 2011A and 2009B.
* VIMS 3G Connect
* VIMS Supervisor
* TPMpc
* PCSpc
The table below compare capability to connect to various hardware platforms between VIMSpc 2013A and 2011A versions.
Compatible ECM VIMSpc 2013A VIMSpc 2011A
A5N2 Yes No
A4N4 Yes Yes
523 (A4G4) Yes Yes
VIMS ABL2M Yes Yes
VIMS 68K Yes Yes
TPM ABL1M Yes No
TPM Legacy Yes No
PCS A4M3 Yes No
PCS Legacy Yes No
The following list contains the enhancements and modifications of VIMSpc version 2013A:
* Includes functionality of VIMSpc 2011A, 2009B, VIMS 3G Connect, VIMS Supervisor, PCSpc, and TPMpc.
* Support VIMS A5, A4, 522, 523, ABL2M, and 68K hardware platforms.
* Uses IBM DB2 database instead of Microsoft Access which allows much more data storage (limited by size of hard drive).
* Improved the speed of data merge.
* Improved Ethernet connection.
* Fixed bugs found in 2011A version.
Installation Requirements
You must be an administrator to install VIMSpc. All air cards should be removed and VPN turned off prior to installation and when running VIMSpc while connecting to VIMS3G modules.
System Requirements
To successfully run VIMSpc, the following computer hardware, communication hardware and cables, and software are needed:
* IBM® PC compatible with Pentium 1 GHz processor or greater
* 1 GB RAM
* 500 MB of available hard drive space
* Supported OS: Windows XP, Vista, and Windows 7, 32-bit and 64-bit
* RS232 port with 16550AF UART (or compatible) OR USB 1.1 or 2.0 port with a USB to Serial Port adapter (P/N: 370-8059) for use with VIMS Download Cable (P/N: 127-9797) for VIMS ABL & 68K hardware
* Ethernet port for use with the VIMS 3G Download Cable (P/N: 305-5528) for VIMS 3G hardware
* Adobe PDF reader
Support of VIMSpc 2011A
For assistance to the dealer, contact the Condition Monitoring Product Support Hotline following numbers:
1-800-290-1808 within US and Canada
309-675-6229 outside US and Canada
The hours of operation for the Condition Monitoring Product Support Hotline are 8:00 AM to 4:30 PM Central Time Monday through Friday.
For further assistance with this software, contact your Caterpillar dealer.
Ricardoman
15
1,908
#3
Thank you for your response. Yes I understand SIS, I work with it daily. What I do need help with is modifying ECM hours, such as changing them to zero. For this reason I need help with "Caterpiller factory password" software. Thanks!
GSA10R
1
84
#4
check your PM
GSA10R
1
84
#5
PLEASE HELP! :confused:WHAT FORMAT DO WE CHANGE FILES TO? They are in .ISO format what do we change them to to Install VIMS correctly:confused:, MASTER can you please help on this! THANK YOU!
Master
Cleaner
720
4,083,303
#6
Dear you, you can share how to intall for people. Thanks.
GSA10R
1
84
#8
Dear you, please find " Read me" inside folder to see how to install.
Master there is no "READ ME" in files i downloaded the 1-10 Files and nonthing just a "00#" white file.. ive tried extracting it w/ .rar and nonthing can you PM me the ReadMe document and a image of how its supposed to appear after downloaded? Thanks
Master
Cleaner
720
4,083,303
#9
Dear you, after you download 10 files please extrect those file and copy file .001,.002,.003... into a folder. After you use a software "The Fastest File Splitter and Joiner" in this topic.
After you download and set up this soft. You join all file into a winrar and use. Good luck.
