Snorkel Scissor Lifts S9043RT Parts Manual 1442999-000
Brand: Snorkel
Type of Machine: Scissor Lift
Type of Manual: Parts Manual, Electrical Diagram
Model: Snorkel S9043RT Scissor Lift
Part Number: 1442999-000
Publication Date: 2022
Number of Pages: 876 Pages
Repair Parts
Generic Assembly - Pg
Generic Assembly - Parker
Chassis Assembly - Rt Series - Pg
Chassis Assembly - Rt Series - Parker
Oscillating Axle Assembly - Rt Series
Engine And Cabinet Installation - Kubota V1605 - Dual Fuel - Pg - June 2025 And Before
Engine And Cabinet Installation - Kubota V1605 - Dual Fuel - Pg - July 2025 And After
Engine And Cabinet Installation - Kubota V1605 - Dual Fuel - Parker
Engine And Cabinet Installation - Kubota V1505 - Stage 5 - Pg
Engine And Cabinet Installation - Kubota V1505 - Stage 5 - Parker
Engine Cabinet Assembly - Kubota V1605 - Dual Fuel
Engine Cabinet Assembly - Kubota V1505 Stage 5
Engine Cabinet Back Panel Assembly - Kubota V1605 - Dual Fuel
Engine Cabinet Back Panel Assembly - Kubota V1505 Stage 5
Engine Side Ladder Assembly - S9033rt/S9043rt
Engine Tray Assembly - Kubota V1605 - Dual Fuel
Engine Tray Assembly - Kubota V1505 Stage 5
Engine Assembly - Dual Fuel V1605 - November 2023 And Before
Engine Assembly - Dual Fuel V1605 - December 2023 And After
Engine Assembly - Kubota V1505 Stage 5 - Diesel Engine
Engine Assembly - Kubota Diesel V1505 - Eaton Gear Pump 15 Cc - February 2025 And After
Engine Assembly - Kubota Diesel V1505 - Bucher Gear Pump 19.2 Cc - December 2023 And After
Engine Assembly - Kubota Diesel V1505 - Bucher Gear Pump 19.2 Cc - November 2023 And Before
Engine - Kubota V1505 Skl
Throttle Solenoid Assembly - Kubota
Lower Fan Kit Assembly - Kubota V1505 Skl-1 V1505-25hp Wg1605 Df
Bell Housing Assembly - Kubota
Radiator Kit - Kubota
Fuel Tank Assembly
Liquid Propane Tank Mount Assembly
Stabilizer Assembly - Pg
Main Deck Assembly
Main Deck Double Extend Assembly
Extension Deck Assembly - Single
Extension Deck Assembly - Dual
End Rail Assembly
4-Stack Scissor Assembly Pg - July 2023 And Before
4-Stack Scissor Assembly Pg - August 2023 And After
4-Stack Scissor Assembly - Parker - July 2023 And Before
4-Stack Scissor Assembly - Parker - August 2023 And After
Stack Slider Pad Assembly
Stack Slide Pad Assembly
Centering Arm Assembly
Safety Prop Assembly
Deck Ring Assembly
Single Extension Deck Assembly
Dual Extension Deck Assembly
Platform Extension Wire Channel Assembly
Decal Assembly Kit - Single Extension Deck - English
Decal Assembly Kit - Single Extension Deck - Chinese
Decal Assembly Kit - Single Extension Deck - Japanese
Decal Assembly Kit - Single Extension Deck - German
Decal Assembly Kit - Single Extension Deck - Spanish
Decal Assembly Kit - Single Extension Deck - French
Decal Assembly Kit - Dual Extension Deck - English
Decal Assembly Kit - Dual Extension Deck - Chinese
Decal Assembly Kit - Dual Extension Deck - Japanese
Decal Assembly Kit - Dual Extension Deck - Spanish
Decal Assembly Kit - Dual Extension Deck - French
Decal Assembly Kit - Dual Extension Deck - German
Decals Assembly Kit - Dual Fuel - English Language - Includes French/Spanish/German/Japanese/Chinese Language Kits In Chart
Decals Kit Assembly - Dual Fuel - Dual Extension - English Language - Includes French/Spanish/German/Japanese/Chinese Language Kits In Chart
Hydraulic
Gear Hub Assembly
Drive Motor - 15.1cc/Rev Hyd Rt
Oscillating Cylinder
Steer Cylinder
Hydraulic Cabinet Assembly - Parker
Hydraulic Cabinet Assembly - Pg
Hydraulic Side Ladder Assembly - S9033rt/S9043rt
Hydraulic Reservoir Assembly - 30 Gallon
Hydrostatic Pump - Hengli
Dual Platform/Stack Hydraulics/Electrical Installation - Pg - June 2025 And After
Dual Platform/Stack Hydraulics/Electrical Installation - Pg- May 2025 And Before
Dual Platform/Stack Hydraulics/Electrical Installation - Parker - June 2025 And After
Dual Platform/Stack Hydraulics/Electrical Installation - Parker - May 2025 And Before
Single Platform Stack Hydraulic/Electrical Installation Assembly - Pg - June 2025 And After
Single Platform Stack Hydraulic/Electrical Installation Assembly - Pg - May 2025 And Before
Single Platform Stack Hydraulic/Electrical Installation Assembly - Parker - June 2025 And After
Single Platform Stack Hydraulic/Electrical Installation Assembly - Parker - May 2025 And Before
Main Manifold And Stabilizer Installation - Fluidtech
Main Manifold And Stabilizer Installation - Hydac
