Momed80
150
35,046
Snorkel Scissor Lifts S3219E 2014-2015 Parts Manual 1502788 2017
Brand: Snorkel
Type of Machine: Scissor Lift
Type of Manual: Parts Manual, Electrical Diagram, Hydraulic Diagram
Model: Snorkel S3219E 2014-2015 Scissor Lift
Serial Number: 000000 and after
Part Number: 1502788
Publication Date: 2017
Number of Pages: 420 Pages
General Information 2015
Repair Parts
Chassis Assembly - Ce - December 2015 And Before
Chassis Assembly - Ansi - Sn 04-002295 And Before
Chassis Stack Assembly - Ansi - Sn 3219e-04-002295 And Before
Overtravel Assembly
Overtravel Assembly - S3215e/S3219e/S3220e/S3226e - Sn S3215e-04-000001 Through S3215e-04-170200003, S3219e-04-000001 Through S3219e-04-001229
Valve Tray Assembly Two-Speed - October 2018 And Before
Rear Tray Installation - Ansi - S3215e/S3219e
Rear Tray Assembly - Ansi - Sn 3219e-04-002295 And Before
Rear Tray Assembly - Service Use 150198428 For Chassis Harness - Ansi
Rear Tray Assembly - January 2019 And After
Rear Tray Assembly - Ce/As
Trays Installation - Ce - March 2015 And Before
Control Tray Assembly - S3215e/S3219e - As/Ce - March 2015 And After
Trays Installation - Ce - April 2015 And After
Trays Assembly - S3215e/S3219e - Ansi/Csa - Uses 1502147 Valve Tray Assembly
Trays Installation And Assembly - S3215e/S3219e - Ansi/Ce/As - Uses 1502148 Valve Tray Assembly
Tank Tray Assembly - S3215e/S3215l/S3219e - June 2018 And After
Tank Tray Assembly - Ansi/Ce - Sn 3219e-04-001543 Through Current - 6029696 Wuxi Pump
Stack Installation - Ansi - January 2015 And Before
Stack Installation - Ansi - February 2015 And After
Stack Installation - Ansi/Ce/As - Sn 3219e February 2015 And After
Stack Installation - Ansi/Csa - March 2019 And Before
Stack Installation - Ce/As
Stack Assembly - Ansi/Ce/As - Sn 3219e-04-000001 Through Current
Stack Assembly - China
Lynch Pin With Lanyard Assembly
Upper Control Add On Assembly - Ce - July 2015 And Before
Platform Add On Assembly - Ce - August 2015 And After
Platform Add On Assembly - Ce - December 2015 And After
Platform Assembly - S3215e/S3219e - January 2017 And Before - Ansi/Ce/As
Platform Add On Assembly - As
Handrails Assembly - S3215e/S3219e - As - April 2018 And Before
Handrails Assembly - Ansi/Csa - July 2015 And Before
Handrails Assembly - S3215e/S3219e - Ansi/Csa - August 2015 And After
Non-Folding Handrails Assembly - S3215e/S3215l/S3219e - April 2018 And Before - Ansi
Folding Handrails Assembly - Ansi - S3215e/S3219e
Saloon Gates Assembly - S3215e/S3215l/S3219e - Ansi
Single Swing Gate Assembly - S3215e/S3219e - As
Single Gate Assembly - S3215e/S3219e - China
Decals Assembly - Csa/English
Decals Assembly - Csa/French
Decals Assembly - Ansi - January 2015 And Before
Decals Assembly - Ce - August 2015 And Before - English
Decals Assembly - Ce/French
Decals Assembly - Ce/China
Decals Assembly - September 2019 And Before - German
Decals Assembly - October 2019 And After - Spanish
Hydraulics
Manifold Single Speed Hawe - Sn 3219e-04-000001 Through S3219e-04-002295
Drive Motor White - July 2014 And After
Brake Dali
Brake Hub White - January 2015 And After
Hose Assembly
Pump Unit Bucher 24vdc 4.33cc - Sn 3219e-04-001542 And Before
Pump Unit 24vdc 4.33cc - Wuxi
Lift Cylinder - Rosenboom
Lift Cylinder - Hengli
Lift Cylinder - Fisher
Lift Cylinder - Pb/Ce
Steer Cylinder - Rosenboom/Pb
Electrical
Chassis Harness - Ansi - December S3219e-04-000001 Through S3219e-04-002295
Lower Control Panel Assembly - Ansi/Ce/As - S3219e-04-002296 And After
Lower Control Panel - Ansi/Ce/As - Sn 3219e-04-002295 And Before
Lower Control Harness
