Snorkel Scissor Lifts S4740E Parts Manual 1503711-000
Brand: Snorkel
Type of Machine: Scissor Lift
Type of Manual: Parts Manual, Electrical Diagram, Hydraulic Diagram
Model: Snorkel S4740E Hydraulic And Electric Drive Scissor Lift
Serial Number: 000000 and after
Part Number: 1503711-000
Publication Date: 2022
Number of Pages: 369 Pages
Repair Parts
Tire And Wheel Assembly
Hydraulic Drive Chassis Assembly
Hydraulic Drive Tray Installation
Hydraulic Drive Tray Installation - S4740 Hc
Hydraulic Drive Assembly - Ansi 92.20/Ce/Csa/As
Hc Assembly Chassis
Rollout Front Platform
Chassis Weldment Bearing - Ss4726e/S4732e/S4740e
Front Counterweight Cast Assembly
Front Counterwight Platform Assembly
Tank Tray Wide Lg Assembly
Lynch Pin With Lanyard Assembly
Valve Tray Assembly Wide - October 2020 And After
Valve Tray Wide Assembly
Stack Assembly High-Capacity
Stack Assembly Installation
Stack Assembly
Stack Installation Assembly - Electric Drive - High Capacity
Stack Arms Kit
Control Tray Assembly - Ez300
Platform Assembly - S4726e-04-210901152 And S4732e-04-211002432 And After
Folding Handrail Assembly - Ansi 92.20/Csa
Folding Handrails Assembly With Removable Upper Control Box - Ansi 92.20/Csa
Folding Handrails Assembly With Removable Upper Control Box - Ce/As
Folding Handrails Assembly - Ce/As
Saloon Gates Assembly - Ansi 92.20/Ce/Csa - S4726e-04-210901152 And S4732e-04-211002432 And After
Single Gate Assembly - Ce/As
Brush Assembly
Decals Assembly - Ansi 92.20/Csa - Extra Capacity
Decals Assembly - Ansi 92.20/Csa - Extra Capacity - Spanish
Decals Assembly - Ansi 92.20/Csa - Extra Capacity - French
Decals Assembly - Ansi/Csa 92.20 - June 2020 And After
Decals Assembly - Ansi/Csa 92.20 - June 2020 And After - French
Decals Assembly - Ansi 92.20/Csa - June 2020 And After - Spanish
Decals Assembly - As
Decals Assembly - Ce
Decals Assembly - Ce - German
Hydraulic
Scissor Manifold Two-Speed Assembly - Fluid Tech
Steer Cylinder - Rosenboom/Pb
Hydraulic Hose Kit
Lift Cylinder Lower - Rosenboom
Lift Cylinder Upper - Rosenboom
Brake Dali
Electrical
Stack Harness
Chassis Harness - Ez230/Ez300
Harness - 110v Jumper
Tabulated Battery Cables
Pressure Sensor 2 Connector Retrofit
Pressure Sensor 3 Connector Retrofit
Drive Control Pendant
Lower Control Panel Assembly - Ansi 92.20/Csa/Ce/As
Upper Control Box Assembly - Two-Speed - Ansi/Ce
Upper Control Box Connector - Two-Speed - Ansi
Upper Control Box Assembly - Two-Speed - Ce - August 2018 And After
Snorkel Guard Upper Control Box Harness
Ultrasonic Secondary Guard Stack Harness
Options
Bumpguard Assembly - S4726e/S4740e
Trackunit Access Connector - S4726e/S4732e/S4740e
Trackunit/Keypad Installation
Lithium Battery - 1 - S3215e/S3219e
Control Tray Assembly Sem300 - Ansi 92.20 Csa/Ce/As - July 2023 And Before
Control Tray Assembly Sem301 - Ansi 92.20 Csa/Ce/As - August 2023 And After
Electric Drive Field Harness
Electric Drive Assembly - Ansi 92.20 - Csa/Ce/As
Electric Drive Chassis Assembly
Electric Drive Tray Installation - S4740 - Hc
Electric Drive Valve Tray Assembly
Electric Drive Chassis Harness - Sem300
Electric Drive Decals Assembly - Ansi 92.20/Csa/As
Electric Drive Decals Assembly - Ansi 92.20/Csa - June 2020 And After
Electric Drive Decals Assembly - Ansi 92.2/Csa - June 2020 And After - French
Electric Drive Decals Assembly - Ansi 92.2/Csa - June 2020 And After - Spanish
Electric Drive Decals Assembly - Ce
Electric Drive Decals Assembly - Ce - German
Electric Drive Decals - Extra Capacity - Ansi 92.20/Csa
Electric Drive Decals - Extra Capacity - Ansi 92.20/Csa - Spanish
Electric Drive Decals - Extra Capacity - Ansi 92.20/Csa - French
Electric Drive Decals Assembly - Extra Capacity - Ce
Electric Drive Decals Assembly - Extra Capacity - Ce - German
Ultrasonic Sensor - Metric Assembly
Ultrasonic Sensor - Imperial Assembly
Platform - Narrow Assembly
Single Gate - Narrow Assembly
Folding Handrail - Narrow Assembly
Snorkel Guard Assembly - Non-Removable 6-Pin - Ansi 92.20/Csa
Snorkel Guard - Removable 8-Pin - Ansi 92.20/Csa
Snorkel Guard - Removable 8-Pin - Ce/As
Upper Control Box With Snorkel Guard Assembly - Ce/As
Upper Control Box Assembly With Snorkel Guard - Ce - October 2018 And After
Snorkel Guard Platform Control Box Two-Speed Assembly - Ansi - August 2018 And After
Snorkel Guard Assembly - Non-Removable 6-Pin - Ce/As
Top Rail Wide
Pipe Rack Wide - May 2019 And After
Light Package Installation
Amber Beacon Assembly - Ansi
Safety Light Installation
Blue Safety Light Assembly
Schematics
Electric Schematic
Electrical Schematic Telematics
Hydraulic Schematic - Electric Drive
Hydraulic Schematic Uses - S3215l/S3215e/S3219e/S3220e/S3226e/S4726e/S4732e
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Hc Assembly Chassis
Stack Assembly
Stack Arms Kit
Brush Assembly
Hydraulic
Hydraulic Hose Kit
Brake Dali
Electrical
Stack Harness
Options
Top Rail Wide
Schematics
Electric Schematic
Appendix A
Appendix B
