Momed80
150
35,046
Snorkel Telehandler SR1745 Parts Manual 159-0043-000
Brand: Snorkel
Type of Machine: Telehandler
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel SR1745 Telehandler
Part Number: 159-0043-000
Publication Date: 2022
Number of Pages: 730 Pages
Repair Parts
Mud Guard Kit - Stage 5
Chassis And Pins
Rear Axle
Rear Axle - Axial Body
Rear Axle - Caps And Steering Cylinder
Rear Axle - Bevel Gear
Rear Axle - Differential
Rear Axle - Double Joint
Rear Axle - Wheel Hub
Rear Axle - Planetary Reduction
Front Axle
Front Axle - Axle Body
Front Axle - Caps And Steering Cylinder
Front Axle - Bevel Gear
Front Axle - Spacer
Front Axle - Double Joint
Front Axle - Brakes
Front Axle - Wheel Hub
Front Axle - Planetary Reduction
Front Axle - Transmission Box
Front Axle - Shafts And Gears
Main Transmission Assembly
Steering Distributor
Steering Column
Engine - Deutz - A - If 100kw - 74kw Stage 5
Engine - Deutz - If 100kw - 74kw Stage 4/5
Eat Assembly (If 100kw - 74kw Stage Iv)
Fan Assembly - If 100kw - 74kw
Engine - Deutz - If 100kw - 74kw Stage 5a
Engine Assembly - Deutz - If 100kw - 74kw Stage 5
Eat Assembly - If 100kw - 74kw Stage 5a
Engine Assembly - Deutz - If 55kw
Engine - Deutz - If 55kw - A
Engine Supports Assembly
Engine Exhaust - Deutz 90kw 3b
Engine - Deutz - If 55kw Stage B
Exhaust Assembly - If 100kw - 74kw Stage 4
Exhaust Assembly - If 55kw
Engine Assembly - Deutz 90kw Tcd 3.6 L4
Engine Assembly - Deutz - If 100kw - 74kw Stage 4
Exhaust Terminal
Abs - Front Plastics - If Closed Cabin
Abs - Front Plastics - If Open Cabin
Abs - Door Side Plastics - If Closed Cabin
Abs - Engine Compartment Side Plastics - A - If Closed Cabin
Abs - Engine Compartment Side Plastics - A - If Open Cabin
Abs - Engine Compartment Side Plastics - B
Parking Brake Accumulator - Fr04
Brake Pedal
Cabin - Abs - If Closed Cabin
Cabin - Abs - If Open Cabin
Cabin Clasic Agritop
Cabin Queen Cabin - Door 1
Cabin Queen Cabin - Door 2
Cabin - Rear Casing - If 100kw - 74kw
Cabin - Rear Casing - If 55kw
Cabin - Windows And Wipers - If Closed Cabin
Cabin - Door - If Closed Cabin
Cabin - Mechanical Spring Seat - If Closed Cabin
Cabin - Windows And Protections - If Open Cabin
Cabin - Mechanical Spring Seat - If Open Cabin
Cabin - Anti-Vibration Pads
Cabin - Insulating Sponges
Cabin - Wrist Support/Joystick Controller - If Closed Cabin - Until June 2022
Cabin - Wrist Support/Joystick Controller - If Usa - From July 2022
Cabin - Levelling Device
Cabin - Rear View Mirror
Inner Coatings Cabin Classic
Casting And Protections
Leveling Bubble
Chassis And Lights
Cardan Shaft
Stabilizers Assembly
Abs - Rear Plastics - If Closed Cabin
Abs - Rear Plastics - If Open Cabin
Abs - Cabin Roof Plastics
Air Suspension Seat - If Closed Cabin
Eat Assembly - If 55kw
Eat Assembly - If 100kw - 74kw Stage 5b
Fan Assembly - If 55kw
Tank Assembly - If 100kw - 74kw - Adblue
Pump - If 100kw - 74kw - Adblue
Engine-Pump Coupling
Air Filter Assembly - If 100kw - 74kw Stage 5
Air Filter Assembly - If 100kw - 74kw Stage 4
Powercore Complete Air Filter 9"
Exchanger Assembly - If 100kw - 74kw
Exchanger Assembly - If 55kw
Control Unit Assembly - If 100kw - 74kw Stage 5
Control Unit Assembly - If 100kw - 74kw Stage 4
Control Unit Assembly - If 55kw
Tank Assembly
Diesel Pump Filters Assembly - If 100kw - 74kw Stage 5
Diesel Pump Filters Assembly - If 100kw - 74kw Stage 4
Diesel Pump Filters Assembly - If 55kw
Diesel Tank Kit - Before June 2023
Diesel Tank Kit - After July 2023
Chassis Assembly - A
Chassis Assembly - B
Oscillating Bridge Assembly
Ballasts Assembly - 14-17m
Boom Assembly - 17m
Fixed Boom Assembly - 17m
Fixed Boom Assembly - 17m - A