Loading Control Panel Assembly - August 2015 And After
Stack Harness Assembly - July 2018 And Before
Stack Harness Assembly - Ansi Units
Harness - 110v Jumper
Side Drive Rear Assembly - Sn 3219e - September 2015 And After - Ansi/As
Side Drive Override Connector
Drive Control Pendant
110v Assembly - China
Upper Control Box Harness
Upper Control Box Assembly - One-Speed - Ansi - June 2017 And Before
Upper Control Box Connector - Two-Speed - Ce/As - September 2018 And Before
Joystick Controller
Options
Maintenance Free Battery
Charger Interlock Delete - Ansi
Connector Charger Interlock Delete
Locking Battery And Rear Tray
Rear Tray Cover Installation
6h Plug And Socket
Plug - Australia/New Zealand
Environmentally Safe Oil - S3215e/S3215l/S3219e
Inverter Assembly - S3215e/S3219e
Inverter Assembly - S3215l/S3215e/S3219e
Scratch Guard - S3215e/S3219e
Angle Transducer Cover
Overload - May 2016 And After
Single Gate Assembly - S3215e/S3219e - Ce
Saloon Gates Assembly - S3215e/S3219e - Ce
Brush Assembly
Gravity Gate Assembly - S3215e/S3219e
Swing Gate - S3215/3219e - Ce
Panel Carrier
Airline
Pipe Rack Narrow
Pipe Rack Narrow
Handrails Assembly - S3215e/S3219e - Ce - June 2018 And Before
Handrails Assembly - S3215e/S3219e - Ce - July 2018 And After
Non-Folding Handrails With Removable Upper Control Box - S3215e/S3219e - Ansi - October 2018 And After
Non-Folding Handrails Assembly With Fixed Upper Control Box - S3215e/S3219e - As - December 2018 And After
Non-Folding Handrails With Removable Upper Control Box Asembly - S3215e/S3219e - As - October 2018 And After
Non-Folding Handrails With Removable Upper Control Box Assembly - S3215e/S3219e - As - September 2018 And Before
Non-Folding Handrails Assembly With Foot Latch
Non-Folding Handrails Assembly As With Fixed Upper Control Box - S3215e/S3219e - July 2018 And Before
Non-Folding Handrails Assembly As With Fixed Upper Control Box - S3215e/S3219e - August 2018 And After
Folding Handrails Assembly With Removable Upper Control Box - S3215e/S3219e - Ce - September 2018 And Before
Folding Handrails Removeable Upper Control Box - Ce - July 2019 And After
Removable Top Rail - S3215e/S3215l/S3219e/S3220e/S3226e
Removable Upper Control Box - S3215e/S3219e - As
Control Box Weather Guard Kit
Snorkel Guard Platform Control Box Assembly
Snorkel Guard Upper Control Box Assembly - Ansi
Snorkel Guard Upper Control Box Harness
Snorkel Guard Assembly
Loading Control Kit Folding Rails Built With Out Side Drive - May 2019 And After
Loading Control Kit Fixed Hand Rails Built With Out Side Drive - May 2019 And After
Bumpguard Assembly - S3215e/S3219e - September 2019 And After
Panel Carrier
Step Platform Assembly - 22.5" Wide - Fits: 30"/32"/47" Wide Platforms
Step Platform Assembly - 23.75" Wide
Amber Beacon Installation - Ce - October 2016 And After
Amber Beacon Installation - Ansi - June 2019 And After
Amber Beacon Assembly - Ansi
Amber Beacon Assembly - Ansi/Ce/As - October 2016 And After
Amber Beacon Assembly - June 2017 And After
Amber Beacon Harness
Dual Flashing Light
Dual Flashing Light
Maintenance
Maintenance
Schematics
Two-Speed Hydraulic Schematic - S3215l/S3215e S3219e/S3220e/S3226e/S4726e/S4732e - March 22, 2017 And After
Hydraulic Schematic - S3215e/S3219e/S3220e
Electrical Schematic Without Pendant - Ansi - S3215l/S3215/S3219e/S3220e/S3226e/S4726e/S4732e
Electrical Schematic With Pendant - Ansi - S3215l/S3215e/S3219e/S3220e/S3226e/S4726e/S4732e
Electrical Schematic - S3215l/S3215e/S3219e/S3220e/S3226e/S4726e/S4732e - Ce
Appendix A:pages Index
Appendix B:parts Index
