Tigercat FPT Engine N67 Tier 2 Non-Certified Troubleshooting Manual 74311AENG
Brand: Tigercat, FPT
Type of Manual: Troubleshooting Manual
Model: Tigercat FPT N67 Tier 2 Non-Certified Engine
Part Number: 74311AENG
Publication Date: 2024
Number of Pages: 344 Pages
Section 1 - Introduction
Diagnostic Tools (PT-Box and LogOn)
Engine Electronic Control Unit (ECU) Connections, Tier 2/Non-Certified
ECU Soft Reset
Section 2 - Engine
Visually Check the Crankcase System
Cylinder Compression Test
Check For External Fuel Leakage in the Engine Area
Fuel High Pressure Relief Test
Check Turbo System
Check Intake Air System
Check the Charge Air System and Air Delivery Pipes
Section 3 - Injection
Fuel Pressure Check
Check High-Pressure Pump Backflow Pressure
Fuel Pump Leakage Test
Check High-Pressure Pump Backflow Rate
Check Fuel Rail Pressure Adjustment
Check Fuel Rail Pressure During Cranking
Check Intake Air Pressure and Temperature Sensor
Check Suction Pressure Between Tank and Pre-Filter
Check Suction Pressure After Pre-Filter
Check Water In Fuel Sensor Plausibility
Check External Fuel Leakage Of High-Pressure System
Injector Cylinder Cut Out Test
Fuel Injector Leakage Test
Section 5 - Electrical Components
Check Grid Heater Activation
Check Camshaft and Crankshaft Synchronization
Check the Engine Speed Adjustment
Check the ECU Power Supply
Check the ECU Parameters Reading
Section 6 - Fault Code Troubleshooting
SPN-4371-31 / DTC-1113-1F
SPN-4421-31 / DTC-1145-1F
SPN-4445-31 / DTC-115D-1F
SPN-4579-31 / DTC-11E3-1F
SPN-4645-31 / DTC-1225-1F
SPN-4701-31 / DTC-125D-1F
SPN-4961-31 / DTC-1361-1F
SPN-4980-31 / DTC-1374-1F
SPN-5060-31 / DTC-13C4-1F
SPN-5157-31 / DTC-1425-1F
SPN-5477-31 / DTC-1565-1F
SPN-5686-31 / DTC-1636-1F
SPN-5725-31 / DTC-165D-1F
SPN-5957-31 / DTC-1745-1F
SPN-6245-31 / DTC-1865-1F
SPN-6355-31 / DTC-18D3-1F
SPN-6677-31 / DTC-1A15-1F
SPN-7123-31 / DTC-1BD3-1F
SPN-7189-31 / DTC-1C15-1F
SPN-7524-31 / DTC-1D64-1F
SPN-7557-31 / DTC-1D85-1F
SPN-8723-31 / DTC-2213-1F
SPN-8805-31 / DTC-2265-1F
SPN-8931-31 / DTC-22E3-1F
SPN-8997-31 / DTC-2325-1F
SPN-9053-31 / DTC-235D-1F
SPN-9309-31 / DTC-245D-1F
SPN-9313-31 / DTC-2461-1F
SPN-9332-31 / DTC-2474-1F
SPN-9412-31 / DTC-24C4-1F
SPN-9509-31 / DTC-2525-1F
SPN-9939-31 / DTC-26D3-1F
SPN-10077-31 / DTC-275D-1F
SPN-10085-31 / DTC-2765-1F
