Momed80
150
35,046
Snorkel Work Platform S9031RT to S9053RT Service Maintenance Manual 1443600-000
Brand: Snorkel
Type of Manual: Service Maintenance Manual
Model: Snorkel S9031RT S9043RT S9053RT Aerial Work Platform
Part Number: 1443600-000
Publication Date: 2026
Number of Pages: 312 Pages
Section 1 General Information
Component Identification
Serial Number Locations
Safety Precautions
Operator’s Manual Procedures
Technical Bulletins
Wire Code and Function Chart
PG Operating System
Parker Operating System
Abbreviations List
Section 2 Specifications
General Specifications
S9033RT
S9043RT
S9053RT
Drive Motor Specifications
Gear Hub Specifications
Brake Specifications
Battery Specifications
Pressure Filter Specifications
Hydrostatic Pump Specifications
Gear Pump Specifications
Engine Specifications
Kubota V1505 Stage 5
Kubota WG1605 Dual Fuel
Fastener Torque Chart
Standard System
Metric System
Section 3 Hydraulic Components
Chassis Hydraulic Component Location
Without Stabilizers
With Stabilizers
Stabilizers
Hydraulic Cabinet
Components
Stabilizer Manifold
Hydraulic Fluid Reservoir
Function Manifold
Top View
Bottom View
Rear, Right and Left Views
Coil Identification
Engine Cabinet
Kubota V1505 Stage 5 Engine
Kubota WG1605 Dual Fuel Engine
Hydraulic Pressure Filter
Hydrostatic Drive Pump
Right View
Left View
Gear Pump
Coupler Installation
Emergency Power Unit
Steer Cylinder
Oscillating Axle Cylinder
Stabilizer Cylinder
Lift Cylinder – Upper and Lower
Extension Deck Cylinder
Section 4 Electrical Components
Chassis Electrical Components
PG Operating System
Engine Cabinet
PG Operating System
PG Operating System
Power Distribution Module
Lower Controls
PG Operating System
Panel Components
RT93 Controller
Components
Pinouts
Panel Components
Display Screen
Control Module
Components
Controller Connectors
Pinouts
Electrical Panel
PG Operating System
PG Operating System
Stabilizer Limit Switch
Power to Platform
Single Extension Deck
110 Volt
220 Volt
Upper Control Box
Without Stabilizers, with DPF
External Components
With Stabilizers, with DPF
External Components
DPF Harness
Without Stabilizers
External Components
With Stabilizers
External Components
Dual Fuel Harness
PG Operating System
Internal Components
GP442 Control Board
Internal Components
XT44 Controller
Components
Pinouts
Joystick with Guard
Harnesses
Chassis Harness
PG Operating System
Wiring
Function Manifold Coil Identification
Pinouts
Wiring
To Controller
To Lower Controls
To PDM Module and Engine
To Hydraulic Warm-up Option
Pinouts
CAN, Grounds and Power
Engine Harness
Wiring
Pinouts
Wiring
Pinouts
Stabilizer Harness
PG Operating System
Wiring
Legend and Coil Identification
Pinouts
Wiring
Pinouts
Stack Harness
PG Operating System
AC Power to Plaform
Upper Control Box Harness
PG Operating System
Kubota V1505 Stage 5 Engine with Stabilizer Option and DPF
Wiring
Pinouts
Kubota WG1605 Dual Fuel Engine with Stabilizer Option
Wiring
Pinouts
Wiring
Pinouts
Upper Control Box Stabilizer Harness
Wiring
Pinouts
Upper Control Box Cord
PG Operating System
Components
Pinouts
Section 5 Engine Components
Right View
Left View
Diesel Particulate Filter
Right View
Left View
Section 6 Drive System Components
Oscillating Steer Axle
Rear Axle
Gear Hub
Drive Motor
Section 7 Stack
Stack
S9033RT
S9043RT
S9053RT
Emergency Lowering Cable
Section 8 Platform
Platform Components
Bottom View
Top View
Saloon Gate
Single Entry Gate
Section 9 Options
25KW Belt Driven Generator
Components
Installation
Generator Harness
Dual Extension Deck
Bottom View
Top View
110 Volt Power to Platform
220 Volt Power to Platform - CE
Hydraulic System Warm-up
Components
PG and Parker Operating Systems
PG Operating System
Upper Control Box Switch
Platform Light
PG Operating System
Section 10 Procedures & Adjustments
Recommended Tools
Main Pressure Adjustment
Diesel Particulate Filter Regeneration
PG Operating System
RT93 Controller Buttons
Initial set-up
RT93 Menus Available with EZcal
RT93 Calibrate Level Procedure
RT93 Calibrate Load Procedure
Height / Pressure
Loadcells
Errors
RT93 Access Level Code
RT93 Function Modes and Help Messages
Home Screen
Main Menu Screen
Machine Info Menu
Machine Data Menu
Machine Logs
Adjustments
Calibration Menu
Chassis Tilt
Arm Angle
Overload
Alerts
Pin / Number Entry
Overload Calibration
Display Home Screen
Procedure
Stabilizer Test
Oscillating Axle Test
Engine Codes
Kubota Engine
Section 11 Maintenance
General Maintenance
Lubrication Points
Battery Care and Maintenance
Maintenance Schedule
Prestart Inspection Checklist
Frequent Inspection and Maintenance – Every 90 Days or 150 Hours
Frequent Maintenance – Every 90 Days or 150 Hours
Annual Maintenance – Every 500 Hours
Major Repairs
Filter Service Intervals
Section 12 Schematics
Hydraulic Schematic
No Options
Generator and Stabilizer Options
Stabilizer Option
Generator Option
Function Manifold
Schematic
Abbreviations
Stabilizer Manifold
Electric Schematics
PG Operating System
Hydraulic Cabinet
Function Manifold
Stack to Upper Control Box
Hydraulic Cabinet
Function Manifold
Electrical Schematics Legend
Electrical Schematics Abbreviations
Section 13 Appendix
Appendix A - Glossary
