Snorkel Telehandler SR626 Operators And Maintenance Manual 159-0003-000 2018
Brand: Snorkel
Type of Machine: Telehandler
Type of Manual: Operators And Maintenance Manual
Model: Snorkel SR626 Telehandler
Part Number: 159-0003-000
Publication Date: 2018
Number of Pages: 164 Pages
1. General Information
1.1 Preliminary Information
1.2 The Manufacturer
1.3 The Dealer
1.4 Ce Certification
1.5 Operator Training
1.6 Machine Identification
1.7 Noise
1.8 Vibration
Technical Specifications
1.9 Regulatory References
2. Safety
2
2.1 Intended Use Of The Machine
2.2 Unintended Use
2.3 Limits Of Use
2.4 General Regulations For Use
2.5 Working On Site
2.6 Maneuvering On Uneven Ground
2.7 Maneuvering On A Transversal Slope
2.8 Maneuvering On A Longitudinal Slope
2.9 In Case Of Tipping Over
2.10 Preparing To Drive
2.11 Opening The Back Window
2.12 Heating And Air Conditioning
2.13 Safety Decals
2.14 Load Diagram
2.15 Anti-Tip System (Llmi-Llmc)
2.16 Transporting The Machine
2.17 General Safety Warnings
2.18 Checking Engine Start Up
2.19 Movement In Reverse Drive
2.20 Refuelling The Machine
2.21 Storing The Machine
2.22 Machine Demolition
2.23 Using The Machine
2.24 Road Circulation
3 Sr626 Tier Iv Final Controls And General Regulations
3.1 Description Of The Controls
4 Operating With The Machine
4.1 Start Up
4.2 Forward Drive Or Reverse Drive
4.3 Steering
4.4 Selecting The Driving Mode
4.5 Accessory Coupling And Release
4.6 Stacking
4.7 Limits Of Machine Use
4.8 Reversing Fan Procedure
4.9 What To Do And Not Do
4.10 How To Verify That The Anti-Tip Device Works Correctly
4.11 Towing The Machine
5 Sr626 Tier Iv Final Maintenance
5.1 General Information
5.2 Thermal Risk
5.3 Pressurised Liquids
5.4 Exhaust Gas
5.5 Handle The Battery With Care
5.6 Start-Up Using An External Battery
5.7 In Case Of Fire
5.8 Maintenance With The Engine Off
5.9 Maintenance With The Engine On
5.10 Respect The Environment
5.11 Maintenance Schedule
5.12 Engine
5.13 Heat Exchanger
5.14 Checking The Hydraulic Oil Level
5.15 Changing The Hydraulic Oil
5.16 Visual Inspection For Oil Leaks In The Hydraulic System
5.17 Replacing The Return Hydraulic Oil Filter Cartridge
5.18 Cleaning Or Replacing The Oil Tank Vent Cartridge
5.19 Replacing The Hydrostatic Pump Oil Cartridge/Filter
5.20 Cleaning And Replacing The Engine Air Filter Cartridge
5.21 Replacing The Cabin Air Filter
5.22 Greasing – Lubrication
5.23 Lubricant/Liquid Characteristics
5.24 Axles
5.25 Torque Of The Screws And Greasing The Cardan Shaft Cross
5.26 Recharging The Air Conditioning
5.27 Checking The Tire Pressure And Torque Of The Nuts
5.28 Inspecting, Charging And Replacing The Battery
5.29 Fuse Holder Card
5.30 Engine Errors List
5.31 List Of Transmission Errors
6 Electrical System Diagram
6.1 Request For The Electrical Wiring Diagram
7 Hydrualic System Diagram
7.1 Request For Hydraulic System Diagram
8 Scheduled Maintenance Coupons
8.1 Implemented Scheduled Maintenance Coupons
9 Machine Receipt Card
Brand: Snorkel
1.3 The Dealer
1.7 Noise
1.8 Vibration
2. Safety
2
2.2 Unintended Use
2.3 Limits Of Use
2.5 Working On Site
2.13 Safety Decals
2.14 Load Diagram
4.1 Start Up
4.3 Steering
4.6 Stacking
5.2 Thermal Risk
5.4 Exhaust Gas
5.7 In Case Of Fire
5.12 Engine
5.13 Heat Exchanger
5.24 Axles
