Thermo King Technical Service Bulletins 1997
Type: pdf
Instruction Install:
Install to HDD C:\TK
For install picture - copy directory ART from CD to C:\TK\ART
Copy directory XTRAS from CD to C:\TK\BULLETIN\XTRAS
If error - copy from CD all files Catalog\*.* to C:\TK\*.*
VBRUN 3 DLL must be installed ...
copy from CD Catalog\ECS.INI to C:\Windows\ECS.INI
then replace string
[ECS]
PICTURE=c:\tk
CATALOG=c:\tk
PROGRAM=c:\tk
NOTES=c:\tk
BULLETIN=ñ:\tk
[LANGUAGE]
LANG=English
[FILESPACE]
Service Info:
Install Adobe Acrobat Reader 2.1 from directory
CD-ROM:\INSTALL\WIN\DISK1\SETUP.EXE
(previously copied to a directory on your hard drive)
either run it manually from the
C:\TK\BULLETIN\ACROREAD\ACROREAD.EXE
If you correctly copy all directory of software as describe
start ACROBAT READER
see -> menu (right) -> two buttons are highlighted
Press one button
new window with message : Which catalog with docs must be to index
and select checkbox
If you don't install Acrobat Reader 2.1
but start without install - copy Acrosrch.ini to C:\WINDOWS.
After indexing will see a search box
put in any field (Title, Subject etc.) an asterisk "*"
press the Search button
and get a full list of available service bulletins.
Next (using the Refine Search)
instead of the asterisk is better to write the name or the type
for which you are looking for information.
Type: pdf
then replace string
[ECS]
PICTURE=c:\tk
CATALOG=c:\tk
PROGRAM=c:\tk
NOTES=c:\tk
BULLETIN=ñ:\tk
[LANGUAGE]
LANG=English
[FILESPACE]
Service Info:
Press one button
and select checkbox
- Injector Commonrail Delphi
- Workshop Manual Epic Pump - Direct Injection Version
- Delphi DPA Bomba Pump Model Manual
- Thermo King Models Service Manual
- Thermo King Refrigerator SL-100 to SLXe Ferry Maintenance Manual
- ATSG Transmission Manuals
- Thermo King Truck Wiring Diagrams 2006
- Thermo King TK2.44,2.49,3.66,3.74,3.88 & 3.95 Overhaul Manual
- NAVISTAR MAXXFORCE Diagnostic & Service Manuals
- Overhaul manual for Mack E7 Engine
- Dana Spicer transmission model HR36000 4 and 6 speeds
- Actros capacitación de cajas G210-G260
- Thermo King TK270,370,376 Overhaul Manual
- Actros Caja GO 190 e 210 - 6
- CARPROG MANUALS