SPN-10707-31 / DTC-29D3-1F
SPN-11062-31 / DTC-2B36-1F
SPN-11475-31 / DTC-2CD3-1F
SPN-11541-31 / DTC-2D15-1F
SPN-11876-31 / DTC-2E64-1F
SPN-13074-31 / DTC-3312-1F
SPN-15205-31 / DTC-3B65-1F
SPN-15461-31 / DTC-3C65-1F
SPN-16658-31 / DTC-4112-1F
SPN-16677-31 / DTC-4125-1F
SPN-16914-31 / DTC-4212-1F
SPN-17426-31 / DTC-4412-1F
SPN-17429-31 / DTC-4415-1F
SPN-17509-31 / DTC-4465-1F
SPN-17682-31 / DTC-4512-1F
SPN-19332-31 / DTC-4B84-1F
SPN-19588-31 / DTC-4C84-1F
SPN-21077-31 / DTC-5255-1F
SPN-21270-31 / DTC-5316-1F
SPN-21526-31 / DTC-5416-1F
SPN-21782-31 / DTC-5516-1F
SPN-22036-31 / DTC-5614-1F
SPN-22038-31 / DTC-5616-1F
SPN-22294-31 / DTC-5716-1F
SPN-22550-31 / DTC-5816-1F
SPN-25126-31 / DTC-6226-1F
SPN-25382-31 / DTC-6326-1F
SPN-25638-31 / DTC-6426-1F
SPN-25685-31 / DTC-6455-1F
SPN-25725-31 / DTC-647D-1F
SPN-25894-31 / DTC-6526-1F
SPN-26150-31 / DTC-6626-1F
SPN-26197-31 / DTC-6655-1F
SPN-26237-31 / DTC-667D-1F
SPN-26406-31 / DTC-6726-1F
SPN-26749-31 / DTC-687D-1F
SPN-27156-31 / DTC-6A14-1F
SPN-28950-31 / DTC-7116-1F
SPN-29206-31 / DTC-7216-1F
SPN-30037-31 / DTC-7555-1F
SPN-30077-31 / DTC-757D-1F
SPN-30549-31 / DTC-7755-1F
SPN-30589-31 / DTC-777D-1F
SPN-31101-31 / DTC-797D-1F
SPN-31764-31 / DTC-7C14-1F
SPN-33621-31 / DTC-8355-1F
SPN-34836-31 / DTC-8814-1F
SPN-37147-31 / DTC-911B-1F
SPN-37323-31 / DTC-91CB-1F
SPN-37579-31 / DTC-92CB-1F
SPN-37739-31 / DTC-936B-1F
SPN-37835-31 / DTC-93CB-1F
SPN-38091-31 / DTC-94CB-1F
SPN-38139-31 / DTC-94FB-1F
SPN-38171-31 / DTC-951B-1F
SPN-38251-31 / DTC-956B-1F
SPN-39099-31 / DTC-98BB-1F
SPN-39355-31/ DTC-99BB-1F
SPN-39803-31 / DTC-9B7B-1F
SPN-57638-31 / DTC-E126-1F
SPN-57661-31 / DTC-E13D-1F
SPN-57709-31 / DTC-E16D-1F
SPN-57821-31 / DTC-E1DD-1F
SPN-57853-31 / DTC-E1FD-1F
SPN-57885-31 / DTC-E21D-1F
SPN-57901-31 / DTC-E22D-1F
SPN-57917-31 / DTC-E23D-1F
SPN-57965-31 / DTC-E26D-1F
SPN-58077-31 / DTC-E2DD-1F
SPN-58141-31 / DTC-E31D-1F
SPN-58157-31 / DTC-E32D-1F
SPN-58166-31 / DTC-E336-1F
SPN-58173-31 / DTC-E33D-1F
SPN-58221-31 / DTC-E36D-1F
SPN-58333-31 / DTC-E3DD-1F
SPN-58397-31 / DTC-E41D-1F
SPN-58413-31 / DTC-E42D-1F
SPN-58429-31 / DTC-E43D-1F
SPN-58477-31 / DTC-E46D-1F
SPN-58589-31 / DTC-E4DD-1F
SPN-58653-31 / DTC-E51D-1F
SPN-58669-31 / DTC-E52D-1F
SPN-58678-31 / DTC-E536-1F
SPN-58685-31 / DTC-E53D-1F
SPN-58717-31 / DTC-E55D-1F
