Momed80
150
35,046
Snorkel Aerial Work Platform AB60J AB60JRT Parts Manual 0181971 2016
Brand: Snorkel
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel AB60J AB60JRT Aerial Work Platform
Part Number: 0181971
Publication Date: 2016
Number of Pages: 1164 Pages
Repair Parts
4x4 Tires And Wheel Assembly
4x2 Tires And Wheel Assembly
Steering Installation 2wheel Drive
4x4 Steering Installation
Rear Drive Installation
Chassis And Turntable Installation
4x4 Chassis Sub-Assembly
4x2 Chassis Sub-Assembly
4x4 Turntable Assembly - Cummings
4x2 Turntable Assembly - Cummins
Turntable Assembly - Gm
Turntable Assembly - Gm Lps Only
4x4 Turntable Assembly - Gm Tier 3
Turntable Assembly - Kubota
Turntable Assembly - Kubota Tier 4 Final
Turntable Assembly - As/Nz - Kubota
Turntable Assembly - February 2020 And After - Kubota Wg2503 Dual Fuel
4x4 Lift Swing Counterweight Installation
4x2 Lift Swing Counterweight Installation
Centerpost Sub-Assembly 4wheel Drive
Hydraulic Fluid Reservoir Installation
Hydraulic Fluid Reservoir Assembly
Fuel Tank Installation
Engine Installation - Cummins 4b
Engine Sub-Assembly - Cummins 4b
Engine Installation - Cummins 3.3
Exhaust Installation - Cummins 4b
Exhaust/Air Cleaner Installation - Cummins 3.3
Engine Assembly - Cummins 3.3
Engine Assembly - Gm 2.4l T3
Engine Assembly - Kubota V2403 Cr Tier 4 Final
Engine Assembly - January 2018 And Before - Kubota Wg2503 Dual Fuel
Engine Assembly - February 2018 And After - Kubota Wg2503 Dual Fuel
Engine Sub-Assembly - December 2021 And Before - Kubota V2403t
Engine Sub-Assembly - January 2022 And After - Kubota V2403t
Engine And Radiator Installation - Ford 425 Lrg
Engine Sub-Assembly - Ford Lrg 425
Engine With Radiator Replacement Parts - Kubota Wg2503 Dual Fuel
Engine And Radiator Installation - Gm 2.4l Tier 3
Engine Sub-Assembly - Gm 2.4l Tier 3
Engine And Radiator Installation - Gm 3.0l Tier 3
Engine Sub-Assembly - Gm 3.0l Tier 3
Engine With Radiator Replacement Parts - Kubota V2403-M-T-E3b-Kea-2f
Engine With Radiator Replacement Parts - Kubota Wg2503 - Dual Fuel
Engine Replacement Parts - Kubota V2403-Cr Tier 4b
Engine Replacement Parts - Kubota V2403 Cr Tier 4 Final
Engine Radiator - Kubota Tier 4 Final
Fuel Pump Assembly - Gm 2.4l Tier 3
Diesel Oxidation Catalyst Muffler - Kubota V2403 Cr Tier 4 Final
Radiator Assembly - Cummins 3.3
Radiator Kit - Kubota Tier 4 Final
Supertrapp Muffler Adapter
Fuel System Gas Only - Gm Tier 3
Fuel System Standard Dual Fuel - Gm Tier 3
Fuel System Liquid Propane Only - Gm Tier 3
Fuel System Assembly - Kubota V2403 Tier 4 Final
Cooling System - Kubota V2403 Cr T1
Air Cleaner Replacement Parts
Exhaust/Air Cleaner Installation - January 2020 And After - Kubota Tier 4 Final
Exhaust/Air Cleaner Installation - Kubota Dual Fuel
Exhaust/Air Cleaner Installation - Ford 425 Lrg
Exhaust/Air Cleaner Installation - Gm 3.0l
Exhaust/Air Cleaner Installation - Gm Tier 3
Exhaust/Air Cleaner Installation - Kubota 2403 Tier 3
Air Cleaner Assembly
Air Cleaner Assembly - Cummins/Kubota 3.3 Dual Fuel
Cowling Installation
Cowling Installation - Cummins
Cowling Assembly - Kubota Tier 4 Final
Floating Turret
Boom Installation
Booms Mounting
Base Boom
Boom Sub-Assembly - Ce
Riser Boom And Turntable Installation
