Snorkel Telehandler SR626 Parts Manual 159-0004-000
Brand: Snorkel
Type of Machine: Telehandler
Type of Manual: Parts Manual, Electrical Schematic
Model: Snorkel SR626 Telehandler
Part Number: 159-0004-000
Publication Date: 20118
Number of Pages: 621 Pages
Repair Parts
Chassis Assembly - Stage 3 And 5
Work Lights And Components - Standard - No Usa - Stage 5
Work Lights And Components - Stage 3
Work Lights And Components - If Usa - Stage 5
Engine Assembly - Stage 5
Engine Assembly - Yanmar Stage 3a
Engine - Yanmar 52kw Stage 5
Engine - Yanmar Stage 3a
Eat Assembly - A - Stage 5
Eat Assembly - B - Stage 5
Fan Assembly - Stage 3/5
Air Filter Assembly - 52kw Stage 5
Air Filter Assembly - 52kw Stage 3a
Exchanger Assembly - 52kw Stage 5
Engine Supports Assembly - Stage 3 And 5
Engine Control Unit Assembly - 52kw Stage 5
Engine Control Unit Assembly - Stage 3
Filters Assembly - 52kw Stage 3a
52 Kw Diesel Pump Assembly - Stage 3/5
Tray Assembly - 52kw Stage 5
Engine Exhaust - Yanmar Stage 5
Engine Exhaust - Yanmar Stage 3a
Plastic Diesel Tank Assembly - Stage 3 And 5
Engine Hood And Compartment Casing Assembly - A - Stage 3 And 5
Engine Hood And Compartment Casing Assembly - B - Stage 3 And 5
Pump-Engine Coupling Assembly - Stage 3 And 5
Engine - Yanmar Tier 4 Final
Engine Exhaust - Yanmar Tier 4 Final
Engine Throttle - Yanmar Tier 4 Final
Engine Replacement Parts - Yanmar 4tnv98c Tier 4 Final
Diesel Tank
Chassis Assembly
Chassis And Carter
Arm Pins
Main Transmission Assembly - Stage 3/5
Front Axle Assembly - Stage 3/5
Front Axle - Central Box - Stage 3/5
Front Axle - Spacer - Stage 3/5
Front Axle - Hub Final Drive - Stage 3/5
Front Axle - Brakes - Stage 3/5
Front Axle - Steering - Stage 3/5
Rear Axle Assembly - Stage 3/5
Rear Axle - Central Box - Stage 3/5
Rear Axle - Differential - Stage 3/5
Rear Axle - Hub Final Drive - Stage 3/5
Rear Axle - Steering - Stage 3/5
Rear Axle - Pins - Stage 3/5
Universal Joint Shaft - Stage 3/5
Wheels - Stage 3/5
Steering Distributor - Stage 3/5
Steering Column - Stage 3/5
Brake Accumulator Assembly Parking Brake - Stage 3/5
Brake Pedal Kit Assembly - Stage 3/5
Boom Assembly - Stage 3/5
Fixed Boom Assembly - Stage 3/5
Fixed Boom Assembly - A - Stage 3/5
Fixed Boom Assembly - B - Stage 3/5
Fixed Boom Assembly - C - Stage 5
Fixed Boom Assembly - C - Stage 3
Extension Assembly - Stage 3/5
Extension Assembly - A - Stage 3/5
Extension Assembly - B - Stage 3/5
Extension Assembly - C - Stage 3/5
6' Material Handler Jib Assembly
Fh Accessory Holder Assembly - Stage 3/5
Euro Coupling Accessory Holder Assembly - A - Stage 3/5
Euro Coupling Accessory Holder - B - Stage 5
Euro Coupling Accessory Holder - B - Stage 3
Carriage Pin Assembly
Carriage Assembly
Oil Tank
Oil Tank New Transmission
Rear Hydraulic Weight
Cabin Clasic Agritop
Cabin Queen Cabin Door
6 Way Electric And 6 Way Manual Diverter On Boom
Abs Cabin - If Closed Cabin - Stage 3/5
Abs Cabin - If Open Cabin - Stage 5
Abs - Front Plastics - If Closed Cabin - Stage 3/5
Abs - Front Plastics - If Open Cabin - Stage 5
