700,339
Tigercat FPT Engine N67 Tier 2 Non-Certified Troubleshooting Manual 74311AENG
Brand: Tigercat, FPT
Type of Manual: Troubleshooting Manual
Model: Tigercat FPT N67 Tier 2 Non-Certified Engine
Part Number: 74311AENG
Publication Date: 2024
Number of Pages: 344 Pages
Section 1 - Introduction
Diagnostic Tools (PT-Box and LogOn)
Engine Electronic Control Unit (ECU) Connections, Tier 2/Non-Certified
ECU Soft Reset
Section 2 - Engine
Visually Check the Crankcase System
Cylinder Compression Test
Check For External Fuel Leakage in the Engine Area
Fuel High Pressure Relief Test
Check Turbo System
Check Intake Air System
Check the Charge Air System and Air Delivery Pipes
Section 3 - Injection
Fuel Pressure Check
Check High-Pressure Pump Backflow Pressure
Fuel Pump Leakage Test
Check High-Pressure Pump Backflow Rate
Check Fuel Rail Pressure Adjustment
Check Fuel Rail Pressure During Cranking
Check Intake Air Pressure and Temperature Sensor
Check Suction Pressure Between Tank and Pre-Filter
Check Suction Pressure After Pre-Filter
Check Water In Fuel Sensor Plausibility
Check External Fuel Leakage Of High-Pressure System
Injector Cylinder Cut Out Test
Fuel Injector Leakage Test
Section 5 - Electrical Components
Check Grid Heater Activation
Check Camshaft and Crankshaft Synchronization
Check the Engine Speed Adjustment
Check the ECU Power Supply
Check the ECU Parameters Reading
Section 6 - Fault Code Troubleshooting
SPN-4371-31 / DTC-1113-1F
SPN-4421-31 / DTC-1145-1F
SPN-4445-31 / DTC-115D-1F
SPN-4579-31 / DTC-11E3-1F
SPN-4645-31 / DTC-1225-1F
SPN-4701-31 / DTC-125D-1F
SPN-4961-31 / DTC-1361-1F
SPN-4980-31 / DTC-1374-1F
SPN-5060-31 / DTC-13C4-1F
SPN-5157-31 / DTC-1425-1F
SPN-5477-31 / DTC-1565-1F
SPN-5686-31 / DTC-1636-1F
SPN-5725-31 / DTC-165D-1F
SPN-5957-31 / DTC-1745-1F
SPN-6245-31 / DTC-1865-1F
SPN-6355-31 / DTC-18D3-1F
SPN-6677-31 / DTC-1A15-1F
SPN-7123-31 / DTC-1BD3-1F
SPN-7189-31 / DTC-1C15-1F
SPN-7524-31 / DTC-1D64-1F
SPN-7557-31 / DTC-1D85-1F
SPN-8723-31 / DTC-2213-1F
SPN-8805-31 / DTC-2265-1F
SPN-8931-31 / DTC-22E3-1F
SPN-8997-31 / DTC-2325-1F
SPN-9053-31 / DTC-235D-1F
SPN-9309-31 / DTC-245D-1F
SPN-9313-31 / DTC-2461-1F
SPN-9332-31 / DTC-2474-1F
SPN-9412-31 / DTC-24C4-1F
SPN-9509-31 / DTC-2525-1F
SPN-9939-31 / DTC-26D3-1F
SPN-10077-31 / DTC-275D-1F
SPN-10085-31 / DTC-2765-1F
SPN-10707-31 / DTC-29D3-1F
SPN-11062-31 / DTC-2B36-1F
SPN-11475-31 / DTC-2CD3-1F
SPN-11541-31 / DTC-2D15-1F
SPN-11876-31 / DTC-2E64-1F
SPN-13074-31 / DTC-3312-1F
SPN-15205-31 / DTC-3B65-1F
SPN-15461-31 / DTC-3C65-1F
SPN-16658-31 / DTC-4112-1F
SPN-16677-31 / DTC-4125-1F
SPN-16914-31 / DTC-4212-1F
SPN-17426-31 / DTC-4412-1F
SPN-17429-31 / DTC-4415-1F
SPN-17509-31 / DTC-4465-1F
SPN-17682-31 / DTC-4512-1F
SPN-19332-31 / DTC-4B84-1F
SPN-19588-31 / DTC-4C84-1F
SPN-21077-31 / DTC-5255-1F
SPN-21270-31 / DTC-5316-1F
SPN-21526-31 / DTC-5416-1F
SPN-21782-31 / DTC-5516-1F
SPN-22036-31 / DTC-5614-1F
SPN-22038-31 / DTC-5616-1F
SPN-22294-31 / DTC-5716-1F
SPN-22550-31 / DTC-5816-1F
SPN-25126-31 / DTC-6226-1F
