Snorkel Telehandler SR1054 Parts Manual 159-0025-000
Brand: Snorkel
Type of Machine: Telehandler
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel SR1054 Telehandler
Part Number: 159-0025-000
Publication Date: 2022
Number of Pages: 958 Pages
Repair Parts
Rear Axle
Rear Axle
Rear Axle - Box And Covers
Rear Axle - Axial Body
Rear Axle - Steering Cylinder
Rear Axle - Caps And Steering Cylinder
Rear Axle - Bevel Gear
Rear Axle - Differential
Rear Axle - Double Joint
Rear Axle - Wheel Hub
Rear Axle - Planetary Reduction
Rear Axle - Brakes
Rear Axle - Swinging Supports
Front Axle - Wheel Hub
Front Axle
Front Axle
Front Axle - Box And Covers
Front Axle - Axle Body
Front Axle - Steering Cylinder
Front Axle - Caps And Steering Cylinder
Front Axle - Bevel Gear
Front Axle - Spacer
Front Axle - Spacer
Front Axle - Double Joint
Front Axle - Brakes
Front Axle - Brakes
Front Axle - Planetary Reduction
Front Axle - Transmission Box
Front Axle - Shafts And Gears
Front Axle - Swinging Supports
Wheels - 22.5"
Mud Guard Kit - Stage 5
Mud Guard
Main Transmission Assembly
Transmission Classic
Steering Distributor
Steering Column
Engine - Deutz - A - If 100kw - 74kw Stage 5
Eat Assembly (If 100kw - 74kw Stage Iv)
Engine - Deutz - If 100kw - 74kw Stage 5a
Eat Assembly - If 100kw - 74kw Stage 5a
Engine - Deutz - If 55kw Stage B
Engine - Deutz - If 100kw - 74kw Stage 4/5
Engine - Deutz - If 55kw - A
Engine Assembly - Deutz - If 55kw
Engine Supports Assembly
Engine Assembly - Deutz - If 100kw - 74kw Stage 4
Engine Assembly - Deutz - If 100kw - 74kw Stage 5
Engine Assembly - Deutz 90kw Tcd 3.6 L4
Engine Replacement Parts - Deutz 134hp Tcd3.6l4-Eat Tier 4 Final
Engine-Pump Coupling
Engine Exhaust - Deutz 90kw 3b
Abs - Engine Compartment Side Plastics - A - If Open Cabin
Abs - Engine Compartment Side Plastics - A - If Closed Cabin
Abs - Engine Compartment Side Plastics - B
Eat Assembly - If 100kw - 74kw Stage 5b
Eat Assembly - If 55kw
Braking Circuit Charge Valve
Parking Brake Accumulator - Fr03
Parking Brake Accumulator - Fr04
Brake Pedal
Abs - Front Plastics - If Closed Cabin
Abs - Front Plastics - If Open Cabin
Abs - Door Side Plastics - If Closed Cabin
Cabin Queen Cabin - Door 1
Cabin Queen Cabin - Door 2
Inner Coatings Cabin Classic
Casting And Protections
Chassis And Lights
Chassis And Pins
Gearbox 357 Kit
Gearbox - Fr03
Gears
Cardan Shaft
Abs - Rear Plastics - If Closed Cabin
Abs - Rear Plastics - If Open Cabin
Abs - Cabin Roof Plastics
Cabin - Insulating Sponges
Cabin - Mechanical Spring Seat - If Open Cabin
Cabin - Wrist Support/Joystick Controller - If Closed Cabin - Until June 2022
Cabin - Wrist Support/Joystick Controller - If Usa - From July 2022
Cabin - Levelling Device
Cabin - Rear View Mirror
Cabin - Rear Casing - If 100kw - 74kw
Cabin - Rear Casing - If 55kw
Cabin - Windows And Protections - If Open Cabin
Cabin - Windows And Wipers - If Closed Cabin
Cabin - Door - If Closed Cabin
Cabin - Anti-Vibration Pads
Cabin - Abs - If Open Cabin
Cabin - Abs - If Closed Cabin
Air Suspension Seat - If Closed Cabin
Fan Assembly - If 100kw - 74kw
Fan Assembly - If 55kw
Exhaust Assembly - If 55kw
Exhaust Terminal
Powercore Complete Air Filter 9"
Diesel Tank Kit - Before June 2023
Diesel Tank Kit - After July 2023
Tank Assembly - If 100kw - 74kw - Adblue
Pump - If 100kw - 74kw - Adblue
Air Filter Assembly - If 100kw - 74kw Stage 5
Air Filter Assembly - If 100kw - 74kw Stage 4
Exchanger Assembly - If 100kw - 74kw
Exchanger Assembly - If 55kw
Control Unit Assembly - If 100kw - 74kw Stage 5
Control Unit Assembly - If 100kw - 74kw Stage 4
Control Unit Assembly - If 55kw
Diesel Pump Filters Assembly - If 100kw - 74kw Stage 5