Boom And Jib Sub-Assembly
Boom And Jib Sub-Assembly With Overload
Aluminum Boom And Hose Carrier Assembly
Aluminum Boom And Hose Carrier Assembly - Ce
Boom And Alummum Jib Assembly - Ce
Jib Boom Sub-Assembly - Csa
Jib Boom Assembly Aluminum - Csa
Jib Boom Aluminum Assembly - November 2019 And After
Jib Boom Assembly Aluminum - Ansi/Ce - January 2001 And After
Jib Boom Assembly Aluminum - Ce
Jib Lift Cylinder Sub-Assembly
Platform Frame Mount Assembly - November 2019 And After
Platform Frame Mount W/ Ls Assembly
Platform Rotator Parker Assembly
Platform Rotator Assembly With Overload
Platform Assembly With Snorkel Guard
Global Platform Assembly
36x96 Steel Platform With Swing Gate And Bump Rail - May 2013 And After
Platform Assembly 36 X 96 Steel Double Handrail On Padding September 2017 And After
8' Aluminum Platform Installation With Swing Gate
8' Steel Platform Assembly Tri-Entry And Snorkel Guard
5' Aluminium Platform With Swing Gate - 500lb Capacity - No Halo
5' Aluminium Platform With Swing Gate And Snorkel Guard - 500lb Capacity
Snorkel Guard Legacy Assembly
Snorkel Guard Legacy Kit And Wiring
Decals/Placards Installation
4x4 Decals/Placards - Cummins
4x2 Decals/Placards - Cummins
4x4 Decals/Placards - Gm
4x2 Decals/Placards - Gm
4x4 Decals/Placards - Kubota
4x4 Decals/Placards - Kubota Tier 4 Final
4x4 Decals/Placards - Kubota Dual Fuel
4x4 Decals/Placards - Spanish - Kubota
4x4 Decals/Placards - Ce - Kubota
Decals/Placards Installation - Ab60ku - Tier 4 Final - Csa
Decals/Placards Installation - Ansi 92.2 - June 2020 And After
Decals/Placards Platform
Decals/Placards - Common - Ce
Decals/Placards Platform - Ce
Decals/Placards Installation - White Booms
Decals/Placards - Csa - Kubota Tier 4 Final
Language Kit - Spanish
Language Kit - French
Hydraulics
Drive Motion Control Valve
Chassis Hydraulic
Chassis Hydraulics - 2wheel Drive Installation
Chassis Hydraulic - 4wheel Drive - Before December 2003 And Before
Chassis Hydraulic - 4wheel Drive Installation
Gear Hub - Omni
Brake Unit
Rear Transmission Valve Sub-Assembly
Transmission Valve Package
Front Transmission Valve Assembly
Flow Divider Motion Control Valve Assembly
Flow Divider Combiner Valve - 2wheel Drive
Flow Divider - 4wheel Drive
Left Hand Steer Valve Sub-Assembly
Right Hand Steer Valve Sub-Assembly
Turntable Hydraulic Equipment Installation - 2wheel Drive - July 2006 And Before
Turntable Hydraulic Equipment Installation - 2wheel Drive - March 2007 And Before
Turntable Hydraulic Equipment Installation - 4wheel Drive - April 2000 And Before
Turntable Hydraulic Equipment Installation - 4wheel Drive - March 2015 And Before
Turntable Hydraulics Installation - 4wheel Drive
Turntable Hydraulic Equipment 4x2 - Fulid Tech
Lift And Swing
Swing Drive - April 2006 And After
Swing Drive Assembly -
Swing Drive - Auburn
Swing Drive - Perfection
Swing Motion Control Valve Replacement Parts
Motion Control Valve Swing - Fluid Tech
Pinion Guard
Return Oil Filter Sub-Assembly
Accumulator Sub-Assembly 300 Psi Charged Turntable
Accumulator Sub-Assembly 300 Psi Charged Chassis
Emergency Power Unit Assembly - April 2016 And Before
Emergency Power Unit Assembly - April 2016 And After
Pump Sub-Assembly - July 2018 And After - Kubota
