Snorkel Scissor Lifts S3215L Parts Manual 1502782 2017
Brand: Snorkel
Type of Machine: Scissor Lift
Type of Manual: Parts Manual, Electrical Diagram, Hydraulic Diagram
Model: Snorkel S3215L Scissor Lift
Serial Number: 000000 and after
Part Number: 1502782
Publication Date: 2017
Number of Pages: 503 Pages
Repair Parts
Chassis Assembly - August 2018 And Before
Chassis Assembly - September 2018 And After
Chassis Weldment Bearings
Chassis Stack Assembly - April 2017 And Before
Chassis Stack Assembly - May 2017 And After
Chassis Stack Assembly - August 2019 And After
Chassis Stack Assembly - December 2017 And After
Chassis Stack Assembly - October 2018 And After
Assembly - Ansi
Rear Tray Assembly - Ansi - Sn 3219e-04-002295 And Before
Rear Tray Assembly - Service Use 150198428 For Chassis Harness - Ansi
Rear Tray Assembly - Ansi - S3219e-04-S3219e-04-181006662 And Before
Rear Tray Assembly - Ansi - S3219e-04-181006663 And After
Rear Tray Assembly - Ansi - S3215e/S3215l/S3219e - September 2018 And After
Rear Tray Assembly - Ansi - S3215l/S3215e/S3219e-04-190407733 And After
Rear Tray Assembly - January 2019 And After
Rear Tray Assembly - Ce/As - February 2019 And After
Rear Tray Assembly - April 2019 And After
Valve Tray Assembly Two-Speed - October 2018 And Before
Valve Tray Assembly Two-Speed - December 2019 And After
Valve Tray Assembly Two-Speed - Ansi/Ce - Sn 3219e-04-002296 Through Current
Valve Tray Assembly Wide - October 2020 And After
Assembly - Ce/As
Assembly - Ce/As - September 2019 And Before
Assembly - Ce/As - October 2019 And After
Assembly - S3215e/S3215l/S3219e - Ansi/Csa - January 2020 And After
Assembly - S3215e/S3219e - Ansi 92.20/Csa - June 2020/A92.20 And After
Control Tray Assembly - S3215e/S3219e - As/Ce - October 2016 And After
Control Tray Assembly - S3215l/S3215e/S3219e - Ce - December 2017 And Before And Before
Control Tray Assembly - S3215l/S3215e/S3219e - As/Ce - October 2018 And After
Control Tray Assembly - S3215l/S3215e/S3219e - As/Ce - April 2019 And After
Control Tray Assembly - S3215e/S3219e - Ansi 92.20/Csa - January 2022 And After
Lynch Pin With Lanyard Assembly
Tray Installation - December 2018 And After
Tray Installation - November 2018 And Before
Tank Tray Assembly - S3215e/S3215l/S3219e - December 2017 And Before
Tank Tray Assembly - S3215e/S3215l/S3219e - June 2018 And After
Stack Installation - April 2019 And After
Stack Assembly - February 2016 And After
Stack Assembly - April 2019 And After
Folding Handrails Foot Latch Assembly - S3215e/S3219e - August 2019 And After
Folding Handrail Fixed Upper Control Box Assembly - Csa - September 2019 And After
Non-Folding Handrails Assembly - S3215e/S3215l/S3219e - April 2018 And Before - Ansi
Non-Folding Handrails Assembly - S3215l/S3215e/S3219e - May 2018 And After - Ansi
Handrail Assembly Fixed Upper Control Box - Ansi - April 2018 And Before
Handrails Assembly - May 2017 And After
Handrails Assembly - January 2018 And After
Handrails Assembly - S3215e/S3215l/S3219e - Ce - December 2018 And After
Handrails Assembly - Ce - June 2019 And Before
Handrails Assembly - May 2018 And After
Handrails Assembly - November 2019 And After
Handrail Assembly - Ce - July 2019 And After
Platform Assembly
Single Gate Assembly - S3215e/S3215l/S3219e - Ce - Feburary 2018 And Before
Single Gate Assembly - S3215e/S3219e/S3215l - Ce - March 2018 And After
Single Gate As Assembly - S3215e/S3215l/S3219e - December 2018 And After
Single Swing Gate Assembly - S3215e/S3215l/S3219e - Ce - December 2018 And After
Single Swing Gate Assembly - S3215e/S3219e - As
Saloon Gates Assembly - S3215e/S3215l/S3219e - Ce - November 2018 And Before
Saloon Gates Assembly - S3215e/S3215l/S3219e - Ce - December 2018 And After
Saloon Gates Assembly - S3215e/S3215l/S3219e - Ansi
Saloon Gates Assembly - November 2019 And After
Joystick Controller
Decal Assembly - Ce - September 2019 And Before
Decal Assembly - September 2019 And Before - German
Decal Assembly - Csa - September 2019 And Before
Decal Assembly - September 2019 And Before - French
Decal Assembly - Ce - October 2019 And After