Diesel Pump Filters Assembly - If 100kw - 74kw Stage 4
Diesel Pump Filters Assembly - If 55kw
Tank Assembly
Chassis Assembly - A
Chassis Assembly - B
Oscillating Bridge Assembly
Assembly Extension Iii - 17m
Assembly Extension Iii - 17m - A
Assembly Extension Iii - 17m - B
Assembly Extension Iii - 17m - C
Assembly Extension Iii - 17m - D
Assembly Extension Ii - 17m
Assembly Extension Ii - 17m - A
Assembly Extension Ii - 17m - B
Assembly Extension Ii - 17m - C
Assembly Extension Ii - 14m
Assembly Extension Ii - 14m - A
Assembly Extension Ii - 14m - B
Assembly Extension I - 17m
Assembly Extension I - 17m - B
Assembly Extension I - 17m - C
Assembly Extension I - 17m - D
Assembly Extension I - 14m
Assembly Extension I - 14m - A
Assembly Extension I - 14m - B
Assembly Extension I - 14m - C
Ballasts Assembly - 14-17m
Boom Containment Kit - 14m
Boom Containment Kit - 17m
Boom Assembly - 9m
Fixed Boom Assembly - 9m
Fixed Boom Assembly - 9m - B1
Fixed Boom Assembly - 9m - B2
Fixed Boom Assembly - 9m - C
Fixed Boom Assembly - 9m - D1
Fixed Boom Assembly - 9m - D2
Extension Cylinder - 9m
Extension Assembly - 9m
Extension Assembly - 9m - A
Extension Assembly - 9m - B1
Extension Assembly - 9m - B2
Boom Assembly - 9.40m
Fixed Boom Assembly - 9.40m
Fixed Boom Assembly - 9.40m - B1
Fixed Boom Assembly - 9.40m - B2
Fixed Boom Assembly - 9.40m - C
Extension Assembly - 9.40m
Extension Assembly - 9.40m - A
Extension Assembly - 9.40m - B1
Extension Cylinder - 9.40m
Boom Assembly - 10m
Fixed Boom Assembly - 10m
Fixed Boom Assembly - 10m - B1
Fixed Boom Assembly - 10m - B2
Fixed Boom Assembly 10m (C)
Extension Assembly - 10m
Extension Assembly - 10m - A
Extension Asssembly - 10m - B1
Extension Assembly - 10m - B2
Extension Cylinder - 10m
Boom Assembly - 14m
Fixed Boom Assembly - 14m
Fixed Boom Assembly - 14m - A
Fixed Boom Assembly - 14m - B
Fixed Boom Assembly - 14m - C
Boom Assembly - 17m
Fixed Boom Assembly - 17m
Fixed Boom Assembly - 17m - A
Fixed Boom Assembly - 17m - B
Fixed Boom Assembly - 17m - C
Stabilizers Assembly
Linkage Connecting Rod Assembly Brand
Accessory Holder
Accessory Holder - Boom
Services Pump Suction - Casappa
Oil Tank
Levelling Diverter - Fr03
Casings And Protections Assembly - A
Casings And Protections Assembly - B
Engine Hood And Compartment Casing Assembly - If Stage 4
Engine Hood And Compartment Casing Assembly - If Stage 5
Pump-Engine Coupling Assembly
Assembly Arm - 14m
72" Rotating Carriage Assembly - Sr1054/Sr9244
72" Heavy Duty Carriage Assembly
60'' Wide Carriage Assembly - Fixed
Carriage Pin Assembly
6' Material Handler Jib Assembly
Boom Inclinometer
Exhaust Assembly - If 100kw - 74kw Stage 4
Flip Chart Set - Sr1054/Sr9244
Flip Chart Set - Sr1054/Sr9244 - French
Load Chart Set - Finish
Load Chart Set - French
Decal Kit - Final
Decal Kit - French
Safety Decals
Color Codes
Faresin Spare Key List
Hydraulics
Hydraulic Motor - A
Hydraulic Motor - B
Danfoss Hydraulic Engine - A
Danfoss Hydraulic Engine - B
Danfoss Hydrostatic Pump - A - If 100kw - 74kw
Danfoss Hydrostatic Pump - B - If 100kw - 74kw
Danfoss Hydrostatic Pump - A - If 55kw
Danfoss Hydrostatic Pump - B - If 55kw
Hydroguide
Hydraulic Hose Schematic
Suspension Boom Hose Kit
Floating Boom Hose Kit
Rear Hydraulic Connection Hose Kit
Quick Release Hose Kit
Rear Axle Lock Hose Kit
Levelling Cylinder
Stabilizer Cylinder
Extension Cylinder - 17m
Extension Cylinder - 14m
Tilting Cylinder
Lifting And Compensation Cylinders - 17m
Lifting And Compensation Cylinders - 14m
Lifting Cylinder 9.60
Lifting Cylinder 9.40
Lifting Cylinder 9.70/10.65
Compensation Cylinder 9.40
Lifting Valve
Pilot Block
Drive Block
