Momed80
150
35,046
Snorkel Work Platform S3215L to S4740E Service Maintenance Manual 1503854-000
Brand: Snorkel
Type of Manual: Service Maintenance Manual
Model: Snorkel S3215L, S3215E, S3219E, S3220E, S3226E, S4726E, S4732E, S4740E Aerial Work Platform
Part Number: 1503854-000
Publication Date: 2024
Number of Pages: 174 Pages
Section 1 General Information
Component Identification
Chassis Component Location
Serial Number Locations
Wire Code and Function Chart
Abbreviations List
Operator’s Manual Procedures
Section 2 Specifications
General Specifications
S3215L
S3215E
S3219E
S3220E
S3226E
S4726E
S4732E
S4740E
Hydraulic Power Unit Specifications
Drive Motor Specifications
Battery Charger Specifications
Fastener Torque Chart
Standard System
Metric System
Section 3 Hydraulic Components
Chassis Hydraulic Component Location
Valve Tray
Two Speed Manifold
Hydraulic Tank and Hydraulic Power Unit
Lift Cylinder
Steer Cylinder
Section 4 Electrical Components
Chassis Electrical Component Location
Control Tray
Lower Control Panel
Battery Charger
Control Board
Pinouts
Codes
Platform Electrical Component Location
Side Drive
Upper Control Box
Joystick with Snorkel Guard
Harnesses
Chassis Harness
S3215E, S3215L and S3219E – February 2016 and After
S3215E, S3215L and S3219E – S3219-04-18100663 and After
S3215E, S3215L and S3219E – January 2019 and After
S3220E, S3226E, S4726E, S4732E, S4740E October 2018 and After
S4740E - EZ230 and EZ300 Control Boards
Lower Control Box Harness
Upper Control Box Harness
Two Speed – All Models Except S4740E
Two Speed – S4740E
Two Speed – CE
Section 5 Chassis Components
Pothole Protection
January 2016 and Before
Section 6 Drive System Components
Drive Motor
Brake Assembly
Section 7 Stack
Stack
S4740E
Section 8 Platform
Platform
With Folding Rails
Saloon Gate
Section 9 S4740E Electric Drive
Electric Drive Motor Specifications
Gear Hub Specifications
Hydraulic Valve
Power Hub
Wiring
SEM300 Control Board
Fault and Flash Codes
Chassis Harness
Setting Pressures
Steer Pressure
Lift Pressure
Hydraulic Pump Pressure
Hydraulic Schematic
Electrical Schematic
Section 10 Options
Lithium Battery
Two Batteries
Three Batteries
Perimeter Lights
Perimeter Light Lower Control Tray Harness
Perimeter Light Chassis Harness
Bumpguard
Wiring
High Capacity
S4740E
Section 11 Procedures & Adjustments
Recommended Tools
Battery Charger
Operation
Cable Connection
Fault Indicator
Profiles
Setting Pressures
Main Relief Pressure
Steer Pressure
Lift Pressure
Control Board Calibration
EZ230, EZ231, EZ300 & SEM300
Load Calibration
Tilt Calibration
Height Calibration
Section 12 Maintenance
General Maintenance
Lubrication Points
Battery Care and Maintenance
Maintenance Schedule
Prestart Inspection Checklist
Frequent Inspection and Maintenance – Every 90 Days or 150 Hours
Annual Maintenance – Every 500 Hours
Major Repairs
Filter Service Intervals
Section 13 Schematics
Hydraulic Schematic
S4740E
S4740E
ANSI and CSA
CE and AS
ANSI
Using Single Angle Transducer
Using Pendant 1502836
With Telematics Option
Without Telematics Option
AS and CE
CE
Section 14 Appendices
Appendix A - Glossary
Appendix B - Progressive Tilt
