Momed80
150
35,046
Snorkel Telehandler SR1442 Parts Manual 159-0042-000
Brand: Snorkel
Type of Machine: Telehandler
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel SR1442 Telehandler
Part Number: 159-0042-000
Publication Date: 2022
Number of Pages: 733 Pages
Repair Parts
Mud Guard Kit - Stage 5
Rear Axle
Rear Axle - Axial Body
Rear Axle - Caps And Steering Cylinder
Rear Axle - Bevel Gear
Rear Axle - Differential
Rear Axle - Double Joint
Rear Axle - Wheel Hub
Rear Axle - Planetary Reduction
Front Axle
Front Axle - Wheel Hub
Front Axle - Brakes
Front Axle - Bevel Gear
Front Axle - Axle Body
Front Axle - Caps And Steering Cylinder
Front Axle - Spacer
Front Axle - Double Joint
Front Axle - Planetary Reduction
Front Axle - Transmission Box
Front Axle - Shafts And Gears
Main Transmission Assembly
Engine Assembly - Deutz 90kw Tcd 3.6 L4
Engine Assembly - Deutz - If 55kw
Engine - Deutz - A - If 100kw - 74kw Stage 5
Engine - Deutz - If 100kw - 74kw Stage 4/5
Engine Assembly - Deutz - If 100kw - 74kw Stage 4
Exhaust Assembly - If 100kw - 74kw Stage 4
Eat Assembly (If 100kw - 74kw Stage Iv)
Engine - Deutz - If 100kw - 74kw Stage 5a
Eat Assembly - If 100kw - 74kw Stage 5a
Fan Assembly - If 100kw - 74kw
Engine Assembly - Deutz - If 100kw - 74kw Stage 5
Engine - Deutz - If 55kw - A
Fan Assembly - If 55kw
Engine - Deutz - If 55kw Stage B
Engine-Pump Coupling
Engine Exhaust - Deutz 90kw 3b
Engine Supports Assembly
Eat Assembly - If 100kw - 74kw Stage 5b
Eat Assembly - If 55kw
Exhaust Assembly - If 55kw
Exhaust Terminal
Steering Distributor
Steering Column
Parking Brake Accumulator - Fr04
Brake Pedal
Cabin - Abs - If Closed Cabin
Cabin - Abs - If Open Cabin
Abs - Front Plastics - If Closed Cabin
Abs - Front Plastics - If Open Cabin
Abs - Door Side Plastics - If Closed Cabin
Cabin Clasic Agritop
Cabin Queen Cabin - Door 1
Cabin Queen Cabin - Door 2
Inner Coatings Cabin Classic
Casting And Protections
Leveling Bubble
Chassis And Lights
Chassis And Pins
Stabilizers Assembly
Air Suspension Seat - If Closed Cabin
Abs - Engine Compartment Side Plastics - A - If Closed Cabin
Abs - Engine Compartment Side Plastics - A - If Open Cabin
Abs - Engine Compartment Side Plastics - B
Abs - Rear Plastics - If Open Cabin
Abs - Rear Plastics - If Closed Cabin
Abs - Cabin Roof Plastics
Cardan Shaft
Tank Assembly - If 100kw - 74kw - Adblue
Pump - If 100kw - 74kw - Adblue
Powercore Complete Air Filter 9"
Air Filter Assembly - If 100kw - 74kw Stage 4
Air Filter Assembly - If 100kw - 74kw Stage 5
Exchanger Assembly - If 100kw - 74kw
Exchanger Assembly - If 55kw
Control Unit Assembly - If 100kw - 74kw Stage 4
Control Unit Assembly - If 100kw - 74kw Stage 5
Control Unit Assembly - If 55kw
Diesel Pump Filters Assembly - If 100kw - 74kw Stage 4
Diesel Pump Filters Assembly - If 100kw - 74kw Stage 5
Diesel Pump Filters Assembly - If 55kw
Tank Assembly
Diesel Tank Kit - Before June 2023
Diesel Tank Kit - After July 2023
Chassis Assembly - A
Chassis Assembly - B
Oscillating Bridge Assembly
Boom Assembly - 17m
Fixed Boom Assembly - 17m
Fixed Boom Assembly - 17m - A
Fixed Boom Assembly - 17m - B
Fixed Boom Assembly - 17m - C
Assembly Extension I - 17m
Assembly Extension I - 17m - B
Assembly Extension I - 17m - C
Assembly Extension I - 17m - D
Assembly Extension Ii - 17m
Assembly Extension Ii - 17m - A
Assembly Extension Ii - 17m - B
Assembly Extension Ii - 17m - C
Assembly Extension Iii - 17m
Assembly Extension Iii - 17m - A
Assembly Extension Iii - 17m - B
Assembly Extension Iii - 17m - C
Assembly Extension Iii - 17m - D
Ballasts Assembly - 14-17m
Boom Containment Kit - 17m
Boom Containment Kit - 14m
Boom Assembly - 14m
Fixed Boom Assembly - 14m