Distributor - A
Bench Distributor
Hydrostatic Engine - 160cc
Steering Valve Assembly
Power Steering Assembly
Brake Pedal Assembly
Brake Accumulator Assembly
Pump - Casappa 51cc
Hydraulic Service Pump Itake Pump - Casappa 51cc
Service Pump - Casappa
Proportiona Extension Distribution Dn85-5 Fr00 - Version 2
Distributor - A - Standard - No Usa
Distributor - B - Standard - No Usa
Distributor - A - If Usa
Distributor - B - If Usa
Distributor
Distributor - Dn85
In-Line Valve Assembly - If Usa
Hydraulic Manifold - Fr04
Hydraulic Manifold - Fr03
Oil Tank Assembly
Electrical
Cabin - Heating And Ventilation - If Closed Cabin
Cabin - Accelerator Pedal - February 2023 And Before
Cabin - Accelerator Pedal - March 2023 And After
Cabin - Buttons And Dashboard - A - If Closed Cabin
Cabin - Buttons And Dashboard - B - If Closed Cabin
Cabin - Buttons And Dashboard - C - If Closed Cabin
Cabin - Buttons And Dashboard - If Open Cabin
Cabin - Various Components
Cabin - Mirror Spoiler Oc Work Lights Assembly - If Open Cabin
Anti-Tilt System Sensor
Battery - If Stage 5
Battery - If Stage 4
Control Units/Display/Boards - If Closed Cabin
Control Units/Display/Boards - If Open Cabin
Fuse Holder Board
Fuse Holder Board - If Closed Cabin
Fuse And Relay Holder Board - If Open Cabin
Relay Board
Joystick Controller Classic
Engine - Deutz Tcd 3.6 Kw
Pnp Wired Sensor
Limit Switch Connector Wiring
Driver Seat Basic
Pushbutton Panel Basic
Frame Telaio Basic
Universal Cabin Roof Sheath
Plate Light Extension
Electrical Wiring - Driving Seat
Electrical Wiring - Green Flashing Belt - Fr03
Electrical Wiring - Bw From Starter Engine To Fuse - Fr03 - Deutz
Electrical Wiring - Bw From Spark Plug Relay To Spark Plug - Deutz
Electrical Wiring - Bw From Fuse To Deutz Spark Plug Relay
Electrical Wiring - Bw From Cabin Mass To Frame Mass
Electrical Wiring - Battery Switch - Fr03
Electrical Wiring - Various - Fr03
Electrical Wiring - Deutz Engine Classic 74kw - 100kw - If Stage 5
Electrical Wiring - Deutz Engine Classic 74kw - 100kw - If Stage 4
Electrical Wiring - Deutz Engine Classic 55kw - Stage 4/5
Electrical Wiring - Battery Wire 1
Electrical Wiring - Battery Wire 2
Electrical Wiring - Distributor Interface Dinoil Classic Eda
Electrical Wiring - Pnp Sensor
Electrical Wiring - Joystick Controller Interface
Electrical Wiring - Guide Side If Open Cabin
Electrical Wiring - Guide Side If Close Cabin
Electrical Wiring - Frame If Open Cabin
Electrical Wiring - Frame If Close Cabin
Electrical Wiring - Levelling Keypad
Electrical Wiring - Levelling Frame Modified
Electrical Wiring - Air Conditioning
Electrical Wiring - Work Light Extension On Boom
Electrical Wiring - Keypad
Electrical Wiring - Stabilisers If Close Cabin - Fr04
Electrical Wiring - Stabilisers If Open Cabin - Fr04
Electrical Wiring - Roof - Only Open Cabin- Fr04
Electrical Wiring - Wired Blue Led
Electrical Wiring - License Plate Light
Wrist Rests Classic
Work Lights And Components - A
Work Lights And Components - B
Options
Rear Towing Hook
Rear Axial Lock Assembly
Rear Axial Lock - A
Rear Axial Lock - B - Only With Prop Levelling Kit
Rear Axial Lock - C
Rear Hydraulic Outlet - Fr03
Rear Hydraulic Outlet - Fr04
Rear Electrical Outlet
Air Conditioning
Air Conditioning Compressor
Hook Height Adjustment
Faresin Hook
Boom Suspension
Floating Boom
Quick Release - If Boom 9.70/10.65/9.60
Rapid Release
6-Way Electric Diverter - If Boom 9.70/10.65/9.60 - Fr03
Accessory Holder Xtreme
Boom Peb 17m - Fr04
Boom Peb 14m - Fr04
Peb/Winch Setup
Cabin - Air Conditioning Kit
Cabin - Protection Grid
Reversable Fan - If 100kw - 74kw
Reversable Fan - If 55kw
Water Pre-Heating