SPN-58733-31 / DTC-E56D-1F
SPN-58845-31 / DTC-E5DD-1F
SPN-58909-31 / DTC-E61D-1F
SPN-58925-31 / DTC-E62D-1F
SPN-58941-31 / DTC-E36D-1F
SPN-59037-31 / DTC-E69D-1F
SPN-59101-31 / DTC-E6DD-1F
SPN-59165-31 / DTC-E71D-1F
SPN-59181-31 / DTC-E72D-1F
SPN-59197-31 / DTC-E73D-1F
SPN-59293-31 / DTC-E79D-1F
SPN-59357-31 / DTC-E7DD-1F
SPN-59410-31 / DTC-E812-1F
SPN-59421-31 / DTC-E81D-1F
SPN-59437-31 / DTC-E82D-1F
SPN-59453-31 / DTC-E83D-1F
SPN-59613-31 / DTC-E8DD-1F
SPN-59677-31 / DTC-E91D-1F
SPN-59693-31 / DTC-E92D-1F
SPN-59869-31 / DTC-E9DD-1F
SPN-59933-31 / DTC-EA1D-1F
SPN-60125-31 / DTC-EADD-1F
SPN-60189-31 / DTC-EB1D-1F
SPN-60381-31 / DTC-EBDD-1F
SPN-60470-31 / DTC-EC36-1F
SPN-60637-31 / DTC-ECDD-1F
SPN-60701-31 / DTC-ED1D-1F
SPN-60717-31 / DTC-ED2D-1F
SPN-60726-31 / DTC-ED36-1F
SPN-60957-31 / DTC-EE1D-1F
SPN-60982-31 / DTC-EE36-1F
SPN-61858-31 / DTC-F1A2-1F
SPN-61935-31 / DTC-F1EF-1F
SPN-62021-31 / DTC-F245-1F
SPN-62191-31 / DTC-F2EF-1F
SPN-62277-31 / DTC-F345-1F
SPN-62370-31 / DTC-F3A2-1F
SPN-62447-31 / DTC-F3EF-1F
SPN-62533-31 / DTC-F445-1F
SPN-62626-31 / DTC-F4A2-1F
SPN-62703-31 / DTC-F4EF-1F
SPN-62755-31 / DTC-F523-1F
SPN-62817-31 / DTC-F561-1F
SPN-62882-31 / DTC-F5A2-1F
SPN-63011-31 / DTC-F623-1F
SPN-63138-31 / DTC-F6A2-1F
SPN-63394-31 / DTC-F7A2-1F
SPN-63471-31 / DTC-F7EF-1F
SPN-63542-31 / DTC-F836-1F
SPN-63650-31 / DTC-F8A2-1F
SPN-63798-31 / DTC-F936-1F
SPN-64239-31 / DTC-FAEF-1F
Index
ECU Soft Reset
Section 2 - Engine
Check Turbo System
Fuel Pressure Check
Index
- Tigercat 620D 630D Skidder Operator's & Service Manual
- Tigercat 630 Skidder Operator's & Service Manual
- Tigercat 620E 630E 635E Skidder Operator's Manual
- Tigercat 234 Loader Operator's Manual, Service Manual
- Tigercat 620C Skidder Operator's & Service Manual
- Tigercat 860C 870C L870C Feller Buncher Operator's & Service Manual
- Tigercat 620 Skidder Operator's & Service Manual
- Tigercat NAF Bogie Axle Service & Repair Manual_35979A
- Tigercat Flexxaire Fan Rebuild Manual_01525
- Tigercat 1055B,1075B,1085B Forwarder Service Manual
- Tigercat 720E Feller Buncher Operator's & Service Manual
- Tigercat FPT Tier 4i N45 Fault Codes Chart
- Tigercat 1075C 1085C Forwarder Operator's Manual
- Tigercat 630B Skidder Operator's & Service Manual
- Tigercat Hultdins Super Grip SG Grapple Parts Manual_36249A
