Momed80
150
35,046
Snorkel Work Platform S9031RT-HC to S9070RT-HC Service Maintenance Manual 1443601-000
Brand: Snorkel
Type of Manual: Service Maintenance Manual
Model: Snorkel S9031RT-HC, S9043RT-HC, S9056RT-HC, S9070RT-HC Aerial Work Platform
Part Number: 1443601-000
Publication Date: 2025
Number of Pages: 218 Pages
Section 1 General Information
Component Identification
Serial Number Locations
Safety Precautions
Operator’s Manual Procedures
Technical Bulletins
Wire Code and Function Chart
Abbreviations List
Section 2 Specifications
General Specifications
S9031RT-HC
S9043RT-HC
S9056RT-HC
S9070RT-HC
Drive Motor Specifications
Gear Hub Specifications
Brake Specifications
Battery Specifications
Pressure Filter Specifications
Hydrostatic Pump Specifications
TWO-Section Gear Pump Specifications
Engine Specifications
Kubota V2403 Stage 5
Kubota WG2503 Dual Fuel
Fastener Torque Chart
Standard System
Metric System
Section 3 Hydraulic Components
Chassis Hydraulic Component Location
Stabilizers
Hydraulic Cabinet
Components
Stabilizer Manifold
Hydraulic Fluid Reservoir
Components
Return Filter
Function Manifold
Top view
Bottom view
Rear View
Coil Identification
Engine Cabinet
Kubota V2403 Stage 5 Engine
Kubota WG2503 Dual Fuel Engine
Hydraulic Pressure Filter
Hydrostatic Drive Pump
Two-Section Gear Pump
Coupler Installation
Emergency Power Unit
Traction Manifold
Steer Cylinder
Oscillating Axle Cylinder
Stabilizer Cylinder
Lift Cylinder – Upper and Lower
Extension Deck Cylinder
Section 4 Electrical Components
Chassis Electrical Components
Engine Cabinet
Power Distribution Module
Lower Controls
Parker Operating System
Panel Components
Display Screen
FS43 Control Module
Components
Controller Connectors
Pinouts
Electrical Panel
Stabilizer Limit Switch
Power to Platform
110 Volt
220 Volt
Upper Control Box
External Components
DPF Harness
External Components
Dual Fuel Harness
Internal Components
XT44 Controller
Components
Pinouts
Joystick with Guard
Harnesses
Chassis Harness
Wiring
Function Manifold Coil Identification
To Controller
To Lower Controls
To PDM Module and Engine
To Cold Weather Option
Wire Chart
CAN, Grounds and Power
Engine Harness
Kubota V2403 Engine
Wiring
Wire Chart
Wiring
Wire Chart
Stabilizer Valve Harness
Wiring
Pinouts
Stack Harness
AC Power to Plaform
Stack Harness to 110 V Junction Box
Junction Box to Outlet Box Harness
Upper Control Box Harness
Wiring
Wire Chart
Upper Control Box Stabilizer Harness
Wiring
Wire Chart
Upper Control Box Cord
Components
Pinouts
Section 5 Engine Components
Right View
Left View
Right View
Left View
Diesel Oxygen Catalyst Muffler
Section 6 Drive System Components
Oscillating Steer Axle
Rear Axle
Gear Hub
Drive Motor
Section 7 Stack
Stack
S9031RT-HC
S9043RT-HC
S9056RT-HC
S9070RT-HC
Emergency Lowering Cable
S9031-RT-HC
S9043-RT-HC
Section 8 Platform
Platform Components
Bottom View
Top View
Saloon Gate
Single Entry Gate
Section 9 Options
25KW Belt Driven Generator
Components
Installation
Generator Harness
Cold Weather Package
Section 10 Procedures & Adjustments
Recommended Tools
Main Pressure Adjustment
Controller Navigation
Home Screen
Main Menu Screen
Machine Info Menu
Machine Data Menu
Machine Logs
Adjustments
Calibration Menu
Chassis Tilt
Arm Angle
Overload
Alerts
Pin / Number Entry
Overload Calibration
Display Home Screen
Procedure
Stabilizer Test
Oscillating Axle Test
Engine Codes
Kubota Engine
Section 11 Maintenance
General Maintenance
Lubrication Points
Battery Care and Maintenance
Maintenance Schedule
Prestart Inspection Checklist
Frequent Inspection and Maintenance – Every 90 Days or 150 Hours
Frequent Maintenance – Every 90 Days or 150 Hours
Annual Maintenance – Every 500 Hours
Major Repairs
Filter Service Intervals
Section 12 Schematics
Electric Schematics
Hydraulic Cabinet
Stack and Platform
Electrical Schematics Legend
Electrical Schematics Abbreviations
Hydraulic Schematic
Section 13 Appendix
Appendix A - Glossary
