Auto
Driver
625
1,789,856
UAZ FAULT CODES
UAZ FAULT CODES
Deciphering the code error code
0030 DK1. Fault heater circuit
0031 DK1. Open or short to "weight" the heater circuit
0032 DK1. Short circuit to "bortseti" heater circuit
0036 TPC2. Fault heater circuit
0037 TPC2. Open or short to "weight" the heater circuit
0038 TPC2. Short circuit to "bortseti" heater circuit
0101 DFID. The signal is out of range
0102 DFID. Low signal
0103 DFID. High signal
0112 DTV. Low signal
0113 DTV. High signal
0116 DTOZH. The signal is out of range
0117 DTOZH. Low signal
0118 DTOZH. High signal
0122 Low signal in the sensor circuit 1 throttle
0123 High signal in the sensor circuit 1 throttle
0130 DK1. Fault signal circuit
0131 DK1. Low signal
0132 DK1. High signal
0133 DK1. Slow response to a change in composition
0134 DK1. Loss of signal activity or open circuit
0135 DK1. Fault heater circuit
0136 TPC2. Fault signal circuit
0137 TPC2. Low signal
0138 TPC2. High signal
0140 TPC2. Loss of signal activity or open circuit
0141 TPC2. Fault heater circuit
0171 fuel system too "poor" when its maximum enrichment
0172 fuel system too "rich" when its maximum depletion
0201 Circuit Malfunction 1 injector control
0202 Faulty injector control circuit 2
0203 Faulty injector control circuit 3
0204 Circuit Fault injector control 4
0222 Low signal to the sensor circuit 2 throttle position
0223 High signal in the sensor circuit 2 throttle position
0261 Open or short circuit on "weight" injector control circuit 1
0262 Short circuit to "bortseti" injector driver circuit 1
0264 Open or short circuit on "weight" injector control circuit 2
0265 Short circuit to "bortseti" injector driver circuit 2
0267 Open or short circuit on "weight" injector control circuit 3
0268 Short circuit to "bortseti" chain injector 3
0270 Open or short circuit on "weight" of the control circuit nozzle 4
0271 Short circuit to "bortseti" chain injector 4
0300 Random / multiple misfires
0301 misfires in cylinder 1
0302 misfires in cylinders 2
0303 misfires in cylinder 3
0304 misfires in cylinder 4
0327 Low signal circuit knock sensor
0335 No signal or circuit failure crankshaft position sensor
0340 Sensor Circuit Malfunction of the camshaft
0420 Efficiency converter lower allowable level
0443 Malfunction or open circuit control valve canister purge
0444 Open or short circuit on "weight" of the control circuit canister purge valve
0445 Short circuit to "bortseti" control circuit canister purge valve
0480 Relay Control Circuit Malfunction fan 1
0481 Fault relay control circuit assembly 2
0500 No Signal Vehicle Speed Sensor
0504 Incorrect signal switches the brake pedal
0560 System voltage is below the threshold of work
0562 Low-board voltage
0563 High voltage onboard network
0605 Faulty flash memory controller (checksum error)
0606 Controller Fault
0627 Open relay control circuit elektrobenzonasosa
0628 Open or short circuit on "weight" relay control circuit elektrobenzonasosa
0629 Short circuit to "bortseti" relay control circuit elektrobenzonasosa
0645 Fault relay control circuit compressor clutch
0646 Open or short circuit on "weight" chain compressor clutch relay
0647 KZ "bortseti" chain compressor clutch relay
0691 Open or short circuit on "weight" relay control circuit fan 1
0692 Short circuit to "bortseti" fan relay control circuit 1
0693 Open or short circuit on "weight" the blower motor relay control circuit 2
0694 Short circuit to "bortseti" fan relay control circuit 2
1335 Unreliable throttle position
1336 The discrepancy between the sensors 1 and 2 of the throttle position
1388 acceleration pedal position is out of range
1389 Engine speed is out of range
1390 Irreversible limit fuel injection due to the failure of systems
1391 Error monitoring program engine systems
1545 Throttle position is out of range
1558 initial throttle position is out of range
1559 Unreliable mass flow rate of air through the throttle
1564 Violation of adaptation throttle due to low voltage
1570 No response from the immobilizer or link fault,
1571 We used an unregistered electronic key
1572 Open circuit or malfunction transceiver antenna immobilizer
1573 Internal fault block immobilizer
1574 An attempt to unlock the immobilizer
1575 alarm controller is locked
1578 unreliable results retraining throttle
1579 Abort adaptation throttle due to external conditions
Fault-volatile memory 1603 (EEPROM) controller
2106 Faulty power channel throttle
2122 Low signal in the sensor circuit 1 pedal acceleration
2123 High signal in the sensor circuit 1 pedal acceleration
2127 Low signal in the sensor circuit 2 pedal acceleration
2128 High signal in the sensor circuit 2 pedal acceleration
2135 The discrepancy between the sensors 1 and 2 of the throttle position
2138 The discrepancy between the sensors 1 and 2 of the pedal acceleration
2187 fuel system drifts from "average" to "poor" areas on the twentieth
2188 fuel system drifts from "average" to "rich" area on the twentieth
2195 No coincidence signals of oxygen sensors 1 and 2
2270 Signal oxygen sensor 2 is in the "poor"
2271 Signal oxygen sensor 2 is in the "rich"
C001 Fault information Fault CAN-bus CAN-bus information