Lift Manifold Assembly
Lift Cylinder- Hengli
Manifold Pressure Relief Assembly
Rt Chassis Hydraulic/Electrical Installation Assembly - Pg - May 2025 And Before
Rt Chassis Hydraulic/Electrical Installation Assembly - Pg - June 2025 And After
Rt Chassis Hydraulic/Electrical Installation Assembly- Parker - June 2025 And After
Rt Chassis Hydraulic/Electrical Installation Assembly - Parker - May 2025 And Before
Extension Deck Cylinder - Hengli
Electrical
Chassis Harness - Pg - Rt
Chassis Harness Rt - September 2022 And After
Chassis Harness - Parker
Stabilizer Retrofit Harness - Pg
Stabilizer Option Harness - Parker
Angle Harness - November 2022 And After
Engine Harness - Kubota V1505 Stage 5 - Diesel
Engine Harness - Kubota Wg1605 / Wg2503 Dual Fuel - July 2025 And After
Engine Harness - Wg1605/Wg2503 - Dual Fuel - June 2025 And Before
Generator Harness
Emergency Power Unit Assembly
Switch Pigtail, 2-Pos Harness
Stack Harness - October 2022 And Before
Stack Harness - S9043rt/S9043rt-Hc - November 2022 And After
Cylinder Harness
Control Panel Assembly - V1505 - Pg
Control Panel Assembly - V1505 - Parker
Control Panel Assembly - V1605 - Pg
Control Panel Assembly - V1605 - Parker
Lower Control Panel Assembly - Pg
Lower Control Panel Assembly - Parker
Push/Pull Assembly With Contact
Platform Control Cable Harness Rt - Pg
Control Box Cord Harness - Pg
110 Volt Ac Plug Single Extension Deck - Us/Japan
110 Volt Ac Plug Dual Extension Deck - Us/Japan
Upper Control Box Harness - Dual Fuel - Pg
Upper Control Box Harness - Dpf - Pg
Upper Control Box Harness - Parker - October 2022 And Before
Upper Control Box With Stabilizers Assembly - Dpf - Pg
Upper Control Box Without Stabilizers Assembly - Dpf - Pg
Upper Control Box Without Stabilizers Assembly - Pg
Upper Control Box Without Stabilizers Assembly - Dual Fuel - Pg
Upper Control Box Harness - Parker - November 2022 And After
Upper Control Box With Stabilizers Assembly - Parker
Upper Control Box Without Stabilizers Assembly - Dpf - Parker
Upper Control Box With Stabilizers Assembly - Dual Fuel -Parker
Upper Control Box Without Stabilizers Assembly - Dual Fuel - Parker
Upper Control Box With Stabilizers Assembly - Dual Fuel - Pg
Upper Control Box Rt And Hc Light Harness - Pg
Amber Beacon Assembly - Ansi
Options
Marking Rt Tires
Non-Marking Rt Tires
2.5kw Generator - V1605 Dual Fuel
2.5kw Generator - V1505
7.5kw Hydraulic Generator Option - With Stabilizers - Retrofit - Parker
7.5kw Generator Option - No Stabilizers - Retrofit - Parker
7.5kw Hydraulic Generator Option - Retrofit - With Stabilizers - Pg
7.5kw Hydraulic Generator Option - Retrofit - Without Stabilizers - Pg
7.5kw Generator - Electrical Panel
7.5kw Generator Enclosure Assembly
Stabilizer Retrofit - Fluidtech Manifold - Pg - June 2024 And After
Stabilizer Retrofit - Fluidtech Manifold - Pg - May 2024 And Before
Stabilizer Retrofit - Fluidtech Manifold - Parker - June 2024 And After
Stabilizer Retrofit - Fluidtech Manifold - Parker - May 2024 And Before
Stabilizer Retrofit - Hydac Manifold - Parker
Stabilizer Retrofit - Hydac Manifold - Pg
Stabilizer Pad Box Option Assembly
Stabilizer Pads Option - Rt
Cold Weather Option - Parker
Cold Weather Option - Rt - Pg
Cold Weather Option - With Stabilizers - Rt - Pg
Cold Weather Option - With Stabilizers - Rt - Parker
Cold Weather Option - Stage 5 - Rt - Parker
Cold Weather Option - Stage 5 - Rt - Pg
Cold Weather Option - Stage 5 - With Stabilizers - Rt -Pg
Cold Weather Option - Stage 5 - With Stabilizers - Rt - Parker
Trackunit - Rt Series
110-130 Volt Ac Plug - Dual Extension Deck - Eu - S9043rt
110-130 Volt Ac Plug - Single Extension Deck - Eu
220 Volt Ac Scraping Earth Plug - Dual Extension Deck - Eu
220 Volt Ac Scraping Earth Plug Assembly - Single Extension Deck - Eu
220 Volt Ac Plug Assembly - Dual Extension Deck - Eu
220 Volt Ac Plug Assembly - Single Extension Deck - Eu
Single Gate Option
Saloon Gate Option
Light Option - Rt-Hc - Pg
Decals Stabilizer Assembly
Schematics
Electric Schematic - S9033rt/S9043rt - Pg
Electric Schematic - S9033rt/S9043rt/S9053rt - Parker
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Fuel Tank Assembly
Main Deck Assembly
End Rail Assembly
Deck Ring Assembly
Hydraulic
Gear Hub Assembly
Steer Cylinder
Electrical
Generator Harness
Cylinder Harness
Options
Marking Rt Tires
Single Gate Option
Saloon Gate Option
Schematics
Appendix A
Appendix B