Double Hydraulic Plug On Boom
Prop Levelling Assembly
Proportional Bench Distributor - A - Fr04
Proportional Bench Distributor - B - Fr04
Telematic
Kit Large Faresin Bobcat Fittings
Queen Cabin Work Lights
Boom Work Lights
Grapple Assembly With Shoe Clamp 9660
Star Bucket-Load Charts
Schematics
Hydraulic Schematic
Hydraulic Schematic - 55kw - 14m
Hydraulic Schematic - 55kw - 17m
Hydraulic Schematic - 74 Kw - 14m
Hydraulic Schematic - 74 Kw - 17m
Hydraulic Schematic - 74 Kw - Sr1054
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 1 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 2 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 3 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 4 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 5 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 6 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 7 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 8 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 9 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 10 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 11 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 12 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 13 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 14 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 15 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 16 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 17 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 18 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 19 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 20 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 21 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 22 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 23 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 24 Of 33
Electrical Schematic Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 25 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 26 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 27 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 28 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 29 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 30 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 31 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 32 Of 33
Electrical Schematic - Sr1054/Sr9244 - Deutz Tier 4 Final 74.4 Ct38a5697 - 33 Of 33
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Rear Axle
Rear Axle
Rear Axle - Brakes
Front Axle
Front Axle
Front Axle - Spacer
Front Axle - Spacer
Front Axle - Brakes
Front Axle - Brakes
Wheels - 22.5"
Mud Guard
Steering Column
Brake Pedal
Chassis And Lights
Chassis And Pins
Gearbox 357 Kit
Gearbox - Fr03
Gears
Cardan Shaft
Exhaust Terminal
Tank Assembly
Boom Assembly - 9m
Boom Assembly - 10m
Boom Assembly - 14m
Boom Assembly - 17m
Accessory Holder
Oil Tank
Assembly Arm - 14m
Boom Inclinometer
Decal Kit - Final
Decal Kit - French
Safety Decals
Color Codes
Hydraulics
Hydraulic Motor - A
Hydraulic Motor - B
Hydroguide
Levelling Cylinder
Stabilizer Cylinder
Tilting Cylinder
Lifting Valve
Pilot Block
Drive Block
Distributor - A
Bench Distributor
Pump - Casappa 51cc
Distributor
Distributor - Dn85
Oil Tank Assembly
Electrical
Fuse Holder Board
Relay Board
Pnp Wired Sensor
Driver Seat Basic
Frame Telaio Basic
Wrist Rests Classic
Options
Rear Towing Hook
Rear Axial Lock - A
Rear Axial Lock - C
Air Conditioning
Faresin Hook
Boom Suspension
Floating Boom
Rapid Release
Boom Peb 17m - Fr04
Boom Peb 14m - Fr04
Peb/Winch Setup
Water Pre-Heating
Telematic
Boom Work Lights
Schematics
Hydraulic Schematic
Appendix A
Appendix B