Fixed Boom Assembly - 17m - B
Fixed Boom Assembly - 17m - C
Boom Containment Kit - 17m
Boom Containment Kit - 14m
Boom Assembly - 14m
Fixed Boom Assembly - 14m
Fixed Boom Assembly - 14m - A
Fixed Boom Assembly - 14m - B
Fixed Boom Assembly - 14m - C
Assembly Arm - 14m
Assembly Extension I - 14m
Assembly Extension I - 14m - A
Assembly Extension I - 14m - B
Assembly Extension I - 14m - C
Assembly Extension Ii - 14m
Assembly Extension Ii - 14m - A
Assembly Extension Ii - 14m - B
Assembly Extension I - 17m
Assembly Extension I - 17m - B
Assembly Extension I - 17m - C
Assembly Extension I - 17m - D
Assembly Extension Ii - 17m
Assembly Extension Ii - 17m - A
Assembly Extension Ii - 17m - B
Assembly Extension Ii - 17m - C
Assembly Extension Iii - 17m
Assembly Extension Iii - 17m - A
Assembly Extension Iii - 17m - B
Assembly Extension Iii - 17m - C
Assembly Extension Iii - 17m - D
Accessory Holder - Boom
Services Pump Suction - Casappa
Oil Tank
Boom Inclinometer
Casings And Protections Assembly - A
Casings And Protections Assembly - B
Engine Hood And Compartment Casing Assembly - If Stage 4
Engine Hood And Compartment Casing Assembly - If Stage 5
Pump-Engine Coupling Assembly
Heavy-Duty Standard Carriage Assembly With Doublers
Carriage Pin Assembly
Safety Decals
Flip Chart Set
Load Chart Set - Sr1054
Color Codes
Hydraulics
Danfoss Hydraulic Engine - A
Danfoss Hydraulic Engine - B
Hydroguide
Hydraulic Hose Schematic
Suspension Boom Hose Kit
Floating Boom Hose Kit
Rear Hydraulic Connection Hose Kit
Quick Release Hose Kit
Rear Axle Lock Hose Kit
Levelling Cylinder
Stabilizer Cylinder
Lifting And Compensation Cylinders - 14m
Lifting And Compensation Cylinders - 17m
Lifting Valve
Extension Cylinder - 14m
Extension Cylinder - 17m
Pilot Block
Bench Distributor
Tilting Cylinder
Hydrostatic Engine - 160cc
Hydrostatic Pump 71cc
Danfoss Hydrostatic Pump - A - If 55kw
Danfoss Hydrostatic Pump - B - If 55kw
Danfoss Hydrostatic Pump - A - If 100kw - 74kw
Danfoss Hydrostatic Pump - B - If 100kw - 74kw
Steering Valve Assembly
Power Steering Assembly
Service Pump - Casappa
Hydraulic Service Pump Itake Pump - Casappa 51cc
Distributor - A - If Usa
Distributor - A - Standard - No Usa
Distributor - B - If Usa
Distributor - B - Standard - No Usa
Distributor
Distributor - Dn85
In-Line Valve Assembly - If Usa
Proportiona Extension Distribution Dn85-5 Fr00 - Version 2
Hydraulic Manifold - Fr04
Electrical
Anti-Tilt System Sensor
Battery - If Stage 5
Battery - If Stage 4
Control Units/Display/Boards - If Closed Cabin
Control Units/Display/Boards - If Open Cabin
Fuse And Relay Holder
Fuse Holder Board - If Closed Cabin
Fuse And Relay Holder Board - If Open Cabin
Cabin - Heating And Ventilation - If Closed Cabin
Cabin - Accelerator Pedal - February 2023 And Before
Cabin - Accelerator Pedal - March 2023 And After
Cabin - Buttons And Dashboard - A - If Closed Cabin
Cabin - Buttons And Dashboard - B - If Closed Cabin
Cabin - Buttons And Dashboard - C - If Closed Cabin
Cabin - Buttons And Dashboard - If Open Cabin
Cabin - Various Components
Cabin - Mirror Spoiler Oc Work Lights Assembly - If Open Cabin
Engine - Deutz Tcd 3.6 Kw
Pnp Wired Sensor
Limit Switch Connector Wiring
Driver Seat Basic
Pushbutton Panel Basic
Frame Telaio Basic
Universal Cabin Roof Sheath
Plate Light Extension
Electrical Wiring - Deutz Engine Classic 74kw - 100kw - If Stage 5
Electrical Wiring - Deutz Engine Classic 55kw - Stage 4/5
Electrical Wiring - Deutz Engine Classic 74kw - 100kw - If Stage 4
Electrical Wiring - Battery Wire 1
Electrical Wiring - Battery Wire 2
Electrical Wiring - Distributor Interface Dinoil Classic Eda