Fixed Boom Assembly - 14m - A
Fixed Boom Assembly - 14m - B
Fixed Boom Assembly - 14m - C
Assembly Extension I - 14m
Assembly Extension I - 14m - A
Assembly Extension I - 14m - B
Assembly Extension I - 14m - C
Assembly Extension Ii - 14m
Assembly Extension Ii - 14m - A
Assembly Extension Ii - 14m - B
Arm Asssembly - 17m
Accessory Holder - Boom
Services Pump Suction - Casappa
Oil Tank
Boom Inclinometer
Casings And Protections Assembly - A
Casings And Protections Assembly - B
Engine Hood And Compartment Casing Assembly - If Stage 4
Engine Hood And Compartment Casing Assembly - If Stage 5
Pump-Engine Coupling Assembly
Cabin - Rear Casing - If 100kw - 74kw
Cabin - Rear Casing - If 55kw
Cabin - Windows And Wipers - If Closed Cabin
Cabin - Windows And Protections - If Open Cabin
Cabin - Rear View Mirror
Cabin - Door - If Closed Cabin
Cabin - Insulating Sponges
Cabin - Wrist Support/Joystick Controller - If Closed Cabin - Until June 2022
Cabin - Wrist Support/Joystick Controller - If Usa - From July 2022
Cabin - Mechanical Spring Seat - If Closed Cabin
Cabin - Mechanical Spring Seat - If Open Cabin
Cabin - Anti-Vibration Pads
Cabin - Levelling Device
Decal Kit
Safety Decals
Flip Chart Set
Load Chart Set
Color Codes
Faresin Spare Key List
Hydraulics
Danfoss Hydraulic Engine - A
Danfoss Hydraulic Engine - B
Hydroguide
Hydraulic Hose Schematic
Hydraulic Schematic Classic - 3b
Suspension Boom Hose Kit
Floating Boom Hose Kit
Rear Hydraulic Connection Hose Kit
Quick Release Hose Kit
Rear Axle Lock Hose Kit
Levelling Cylinder
Stabilizer Cylinder
Lifting And Compensation Cylinders - 14m
Lifting And Compensation Cylinders - 17m
Lifting Valve
Lifting Cylinder Floating Boom - 17m
Lifting Cylinder Suspension Boom - 17m
Lifting Cylinder Suspension Boom Schematic - 17m
Extension Cylinder - 14m
Extension Cylinder - 17m
Pilot Block
Bench Distributor
Tilting Cylinder
Hydrostatic Engine - 160cc
Hydrostatic Pump 71cc
Danfoss Hydrostatic Pump - A - If 100kw - 74kw
Danfoss Hydrostatic Pump - B - If 100kw - 74kw
Danfoss Hydrostatic Pump - A - If 55kw
Danfoss Hydrostatic Pump - B - If 55kw
Steering Valve Assembly
Power Steering Assembly
Hydraulic Service Pump Itake Pump - Casappa 51cc
Service Pump - Casappa
Distributor - A - If Usa
Distributor - B - If Usa
Distributor - A - Standard - No Usa
Distributor - B - Standard - No Usa
Distributor
Distributor - Dn85
In-Line Valve Assembly - If Usa
Proportiona Extension Distribution Dn85-5 Fr00 - Version 2
Hydraulic Manifold - Fr04
Electrical
Anti-Tilt System Sensor
Battery - If Stage 5
Battery - If Stage 4
Control Units/Display/Boards - If Closed Cabin
Control Units/Display/Boards - If Open Cabin
Fuse And Relay Holder
Fuse And Relay Holder Board - If Open Cabin
Fuse Holder Board - If Closed Cabin
Cabin - Heating And Ventilation - If Closed Cabin
Cabin - Accelerator Pedal - February 2023 And Before
Cabin - Accelerator Pedal - March 2023 And After
Cabin - Buttons And Dashboard - A - If Closed Cabin
Cabin - Buttons And Dashboard - B - If Closed Cabin
Cabin - Buttons And Dashboard - C - If Closed Cabin
Cabin - Buttons And Dashboard - If Open Cabin
Cabin - Various Components
Cabin - Mirror Spoiler Oc Work Lights Assembly - If Open Cabin
Pnp Wired Sensor
Engine - Deutz Tcd 3.6 Kw
Limit Switch Connector Wiring
Driver Seat Basic
Pushbutton Panel Basic
Frame Telaio Basic
Universal Cabin Roof Sheath
Plate Light Extension
Electrical Wiring - Deutz Engine Classic 74kw - 100kw - If Stage 5
Electrical Wiring - Deutz Engine Classic 74kw - 100kw - If Stage 4
Electrical Wiring - Deutz Engine Classic 55kw - Stage 4/5
Electrical Wiring - Battery Wire 2
Electrical Wiring - Battery Wire 1
Electrical Wiring - Distributor Interface Dinoil Classic Eda