Pump Sub-Assembly - September 2019 And After - Kubota
Pump Sub-Assembly - Kubota
Piston Pump - Hengli
Control Valve Assembly - Weco
Control Valve Replacement Parts - Weco Rexroth
Vickers Package Valve Assembly - March 1998 And After
Vickers Package Valve Replacement Parts
Non-Proportional Control Valve Assembly - October 2007 And After - Fluid Tech
Non-Proporational Control Valve Assembly - Ce - Fluid Tech
Non-Proportional Control Valve Replacement Parts - Fluid Tech
Proportional Control Valve Sub-Assembly - Apitech
Proportional Control Valve Replacement Parts - February 1994 And Before - Appetich
Dual Relief Anti-Cavitation Valve Sub-Assembly
Centerpost Weldment
Check Valve Assembly
Check Valve Sub-Assembly
Shift Speed Valve Sub-Assembly
Speed Shift Valve Sub-Assembly And Replacement Parts
Sense Line Dump Valve
Float Valve
Steer Cylinder - Rosenboom
Steer Cylinder - Hengli
Riser Boom Lift Cylinder Sub-Assembly - April 2020 And After - Rosenboom
Riser Boom Lift Cylinder Prince - April 2000 And Before
Riser Boom Lift Cylinder - Hengli
Riser Boom Lift Cylinder - Rosenboom
Main Boom Lift Cylinder Sub-Assembly - Feburary 2020 And After - Hengli
Main Boom Lift Cylinder - Rosenboom
Main Boom Lift Cylinder - Hengli
Primary Level Cylinder Sub-Assembly
Primary Leveling Cylinder - Hengli
Primary Level Cylinder - Gbi
Primary Level Cylinder - Prince
Primary Level Cylinder - Texas
Secondary Level Cylinder Sub-Assembly
Secondary Level Cylinder - Great Bend Industries
Secondary Level Cylinder Prince - April 2000 And Before
Secondary Level Cylinder - August 2000 And After - Rosenboom
Secondary Level Cylinder - Hengli
Extension Cylinder Sub-Assembly - Feburary 2020 And After - Hengli
Extension Cylinder - Rosenboom
Jib Boom Lift Cylinder - Rosenboom
Jib Boom Lift Cylinder - Hengli
Extension Cylinder - Hengli
Platform Rotator - Helec
Platform Rotator Dual Crossover Relief Valve
Electrical
Turntable Electrical Control Installation - Gm
Turntable Electrical Installation - Gm Tier 3 Dual Fuel
Turntable Electrical Control Installation - Cummins
Turntable Electrical Control Installation - December 2005 And Before
Turntable Electrical Control Installation - March 2008 And After - Cummins
Turntable Harness Assembly - Ford
Turntable Electrical Liquid Propane Only - Gm Tier 3
Turntable Wire Assembly - Gm Tier 3
Turntable Harness Boom Switch
Engine Harness Assembly - Cummins Tier 3
Engine Harness Assembly - Gm Tier 3
Engine Harness Interface - Gm 2.4l To 3.0l
Engine Harness Assembly - Kubota
Engine Harness - Kubota Tier 4 Final
Engine Harness - Kubota Vg2503 Dual Fuel
Diode Resistor Wire Assembly
Engine Wiring Harness - Ford Lrg 425
Wiring Box Assembly Engine - Gm
Wiring Box Sub-Assembly - April 2004 And Before - Cummins
Wiring Box - May 2003 And Before - Ford
Wiring Box Assembly - Cummins 3.3
Wiring Box Panel Assembly - October 2010 And After - Cummins 3.3
Wiring Box Panel Sub-Assembly - September 2003 And After - Cummins
Wiring Box Panel Sub-Assembly - Gm
Wiring Box Panel - Ford Lrg 425
Wiring Box Assembly - Kubota
Wiring Box Panel Assembly - Kubota
Wiring Box Assembly - July 2015 And After - Kubota
Wiring Box Assembly With Overload - Kubota
Wiring Box Assembly - Ce - Kubota
Wiring Box Internal Wire Assembly