Abs - Door Side Plastics - If Closed Cabin - Stage 3/5
Abs - Engine Compartment Side Plastics - A - If Closed Cabin - Stage 3/5
Abs - Engine Compartment Side Plastics - A - If Open Cabin - Stage 5
Abs - Engine Compartment Side Plastics - B - Stage 3/5
Abs - Rear Plastics - If Closed Cabin- Stage 3/5
Abs - Rear Plastics - If Open Cabin - Stage 5
Abs - Cabin Roof Plastics - Stage 3/5
Cabin - Windows And Wipers - If Closed Cab - Stage 3/5
Cabin - Windows And Protections - If Open Cabin - Stage 5
Cabin - Door - If Closed Cab - Stage 3/5
Cabin - Mechanical Spring Seat - If Closed Cab - Stage 3/5
Cabin - Mechanical Spring Seat - If Open Cab - Stage 3/5
Cabin Air Suspension Seat - Stage 3/5 - If Closed Cab
Cabin - Antivibration Pads - Stage 3/5
Cabin - Insulating Foam - Stage 3/5
Cabin - Wrist Support/Joystick Controller - If Open Cabin - Stage 5
Cabin - Wrist Support/Joystick Controller - If Closed Cabin - Stage 5
Cabin - Wrist Support/Joystick Controller - From July 2022 - Stage 3
Cabin - Wrist Support/Joystick Controller - Until June 2022 - Stage 3
Cabin - Levelling Device - Stage 3/5
Cabin - Heating And Ventilation - If Closed Cab - Stage 3/5
Cabin - Accelerator Pedal - Until February 2023 - Stage 5
Cabin - Accelerator Pedal - March 2023 And After - Stage 5
Cabin - Electronic Accelerator Pedal 3a
Cabin - Buttons And Dashboard - A - If Closed Cab - Stage 3/5
Cabin - Buttons And Dashboard - B - If Closed Cabin - Stage 3/5
Cabin - Buttons And Dashboard - If Open Cabin - Stage 5
Inner Coating Cabin
Leveling Bubble
Decal Kit - Ce
Safety Decals - Stage 3/5
Color Codes - Stage 3/5
Faresin Spare Key List
Hydraulics
Hydrostatic Engine - Stage 3/5
Hydrostatic Pump - A - Stage 3/5
Hydrostatic Pump - B - Stage 3/5
Hydroguide - Stage 3/5
Extension Cylinder - Stage 3/5
Compensation Cylinder - Stage 3/5
Hydrostatic Engine - 85cc - Version 1
Hydrostratic Engine - 80cc - Version 2
Hydrostatic Pump - 45cc - Version 1
Hydrostatic Pump - 40cc - Version 2
Hydraulic Pump Joint
Service Pump - From October 2022
Power Steering
Lifting Cylinder - Stage 3/5
Tilting Cylinder
Quick Uncoupling Cylinder
Single Acting Shut-Off Valve - Stage 3/5
Single Acting Shut-Off Valve - Atlantic - Stage 3/5
Hydraulic Fluid Reservoir - Stage 3/5
Pilot Block Assembly - Stage 3/5
Service Pump - Stage 3/5
Distributor - A - Standard - No Usa - Stage 3/5
Distributor - B - Standard - No Usa - Stage 3/5
Distributor - A - If Usa - Stage 5
Distributor - B - If Usa - Stage 5
In-Line Valve Assembly - If Usa - Stage 5
Proportional Extension Distributor Dn 85/5 - Version 1
Proportional Extension Distributor Dn 85/5 - Version 2
Steering Block
Service Pump - 25cc
6 Way Solenoid Valve
6 Way Electric Diverter On Boom
Solenoid Valve Assembly 6 Way 2 Post 1/2
Hydraulic Braking Kit
Differential Locking Kit
Double Hydraulic Connection Hose Kit
Arm Suspension Kit
Floating Arm Kit
Rear Hydraulic Connection Hose Kit
Electrical
Battery - Stage 3/5
Relay Panel 2
Cabin - Various Components - Stage 3/5
Control Units/Displays/Boards - If Closed Cabin - Stage 5
Control Units/Displays/Boards - If Closed Cabin - Stage 3
