Snorkel Telehandler SR1065 Parts Manual 1590218-000
Brand: Snorkel
Type of Machine: Telehandler
Model: Snorkel SR1065 Telehandler
Part Number: 1590218-000
Publication Date: 2023
Number of Pages: 552 Pages
Repair Parts
Mud Guard Kit - Stage 5
Mudguard Kit - Stage 3a
Wheels 22.5"
Chassis Assembly - A
Chassis Assembly - B
Rear Axle
Rear Axle - Box And Covers
Rear Axle - Differential
Rear Axle - Wheel Hub
Rear Axle - Brakes
Rear Axle - Steering Cylinder
Rear Axle - Swinging Supports
Front Axle
Front Axle Box And Covers
Front Axle - Spacer
Front Axle - Wheel Hub
Front Axle - Brakes
Front Axle - Steering Cylinder
Front Axle - Swinging Supports
Main Transmission Assembly
Steering Distributor
Steering Column
Parking Brake Accumulator
Brake Pedal
Braking Circuit Charge Valve
Air-Suspension Seat - If Closed Cabin
Abs - Front Plastics
Abs - Door Side Plastics
Abs - Engine Compartment Side Plastics - A
Abs - Engine Compartment Side Plastics - B
Abs - Rear Plastics
Abs - Cabin Roof Plastics
Universal Joint Shaft
Gearbox 357 Kit
Gearbox
Gears
Engine Hood And Compartment Casings Assembly - Stage 3a
Engine Hood And Compartment Casing Assembly - Stage 4
Casings And Protections Assembly - A - Stage 3a
Casings And Protections Assembly - B - Stage 3a
Casings And Protections Assembly - A - Stage 4
Casings And Protections Assembly - B - Stage 4
Boom Containment Kit
Ballast Assembly 9.70-10.65
Ballast Assembly 9.60
Engine - A - Deutz If 100kw-74kw Stage 4
Engine Assembly - Deutz Stage 4
Engine Assembly - Deutz Stage 3a
Engine Assembly - Deutz - If 100kw-74kw Stage 5
Engine - A - Deutz Stage 4
Engine Supports Assembly - Stage 4
Eat Assembly - Stage 4
Engine - A - Deutz Stage 3a
Engine - A - Deutz If 100kw-74kw Stage 5
Engine - B - Deutz Stage 4
Engine - B - Deutz Stage 3a
Engine Tcd3.6 L4 - 55kw - Deutz Stage 5
Ftp Engine Assembly Stage 3a
Fpt Engine - A - Stage 3a
Fpt Engine - B - Stage 3a
Fpt Engine Supports Assembly - Stage 3a
Engine Supports Assembly - Deutz Stage 3a
Pump-Engine Coupling Assembly - Stage 3a
Pump-Engine Coupling Assembly - Stage 4
Rosati Fan Assembly - A - Deutz Engine 55kw Stage 5
Fan Assembly - 100kw-74kw
Fan Assembly Stage 4
Fan Assembly - Stage 3a - Deutz
Fpt Fan Assembly - Stage 3a
Air Filter Assembly - Stage 4
Air Filter Assembly If 100kw-74 Stage 4
Air Filter Assembly - Stage 3a - Deutz
Fpt Air Filter Assembly - Stage 3a
Exchanger Assembly - Stage 4
Exchanger Assembly - Stage 3a - Deutz
Fpt Exchanger Assembly - Stage 3a
Control Unit Assembly
Diesel Pump Filters Assembly Stage 4
Fuel Pump And Filter Assembly - Stage 3a - Deutz
Fpt Fuel Pump And Filter Assembly - Stage 3a
Tailpipe - Stage 3a - Deutz
Fpt Tailpipe - Stage 3a
Exhaust Assembly - Stage 4
Exhaust Assembly - Stage 3a - Deutz
Exhaust Terminal
Diesel Tank Kit
Tank Assembly - Stage 4
Tank Assembly - Stage 3a
Tank Assembly - Adblue
Tank Components - Adblue
Tank Components - If 100kw-74kw - Adblue
Pump - Adblue
Linkage Connecting Rod Assembly Brand - Fr03
Boom Assembly - 10m
Boom Assembly - 9m
Boom Assembly - 9.40m
Fixed Boom Assembly - 9m
Fixed Boom Assembly - 9m - B1
Fixed Boom Assembly - 9m - B2
Fixed Boom Assembly - 9m - C
Fixed Boom Assembly - 9m - D1
Fixed Boom Assembly - 9m - D2
Fixed Boom Assembly - 10m
Fixed Boom Assembly - 10m - B1
Fixed Boom Assembly - 10m - B2
Fixed Boom Assembly - 10m - C
Fixed Boom Assembly - 10m - D1
Fixed Boom Assembly - 10m - D2
Extension Assembly - 10m
Extension Assembly - 10m - A
Extension Assembly - 10m - B1
Extension Assembly - 10m - B2
Extension Assembly - 9m
Extension Assembly - 9m - A
Extension Assembly - 9m - B1
Extension Assembly - 9m - B2
Extension Cylinder - 10m
Extension Cylinder - 9.40m
Extension Cylinder - 9m
Fixed Boom Assembly - 9.40m
Fixed Boom Assembly - 9.40m - B1
Fixed Boom Assembly - 9.40m - B2
Fixed Boom Assembly - 9.40m - C
Extension Assembly - 9.40m
Extension Assembly - 9.40m - A
Extension Assembly - 9.40m - B1
Extension Assembly - 9.40m - B2
Cabin - Abs
Cabin - Rear Casing - Stage 3a
Cabin - Rear Casing - Stage 4
Cabin - Windows And Wipers
Cabin - Door
Cabin - Vibration Dampers