Lower Control Panel Assembly - October 2017 And After - Kubota Tier 4 Final
Lower Control Panel Wiring Assembly - October 2017 And After - Kubota Tier 4 Final
Lower Control Box Assembly With Overload - As/Ce - May 2019 And After - Kubota Tier 4 Final
Lower Control Panel - May 2019 And After - Kubota Tier 4 Final
Lower Control Box Assembly - October 2018 And After - Kubota Tier 4 Final
Lower Control Box Assembly - Kubota Wg2503 Dual Fuel
Lower Control Panel Assembly - Kubota Wg2503 Dual Fuel
Lower Control Box Wiring - Ce
Control Box Mount Bracket Assembly
Harness Glow Plug Timer Assembly
Harness Eps Assembly
Solenoid Switch - Cummins
Solenoid Switch - Ford Lrg 425
Actuator Module Sub-Assembly
Boom Switch Sub-Assembly
Overload Module Harness
Tuv Boom Switch Installation
Boom Extend Switch Assembly
Boom Extend Switch
Boom Extend Switch Wire Assembly
Boom Lift Switch Assembly
Platform Control Box With Overload - May 2019 And After - Kubota Tier 4 Final
Upper Control Box Installation 4x2 Aluminum Jib - Cummins
Upper Control Box Assembly - 2wheel Drive
Upper Control Box Installation 4x4 - Ce - Cummins
Upper Control Box Assembly 4wheel Drive - October 2010 And After
Upper Control Box Installation - Gm 4x4 Tier 3
Upper Control Foot Switch Assembly
Upper Control Box 4wheel Drive - September 2007 And After
Upper Control Box Assembly - Tier 4 Final
Upper Control Box Assembly - Febraury 2018 And After - Kubota Tier 4 Final
Upper Control Box Assembly - Ce - October 2016 And After - Kubota
Upper Control Box Assembly - April 2016 And After - Kubota
Upper Control Box Assembly - November 2014 And After - Kubota
Upper Control Box Assembly With Overload - Spanish - Kubota
Upper Control Box Assembly - Wg2503 Dual Fuel
4x4 Upper Control Box Assembly - Ce
Controller Drive Steer - Universal
Controller Lift Swing
Options
Non-Marking Foam Filled Tires 4x4
Flotation Tires 4x4
Tow Package
Trackunit To Control Box Boom Installation
Cold Start Weather With Extra Battery - Cummins
Cold Weather Package - Cummins 3.3
Cold Weather Package - Kubota
Cold Weather Package - Gm
Cold Weather Hydraulic Fluid
Extreme Cold Weather Package - Cummins
Extreme Cold Weather Package - Kubota
Extreme Cold Weather Package - Gm
Extreme Enviroment Package
Hydraulic Warm-Up System Controls
Oil Biodegradeable
Exide Battery
Isolation Valve Installation
Waterline To Platform
Airline To Platform
Liquid Propane System Installation - Gm Tier 3 Final
Liquid Propane Fuel Only - Ford Lrg 423
Liquid Propane Fuel Only - Ford Lrg 425
Liquid Propane System Exhaust And Air Cleaner Installation With Lps Rating - Gm Tier 3
Liquid Propane System Only - Engine With Lps Rating - Gm
Liquid Propane Fuel Empty Indicator Light
Extra Liquid Propane Tank Bracket - No Tank
Oil Pressure Gauge - Cummins
2.4kw Belt Generator
Generator 120v Installation - November 2019 And After - Fabco
Generator 120v Installation - February 2022 And After - Fabco
Belt Generator - April 2019 And Before - Kubota 2.4kw V2403/Wg2503
2kw Generator Single V-Belt Assembly - Fabco
Belt Generator - May 2019 And After - Kubota 2.4kw V2403/Wg2503
Ac Generator Hydraulic 110v Power Cable
Ac Generator Valve
115v Ac 2000w Hydraulic Generator Installation - March 2012 And After
Cable 110 Power Aluminium Platform
220v Ac 50hz Hydraulic Ac Generator Sub-Assembly
