Snorkel Scissor Lifts S3370RT BUILDERS Parts Manual 1441817 2017
Brand: Snorkel
Type of Machine: Scissor Lift
Type of Manual: Parts Manual, Electrical Diagram, Hydraulic Diagram
Model: Snorkel S3370RT Scissor Lift
Part Number: 1441817
Publication Date: 2017
Number of Pages: 252 Pages
Builders Front
Repair Parts
Omni Power Wheel Assembly - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Chassis Assembly - From Sn S3370rt-07-180300500 - Version 7
Swing Arms Assembly - From Sn S3370rt-07-180300500 - Version 7
Steer Assembly - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Steer Assembly - From Sn S3370rt-07-180300500 - Version 7
High Torque Drive - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
High Torque Drive - October 2019 And After
Stabilizer Assembly - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Stabiliser Assembly - From Sn S2770rt-07-170400274 S3370rt-07-170100284 S3970rt-07-170200180 - Version 5/6
Stabliliser Assembly - From Sn S3370rt-07-180300501 - Version 7
Emergency Bleed Down Builders
Cabinets Assembly
Cabinets Assembly - From Sn S3370rt-07-180300500 - Version 7
Engine Cabinet - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Engine Cabinet Assembly - From Sn S3370rt-07-180300500 - Version 7
Engine Assembly - From Sn S3370rt-07-170100252 To S3370rt-07-170400306 - Kubota D902 Tier 4 Final
Diesel Engine Assembly - From Sn S3370rt-07-180300500 - Kubota D902 Tier 4 Final - Version 7
Replacement Parts - Kubota D902 Tier 3 And 4
Hydraulic Cabinet - Version 7
Hydraulic Cabinet Assembly - From Sn S3370rt-07-180300500 - Version 7
Hydraulic Fluid Reservoir
Hydraulic Fluid Reservoir Assembly - From Sn S3370rt-07-180300500 - Version 7
Diesel Fuel Tank Assembly
Diesel Fuel Tank Assembly - From Sn S3370rt-07-180300500 - Version 7
Toolbox Tray Assembly - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Block Heater Upgrade
Trombetta Throttle Kit - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Base Stack Platform - 30mm Pins
Base/Stack/Platform Assembly - From Sn S3370rt-07-180300500 - Version 7
Scissor Stack Assembly - 30mm Pins
Scissor Stack Assembly - From Sn S3370rt-07-180300500 - Version 7
Scissor Stack Tees
Platform Assembly - 30mm Pins - Version 6
Platform Rear Handrail Assembly
Platform Rear Handrail Asssembly - From Sn S3370rt-07-180300500 - Version 7
Ladder
Rail Ladder Assembly
Wood Rack Installation
Decals/Placards - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Decals/Placards - From Sn S3370rt-07-180300500 - Version 7
Morton - 500 Hour Engine Service
Morton - Yearly Service
Hydraulics
12570 Drive Motor
12571 Drive Motor W/Brake
Mico Wheel Brakes
Main Manifold - With Fittings - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Main Manifold - With Fittings - From Sn S3370rt-07-180300500 - Version 7
Main Manifold - No Fittings - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Main Manifold - No Fittings - From Sn S3370rt-07-180300500 - Version 7
High Torque Valve Assembly - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
4wheel Drive Manifold With Fittings - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
4wheel Drive Manifold - With Fittings - From Sn S3370rt-07-180300500 - Version 7
4wheel Drive Manifold - No Fittings - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
4wheel Drive Manifold - No Fittings - From Sn S3370rt-07-180300500
Auto Stabiliser Manifold - No Fittings - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Auto Stabiliser Manifold - With Fittings
Hydraulic Electrical Assembly - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Hydraulic Cylinders And Seal Kits
Steer Cylinder Assembly
Axle Cylinder Assembly
Stabiliser Cylinder Assembly - Version 5
Lower Lift Cylinder
Upper Lift Cylinder - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Upper Lift Cylinder Assembly - From Sn S3370rt-07-180300500 - Version 7
Hose Tags - From Sn S3370rt-07-180300500 - Version 7
Hose Part Numbers And Colour Codes - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Electrical
Gp400 Menu Adjustments
Wg752 Engine Harness - With Woodward Throttle Solenoid
Lower Control Box - Ce/As/Nz - Diesel
Flow Control Harness
Upper Control Box - 14023-02 - Ansi - Diesel
Looms
Control Loom
Options
Cold Weather Block Heater Battery Warmer
High-Torque - Non-Mark - From Sn S3370rt-07-170100252 To S3370rt-07-170400306 - Sxx70
Maintenance
Maintenance
Schematics
Builders Electrical Schematic With Outrigger - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Builders Electrical Schematic Lower Control Box - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Builders Electrical Schematic Engine Tier Three Tier Four - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Builders Electrical Schematic Upper Control Box - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Builders Hydraulic Schematic - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Builders Hydraulic Schematic Added Drive Flow Control Valves - From Sn S3370rt-07-170100252 To S3370rt-07-170400306
Wiring Schematic - From Sn S3370rt-07-180300500 - Version 7
Hydraulic Schematic - From Sn S3370rt-07-180300500 - Version 7
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Builders Front
Repair Parts
Cabinets Assembly
Scissor Stack Tees
Ladder
Hydraulics
12570 Drive Motor
Mico Wheel Brakes
Lower Lift Cylinder
Electrical
Looms
Control Loom
Options
Maintenance
Maintenance
Schematics
Appendix A
Appendix B
