Steyr Motors Marine Engine MO256H45 MO256K43 Spare Parts Catalogue
Brand: Steyr Motors
Type of Machine: Marine High Power Engine
Type of Manual: Spare Parts Catalogue
Model: Steyr Motors MO256H45 MO256K43 Marine High Power Engine
Part Number: Z011810-0
Serial Number: 68223507 and up
Date: 2011
Number of Pages: 171 Pages
MOUNT BRACKET, LIFTING EYE, GASKET SET
CRANKCASE
CRANKSHAFT, BEARING, DAMPER
FLYWHEEL, FLYWHEELHOUSING
PISTON, RINGS AND PIN, CONNECTION ROD
CAMSHAFT HOUSING, TILL -->682300699
CAMSHAFT HOUSING, FROM 682300699-->
OILPUMP, OILPIPE, OILPAN -->68224399
OILPUMP, OILPIPE, OILPAN 68224400-->
INTERCOOLER
INTERCOOLER ONLY FOR MO256K43
POWER TAKE OFF FRONT
COOLANT DISTRIBUTION PIPE, OILFILTER
EXHAUST, HEAT EXCHANGER, -->68225170
EXHAUST, HEAT EXCHANGER, 68225171-->
OILCOOLER RAW WATER
TORSIONAL COUPLING
COUPLER
FUEL PUMP, UNIT INJECTOR, PIPE
AIRFILTER, INVERSIONVALVE SOLAS
TURBOCHARGER
CONTR.SOLENOID, SENSOR CONTR.RACK POS.
FUEL FILTER
GLOW PIN
POT. ACCELE., BOOST PRESSURE SENSOR
HIGH RISER, EXHAUSTPIPE
WATERPIPE, THERMOSTAT
WATER PUMP
RAW WATER PUMP
RAW WATER PIPES
ALTERNATOR - STANDARD 14V / 90A
ALTERNATOR 28V / 80A
ALTERNATOR 28V / 55A
STARTING MOTOR
STARTING MOTOR
ENGINE HARNESS
SECURETYSYSTEM, FUSES, ECU, E-BOX
INSTRUMENTPANEL (STANDARD) TILL -->2010
INSTRUMENTPANEL (STANDARD) FROM 2010-->
INSTR.PANEL SOLAS (STANDARD) TILL -->2010
INSTR.PANEL SOLAS (STANDARD) FROM 2010-->
INSTRUMENTPANEL SOLAS 24V (TILL -->2010)
INSTRUMENTPANEL SOLAS 24V (FROM 2010-->)
SCC
SWITCH PANEL FOR DISPLAY
SWITCH PANEL FOR DISPLAY (FROM 2010-->)
PUSH BUTTON PANEL SOLAS FOR DISPLAY
EXTENSION CABLE INSTRUMENTS
TRANSMISS., MOUNTING BRACKETS, PIPES
TRANSMISSION-SHAFT, PTO-SHAFT (STEEL)
TRANSMISSION-SHAFT, PTO-SHAFT (ALU)
DRIVE ADAPTOR VOLVO STERNDRIVE
DRIVE SHAFT EXT. MERCURY STERNDRIVE
HYDRAULIC PUMP
HYDRAULIC PIPES
ENGINE PREHEATING
INTEGR. FLYWHEELGENERATOR (IFG)
PUSH BUTTON PANEL "IFG" (-->TILL 2010)
PUSH BUTTON PANEL "IFG" (FROM 2010-->)
HYBRID
HEATING UNIT, CIRCULATION PUMP
Brand: Steyr Motors
Date: 2011
CRANKCASE
INTERCOOLER
OILCOOLER RAW WATER
TORSIONAL COUPLING
COUPLER
TURBOCHARGER
FUEL FILTER
GLOW PIN
WATER PUMP
RAW WATER PUMP
RAW WATER PIPES
STARTING MOTOR
STARTING MOTOR
ENGINE HARNESS
SCC
HYDRAULIC PUMP
HYDRAULIC PIPES
ENGINE PREHEATING
HYBRID
- Steyr Motors Marine Diesel Engine Spare Parts Catalogue
- Steyr Motors Marine Engine MO84K32 Spare Parts Catalogue
- Steyr Motors Marine Engine MO94K43 Spare Parts Catalogue
- Steyr Motors Marine Engine MO114K33 Spare Parts Catalogue
- Steyr Motors Marine Engine MO126K25 Spare Parts Catalogue
- Steyr Motors Marine Engine MO126M28 Spare Parts Catalogue
- Steyr Motors Marine Engine MO144V38 MO144M38 Spare Parts Catalogue
- Steyr Motors Marine Engine MO156K25 Spare Parts Catalogue
- Steyr Motors Marine Engine MO164M40 Spare Parts Catalogue
- Steyr Motors Marine Engine MO166K28 Spare Parts Catalogue EN DE
- Steyr Motors Marine Engine MO166M28 Spare Parts Catalogue
- Steyr Motors Marine Engine MO174V40 Spare Parts Catalogue
- Steyr Motors Marine Engine MO196K35 Spare Parts Catalogue
- Steyr Motors Marine Engine MO236FDE Spare Parts Catalogue EN DE
- Steyr Motors Marine Engine MO236K42 Spare Parts Catalogue