2.4kw Hydraulic Generator Service Kit
220v Ac 50hz Hydraulic Generator Installation
Sandblast Kit
Boom Wiper
Swing Gate Side Midrail Aluminum Platform - October 2007 And After
Aircraft Package
Proximity Sensing System
36x96 Fall Anchorage Installation
Lanyard Mount
Safety Belt Anchor
Personal Fall Arrest Anchorage
Gravity Gate Side Entry Steel Platform
Upper Control Box - Courtesy Light
Upper Control Box Cover Installation Option
Alarm And Mounting Assembly
All Motion Alarm
Motion Alarm Drive Only
110v Power To Platform Installation
39x96 Steel Platform Tri-Entry - 500lb
39x96 Steel Platform Tri-Entry Snorkel Guard - 500lb
39x96 Steel Platform Tri-Entry Snorkel Guard - Ce - 500lb
36x96 Platform With Bumpguard Padding And Snorkel Guard
36x96 Platform Steel Assembly - Dual Handrails With Pad
36x96 Platform Assembly Bumpguard With Padding
36x96 Platform Assembly Bumpguard With Padding - March 2009 And After
39x96 Steel Platform 500lb Tri-Entry
Bump Guard Installation
Global Standard Platform Assembly
8' Alumummum Platform With Gravity Gate And Bumpguard With Padding 450lb Capacity
8' Steel Platform Swing Gate/Bumpguard With Padding
8' Steel Platform With Swing Gate/Bumpguard/Snorkel Guard
5' Steel Platform With Swing Gate/Bumpguard With Pading
5' Steel Platform With Swing Gate Bumpguard No Padding
Platform Bumpguard - May 2013 And After
Platform Control Cover Vinyl
Glazier Package Platform With 1.7" Toe Board Installation
Glazier Package World Platform With 2" Toe Board Installation
Csa Certification
Crane Lifting Weight
35 Mph Wind Rating
Grounding Loop
Pipe Rack Installation
Pipe Rack Boom Assembly
Platform Work Lights Global Installation
Platform Work Lights Led Installation
Operators Horn - September 2010 And After
Halogen Driving Lights With Red Rear Lights - May 2013 And After
Warning Light 5° Gradability Indicator
Worklight 2 Halogen Installation
Red Beacon Dual
Red Amber Beacon Dual
Driving Light - 4 Floods
Amber Beacon Dual
Amber Dual Beacon Drive
Light Package - Lps Only
Driving Lights - 2 Front 2 Rear
Driving Lights - 4 Halogen
Maintenance
Maintenance
Schematics
Electrical Schematic - Tier 4 Final
Electrical Schematic - Gm 2.4l Tier 3
Electrical Schematic - Revised Rheostat Wiring - Gm 2.4l Tier 3
Electrical Schematic - Updated Wring Add Fm Stamp - Gm 2.4l Tier 3
Electrical Schematic - 3.3 Replaced Cummins 3.9 - No Longer Available - Cummins
Electrical Schematic - Ce - Added Load Sense - Cummins
Electrical Schematic - 4x4 Updated Engine Harness For 1.6 Engine - Gm
Electrical Schematic - Tier 3 4x2 Release Of The Tier 3 Engine - Gm
Electrical Schematic - 4x4 Updated Wiring - Gm 1.6l
Electrical Schematic - 4x4 Added Fuel Pump Relay - Gm 1.6l
Electrical Schematic - 4x4 Added Aux Relay - Gm
Electrical Schematic - Tier 3 Added Glow Plug Timer Assembly And Related Wiring - Cummins
Electrical Schematic - 4x2 - Gm Tier 3
Electrical Schematic - 4x2 Revised Rheostat Wiring - Gm Tier 3
Electrical Schematic - Ce - Kubota
Electrical Schematic - Added Drive Cutout When Tilted - Kubota
Electrical Schematic - Dual Fuel Added Drive Cutout When Tilted - Kubota
Hydraulic Schematic 4wheel Drive Chassis
Hydraulic Schematic Turntable And Booms
Appendix A:pages Index
Appendix B:parts Index