SPN-25382-31 / DTC-6326-1F
SPN-25638-31 / DTC-6426-1F
SPN-25685-31 / DTC-6455-1F
SPN-25725-31 / DTC-647D-1F
SPN-25894-31 / DTC-6526-1F
SPN-26150-31 / DTC-6626-1F
SPN-26197-31 / DTC-6655-1F
SPN-26237-31 / DTC-667D-1F
SPN-26406-31 / DTC-6726-1F
SPN-26749-31 / DTC-687D-1F
SPN-27156-31 / DTC-6A14-1F
SPN-28950-31 / DTC-7116-1F
SPN-29206-31 / DTC-7216-1F
SPN-30037-31 / DTC-7555-1F
SPN-30077-31 / DTC-757D-1F
SPN-30549-31 / DTC-7755-1F
SPN-30589-31 / DTC-777D-1F
SPN-31101-31 / DTC-797D-1F
SPN-31764-31 / DTC-7C14-1F
SPN-33621-31 / DTC-8355-1F
SPN-34836-31 / DTC-8814-1F
SPN-37147-31 / DTC-911B-1F
SPN-37323-31 / DTC-91CB-1F
SPN-37579-31 / DTC-92CB-1F
SPN-37739-31 / DTC-936B-1F
SPN-37835-31 / DTC-93CB-1F
SPN-38091-31 / DTC-94CB-1F
SPN-38139-31 / DTC-94FB-1F
SPN-38171-31 / DTC-951B-1F
SPN-38251-31 / DTC-956B-1F
SPN-39099-31 / DTC-98BB-1F
SPN-39355-31/ DTC-99BB-1F
SPN-39803-31 / DTC-9B7B-1F
SPN-57638-31 / DTC-E126-1F
SPN-57661-31 / DTC-E13D-1F
SPN-57709-31 / DTC-E16D-1F
SPN-57821-31 / DTC-E1DD-1F
SPN-57853-31 / DTC-E1FD-1F
SPN-57885-31 / DTC-E21D-1F
SPN-57901-31 / DTC-E22D-1F
SPN-57917-31 / DTC-E23D-1F
SPN-57965-31 / DTC-E26D-1F
SPN-58077-31 / DTC-E2DD-1F
SPN-58141-31 / DTC-E31D-1F
SPN-58157-31 / DTC-E32D-1F
SPN-58166-31 / DTC-E336-1F
SPN-58173-31 / DTC-E33D-1F
SPN-58221-31 / DTC-E36D-1F
SPN-58333-31 / DTC-E3DD-1F
SPN-58397-31 / DTC-E41D-1F
SPN-58413-31 / DTC-E42D-1F
SPN-58429-31 / DTC-E43D-1F
SPN-58477-31 / DTC-E46D-1F
SPN-58589-31 / DTC-E4DD-1F
SPN-58653-31 / DTC-E51D-1F
SPN-58669-31 / DTC-E52D-1F
SPN-58678-31 / DTC-E536-1F
SPN-58685-31 / DTC-E53D-1F
SPN-58717-31 / DTC-E55D-1F
SPN-58733-31 / DTC-E56D-1F
SPN-58845-31 / DTC-E5DD-1F
SPN-58909-31 / DTC-E61D-1F
SPN-58925-31 / DTC-E62D-1F
SPN-58941-31 / DTC-E36D-1F
SPN-59037-31 / DTC-E69D-1F
SPN-59101-31 / DTC-E6DD-1F
SPN-59165-31 / DTC-E71D-1F
SPN-59181-31 / DTC-E72D-1F
SPN-59197-31 / DTC-E73D-1F
SPN-59293-31 / DTC-E79D-1F
SPN-59357-31 / DTC-E7DD-1F
SPN-59410-31 / DTC-E812-1F
SPN-59421-31 / DTC-E81D-1F
SPN-59437-31 / DTC-E82D-1F
SPN-59453-31 / DTC-E83D-1F
SPN-59613-31 / DTC-E8DD-1F
SPN-59677-31 / DTC-E91D-1F
SPN-59693-31 / DTC-E92D-1F
SPN-59869-31 / DTC-E9DD-1F
SPN-59933-31 / DTC-EA1D-1F
SPN-60125-31 / DTC-EADD-1F
SPN-60189-31 / DTC-EB1D-1F
SPN-60381-31 / DTC-EBDD-1F
SPN-60470-31 / DTC-EC36-1F
SPN-60637-31 / DTC-ECDD-1F
SPN-60701-31 / DTC-ED1D-1F
SPN-60717-31 / DTC-ED2D-1F
SPN-60726-31 / DTC-ED36-1F
SPN-60957-31 / DTC-EE1D-1F
SPN-60982-31 / DTC-EE36-1F
SPN-61858-31 / DTC-F1A2-1F
SPN-61935-31 / DTC-F1EF-1F
SPN-62021-31 / DTC-F245-1F
SPN-62191-31 / DTC-F2EF-1F
SPN-62277-31 / DTC-F345-1F
SPN-62370-31 / DTC-F3A2-1F
SPN-62447-31 / DTC-F3EF-1F
SPN-62533-31 / DTC-F445-1F
SPN-62626-31 / DTC-F4A2-1F
SPN-62703-31 / DTC-F4EF-1F
SPN-62755-31 / DTC-F523-1F
SPN-62817-31 / DTC-F561-1F
SPN-62882-31 / DTC-F5A2-1F
SPN-63011-31 / DTC-F623-1F
SPN-63138-31 / DTC-F6A2-1F
SPN-63394-31 / DTC-F7A2-1F
SPN-63471-31 / DTC-F7EF-1F
SPN-63542-31 / DTC-F836-1F
SPN-63650-31 / DTC-F8A2-1F
SPN-63798-31 / DTC-F936-1F
SPN-64239-31 / DTC-FAEF-1F
Index