Fuse And Relay Holder Board - If Open Cabin - Stage 5
Control Units/Displays/Boards - If Open Cabin - Stage 5
Fuse Holder Board - If Closed Cabin - Stage 3/5
Fuse And Relay Holder - Stage 3/5
Relay Holder Board - If Closed Cabin - Stage 3/5
Joystick Controller
Joystick Controller Wrist Resets Classis
Side Dash Board Selectors
Front Side Dash Board Selectors
Front Dash Board Selectors
Chassis Harness
Engine Harness - Yanmar Tier 4 Final
Driver Seat
Universal Cabin Roof Sheath
Pnp Wired Sensor
Inching Potentiometer With Resistors
Electrical Wiring - My18 Frame - Stage 3/5
Electrical Wiring - My18 Driving Place - Stage 3/5
Electrical Wiring - Yanmar 3b My18 - Stage 5
Electrical Wiring - Yanmar 3a My18 - Stage 3
Electrical Wiring - My18 Pushbutton - Stage 3/5
Electrical Wiring - Bw From Cabin Mass To Frame Mass - Stage 3/5
Electrical Wiring - Battery Switch - Stage 3/5
Electrical Wiring - Wired Plate Light - Stage 3/5
Electrical Wiring - Deutz 55kw Stage 3/5
Electrical Wiring - Distr. Dinoil Classic Eda Interface - Stage 3/5
Electrical Wiring - Hydraulic Fluid Level - Stage 3/5
Electrical Wiring - Various - Stage 3/5
Options
Flat Face Quick Fittings - Starting From September 2022 - Stage 3/5
Skid Steer Adapter Assembly
Tire Assembly - Air Filled
Tire Assembly - Foam Filled
Left Solid Tire Wheel - Camso 792s
Right Solid Tire Wheel - Camso 792s
Non-Marking Solid Tires
Cleanfix Fan
Bobcat Fitting Service Kit
Rear Tow Hook - Stage 3/5
Adjustable Towing Hook
Assembly Valve Block Accessries
Air Conditioning - Stage 3/5
Air Conditioning Compressor - Stage 3
Air Conditioning Compressor - Stage 5
Cabin - Air Conditioning Kit - Stage 3/5
Cabin - Mirror Spoiler Oc Work Lights Assembly - If Open Cab - Stage 5
Hydraulic Socket Assembly Rear - Stage 3/5
Double Rear Hydraulic Socket - Stage 3/5
Boom Suspension - Stage 3/5
Floating Boom - Stage 3/5
Boom Work Lights - Stage 3/5
Quick Release - Stage 3/5
6-Way Electric Diverter - Stage 3/5
After Market
Bucket 1.00 Cu Yd Star - January 2020 And After
Reversible Fan - Stage 3
Reversible Fan - Stage 5
Water Pre-Heating - Stage 3/5
Telematics - Stage 3/5
Telematic Support Bracket
Trailer Brake - Hydraulic Co Stage 3/5
Peb Unit/Ready For Winch - Stage 3/5
Cabin Protection Grid - Stage 3/5
Quick Coupler Skidsteer - Bradco
Hydraulic Quick Disconnect Flatface - Juanuary 2020 And After
Extreme Carriage Kit
Led Work Lights
Queen Cabin Working Lights - Stage 3/5
Rear Electrical Outlet - Stage 3/5
Schematics
Electrical Schematic - Sr5719/Sr626
Hydraulic Schematic - Stage 3/5
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Diesel Tank
Chassis Assembly
Chassis And Carter
Arm Pins
Wheels - Stage 3/5
Carriage Assembly
Oil Tank
Inner Coating Cabin
Leveling Bubble
Decal Kit - Ce
Hydraulics
Power Steering
Tilting Cylinder
Steering Block
Service Pump - 25cc
Arm Suspension Kit
Floating Arm Kit
Electrical
Battery - Stage 3/5
Relay Panel 2
Joystick Controller
Chassis Harness
Driver Seat
Pnp Wired Sensor
Options
Cleanfix Fan
After Market
Led Work Lights
Schematics
Appendix A
Appendix B