Electrical Wiring - Pnp Sensor
Electrical Wiring - Joystick Controller Interface
Electrical Wiring - Guide Side If Open Cabin
Electrical Wiring - Guide Side If Close Cabin
Electrical Wiring - Frame If Open Cabin
Electrical Wiring - Frame If Close Cabin
Electrical Wiring - Levelling Keypad
Electrical Wiring - Levelling Frame Modified
Electrical Wiring - Air Conditioning
Electrical Wiring - Work Light Extension On Boom
Electrical Wiring - Keypad
Electrical Wiring - Stabilisers If Close Cabin - Fr04
Electrical Wiring - Stabilisers If Open Cabin - Fr04
Electrical Wiring - Roof - Only Open Cabin- Fr04
Electrical Wiring - Wired Blue Led
Electrical Wiring - License Plate Light
Wrist Rests Classic
Lights And Components - A
Lights And Components - B
Joystick Controller Classic
Options
Rear Axial Lock Assembly
Rear Axial Lock - A
Rear Axial Lock - B - Only With Prop Levelling Kit
Rear Axial Lock - C
Flat Face Quick Fittings - From November 2022 And After
Air Conditioning
Air Conditioning Compressor
Cabin - Air Conditioning Kit
Cabin - Protection Grid
Rear Towing Hook
Rear Electrical Outlet
Rear Hydraulic Outlet - Fr04
Boom Suspension
Floating Boom
Rapid Release
6-Way Electric Diverter
Accessory Holder Xtreme
Boom Peb 17m - Fr04
Boom Peb 14m - Fr04
Reversable Fan - If 100kw - 74kw
Reversable Fan - If 55kw
Water Pre-Heating
Double Hydraulic Plug On Boom
Prop Levelling Assembly
Proportional Bench Distributor - A - Fr04
Proportional Bench Distributor - B - Fr04
Grapple Assembly With Shoe Clamp 9660
Telematic
Boom Work Lights
Queen Cabin Work Lights
Schematics
Hydraulic Schematic - 55kw - 17m
Hydraulic Schematic - 55kw - 14m
Hydraulic Schematic - 74 Kw - 17m
Hydraulic Schematic - 74 Kw - 14m
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 1 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 2 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 3 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 4 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 5 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 6 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 7 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 8 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 9 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 10 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 11 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 12 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 13 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 14 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 15 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 16 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 17 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 18 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 19 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 20 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 21 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 22 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 23 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 24 Of 33
Electrical Schematic Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 25 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 26 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 27 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 28 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 29 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 30 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 31 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 32 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 33 Of 33
Appendix A:pages Index
Appendix B:parts Index