Electrical Wiring - Pnp Sensor
Electrical Wiring - Joystick Controller Interface
Electrical Wiring - Guide Side If Open Cabin
Electrical Wiring - Guide Side If Close Cabin
Electrical Wiring - Frame If Open Cabin
Electrical Wiring - Frame If Close Cabin
Electrical Wiring - Levelling Keypad
Electrical Wiring - Levelling Frame Modified
Electrical Wiring - Air Conditioning
Electrical Wiring - Work Light Extension On Boom
Electrical Wiring - Keypad
Electrical Wiring - Stabilisers If Open Cabin - Fr04
Electrical Wiring - Stabilisers If Close Cabin - Fr04
Electrical Wiring - Roof - Only Open Cabin- Fr04
Electrical Wiring - License Plate Light
Electrical Wiring - Wired Blue Led
Lights And Components - A
Lights And Components - B
Wrist Rests Classic
Joystick Controller Classic
Options
Air Conditioning
Air Conditioning Compressor
Cabin - Air Conditioning Kit
Cabin - Protection Grid
Rear Towing Hook
Rear Electrical Outlet
Rear Hydraulic Outlet - Fr04
Boom Suspension
Boom Peb 17m - Fr04
Boom Peb 14m - Fr04
Boom Work Lights
Floating Boom
Rapid Release
6-Way Electric Diverter
Accessory Holder Xtreme
Rear Axial Lock Assembly
Rear Axial Lock - A
Rear Axial Lock - B - Only With Prop Levelling Kit
Rear Axial Lock - C
Flat Face Quick Fittings - From November 2022 And After
Reversable Fan - If 100kw - 74kw
Reversable Fan - If 55kw
Water Pre-Heating
Double Hydraulic Plug On Boom
Prop Levelling Assembly
Proportional Bench Distributor - A - Fr04
Proportional Bench Distributor - B - Fr04
Queen Cabin Work Lights
Grapple Assembly With Shoe Clamp 9660
Telematic
Schematics
Hydraulic Schematic - 55kw - 17m
Hydraulic Schematic - 55kw - 14m
Hydraulic Schematic - 74 Kw - 17m
Hydraulic Schematic - 74 Kw - 14m
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 1 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 2 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 3 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 4 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 5 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 6 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 7 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 8 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 9 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 10 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 11 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 12 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 13 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 14 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 15 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 16 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 17 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 18 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 19 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 20 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 21 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 22 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 23 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 24 Of 33
Electrical Schematic Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 25 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 26 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 27 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 28 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 29 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 30 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 31 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 32 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 33 Of 33
Appendix A:pages Index
Appendix B:parts Index