Cabin - Mechanical Spring Seat - If Open Cabin
Cabin - Insulating Sponges
Cabin - Wrist Support/Joystick Controller - Until June 2022
Cabin - Wrist Support/Joystick Controller - From July 2022
Cabin - Levelling Device
Cabin - Heating And Ventilation
Cabin - Accelerator Pedal - Until February 2023 - Stage 4
Cabin - Accelerator Pedal - From March 2023 - Stage 4
Cabin - Mechanical Accelerator Pedal - Stage 3a
Cabin - Rear View Mirror
Cabin - Buttons And Dashboard - A
Cabin - Button And Dashboard - B
Cabin - Various Components
Accessory Holder
Accessory Holder - If Boom 9.40
Oil Tank
Levelling Diverter
Drive Block
Instruction For Color Code
Safety Decals
Faresin Spare Key List
Hydraulic
Hydraulic Manifold
Hydraulic Motor - A
Hydraulic Motor - B
Hydrostatic Pump - A
Hydrostatic Pump - B
Hydroguide
Levelling Cylinder
Compensation Cylinder - 9.70/10.65/9.60
Lifting Cylinder 9.40
Lifting Cylinder 9.60
Lifting Cylinder 9.70/10.65
Lifting Vavle Rexroth - If Boom 9.60/9.70/10.65
Lifting Valve Atlantic - If Boom 9.60/9.70/10.65
Service Pump - Stage 3a - Fpt
Service Pump - Stage 3a - Deutz
Service Pump - Stage 4
Usage Points Pump Intake - Stage 3a - Fpt
Usage Points Pump Intake - Stage 3a - Deutz
Usage Points Pump Intake - Stage 4
Distributor - A
Distributor - B
Electrical
Anti-Tilt System Sensor
Fuse-Holder Board - Stage 4
Fuse-Holder Board - Stage 3a
Fuse And Relay Holder - Stage 4
Fuse And Relay Holder - Stage 3a
Battery - Stage 4
Battery - Stage 3a
Control Units/Displays/Boards
Relay Board
74.9 Kw Fr03-04 Classic/Fr04 Hls - Stage 3a - Deutz
Air Conditioning Wiring - Stage 3a
Cb Rele Cand/Fuse - Stage 3a - Deutz
Cb 74,9 Kw Iveco Starting Engine Alter - Stage 3a - Deutz
Engine Electrical Wiring - Deutz 74kw-100kw
Electrical Wiring - Fr03-04 Hls Fr04 Driving Seat
Electrical Wiring - Fr03-04 Hls Fr04 Keypad
Electrical Wiring - Fr03-04 Hls Fr04 Frame
Electrical Wiring - Bw From Starter Engine To Fuse - Deutz
Electrical Wiring - Bw From Spark Plug Relay To Spark Plug - Deutz
Electrical Wiring - Bw From Fuse To Spark Plug Relay - Deutz
Electrical Wiring - Bw From Cabin Mass To Frame Mass
Electrical Wiring - Battery Switch
Electrical Wiring - Pnp Sensor
Electrical Wiring - Wired Blue Led
Electrical Wiring - Joystick Controller Interface
Electrical Wiring - Wired Plate Light
Electrical Wiring - Distributor Dinoil Classic Eda Interface
Electrical Wiring - Various - Stage 3a
Electrical Wiring - Various - Stage 4
Work Lights And Components - A
Work Lights And Components - B
Options
Rear Tow Hook
Rear Electrical Outlet
Rear Hydraulic Outlet
Air Conditioning - Stage 4
Air Conditioning Compressor - Deutz Stage 3a
Air Conditioning Compressor - Fpt Stage 3a
Air Conditioning Compressor - Stage 4
Cabin Air Conditioning Kit
Boom Suspension
Floating Boom
Quick Release - If Boom 9.70/10.65/9.60
Quick Release - If Boom 9.40
6-Way Electric Diverter - If Boom 9.70/10.65/9.60
6-Way Electric Diverter - If Boom 9.40
Reversible Fan - Deutz Stage 3a
Reversible Fan - Stage 4
Reversible Fan - Fpt Stage 3a
Water Pre-Heating - Stage 4
Water Pre-Heating - Iveco 93 Kw - Stage 3a
Grapple Assembly With Shoe Clamp 9660
Peb/Winch Setup
Hook Height Adjustment
Telematics
Queen Cabin Work Lights
Cabin Protection Grid
Schematics
Hydraulic Schematic - Stage 4
Hydraulic Schematic Classic 75 - Stage 3a
Hydraulic Schematic Classic 93 - Stage 3a
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Wheels 22.5"
Rear Axle
Rear Axle - Brakes
Front Axle
Front Axle - Spacer
Front Axle - Brakes
Steering Column
Brake Pedal
Abs - Rear Plastics
Gearbox 357 Kit
Gearbox
Gears
Exhaust Terminal
Diesel Tank Kit
Pump - Adblue
Boom Assembly - 10m
Boom Assembly - 9m
Cabin - Abs
Cabin - Door
Accessory Holder
Oil Tank
Levelling Diverter
Drive Block
Safety Decals
Hydraulic
Hydraulic Manifold
Hydraulic Motor - A
Hydraulic Motor - B
Hydroguide
Levelling Cylinder
Distributor - A
Distributor - B
Electrical
Battery - Stage 4
Battery - Stage 3a
Relay Board
Options
Rear Tow Hook
Boom Suspension
Floating Boom
Peb/Winch Setup
Telematics
Schematics
Appendix A
Appendix B