Decal Assembly - Csa - October 2019 And After - French
Decal Assembly - October 2019 And After - German
Decal Assembly - Ansi - May 2020 And Before
Decals Assembly - Ansi 92.20/Csa - June 2020/A92.20 And After
Decal Assembly - As/Ce
Decals Assembly - Ce - French
Decals Assembly - Ansi 92.20/Csa - French
Hydraulics
Scissor Manifold Two-Speed Assembly - Fluid Tech
Manifold Two-Speed - November 2016 And Before
Manifold Two-Speed - December 2016 And After
Pump Unit 24vdc 4.33cc - November 2015 And After
Motor 230cc Dali - S3215/S3219 - After S3219-04-002035
Brake Dali - Sn S3219e-04-002034/S4732e-04-000561 And After
Hose Assembly
Lift Cylinder - September 2017 And After - Hengli
Lift Cylinder - After September 2017 - Rosenboom
Lift Cylinder - August 2017 And Before - Fisher
Steer Cylinder - Rosenboom/Pb
Electrical
Chassis Harness - Ansi - S3219e-04-002296 And After
Chassis Harness - Ansi - S3215e/S3215l/S3219e -March 2019 And Before
Chassis Harness - Ansi/Ce/As - Sn 3215e/S3219e/S3219e-04-190407733 Through Current
Angle Transducer Jumper - January 2019 And After
Tabulated Battery Cables
Lower Control Panel Assemblys - 3215e/S3215l/S3219e - Ansi - April 2016 And - After S4740 Feburary 2020 And After
Lower Control Panel Assembly - Ansi 92.20/Csa/Ce/As
Lower Control Harness
Wiring Box Panel Sub-Assembly - January 2005 And After
Wiring Box Panel - December 2015 And Before
Stack Harness Assembly - July 2018 And Before
Stack Harness
Bumpguard Assembly - S3215e/S3219e - September 2019 And After
Harness - 110v Jumper
Upper Control Box Assembly - Two-Speed - Ansi/Ce
Upper Control Box Harness - August 2016 And After
Upper Control Box Assembly - Two-Speed - Ansi - May 2017 And After
Upper Control Box Assembly - One-Speed - Ansi - June 2017 And Before
Upper Control Box Assembly - One-Speed - Ansi - July 2017 And After
Upper Control Box Assembly - Two-Speed - Ansi - May 2018 And After
Upper Control Box Assembly - Two-Speed - Ce - July 2018 And After
Upper Control Box Assembly - One-Speed - Ce - July 2018 And After
Upper Control Box Assembly With Snorkel Guard - Ce - October 2018 And After
Upper Control Box Assembly One-Speed - Ansi - S3215e/S3215l/S3219e - August 2018 And Before
Upper Control Box Assembly - Two-Speed - Ansi - September 2018 And Before
Upper Control Box Assembly - Two-Speed - Ansi - October 2018 And After
Upper Control Box Connection - Two-Speed - Ce - October 2018 And After
Upper Control Box Connector - Two-Speed - Ansi
Drive Control Pendant
110v Assembly - April 2017 And After
Resistor Array Harness Installation - 336 Ohms
Options
Maintenance Free Battery
Lithium Batteries Installation - 3
Trackunit/Keypad Installation
Trackunit With Keypad
Trackunit Access Connector - S3215l/S3215e/S3219e
Charger Interlock Delete - Ansi
24v Lithium Batteries Installation - 2
Connector Charger Interlock Delete
Locking Battery And Rear Tray
Rear Tray Cover Installation
Plug - Australia/New Zealand
Inverter Assembly
Airline
Handrails Removable Upper Control Box Assembly - Ce - November 2020 And After
Folding Handrails - Fixed Upper Control Box Foot Latch - Ce - S3215e/S3219e - May 2019 And After
Non-Folding Handrails Assembly With Foot Latch
Removable Top Rail - S3215e/S3215l/S3219e/S3220e/S3226e
Control Box Weather Guard Kit
Snorkel Guard Assembly - Non-Removable 6-Pin - Ansi 92.20/Csa
Snorkel Guard - Removable 8-Pin - Ce/As
Snorkel Guard - Removable 8-Pin - Ansi 92.20/Csa
Snorkel Guard Assembly - Non-Removable 6-Pin - Ce/As
Snorkel Guard Platform Control Box Two-Speed Assembly - Ansi - August 2018 And After
Snorkel Guard Upper Control Box Harness
Upper Control Box With Snorkel Guard Assembly - Ce/As
Gravity Gate Assembly - S3215e/S3219e
6h Plug And Socket
Inverter Assembly - S3215l/S3215e/S3219e
Panel Carrier
Panel Carrier
Pipe Rack Narrow
Environmentally Safe Oil - S3215e/S3215l/S3219e
Step Platform Assembly - 22.5" Wide - Fits: 30"/32"/47" Wide Platforms
Step Platform Assembly - 23.75" Wide
Padded Rail Narrow
Amber Beacon Installation - Ce - October 2016 And After
Amber Beacon Installation - Ansi - June 2019 And After
Amber Beacon Assembly - Ansi
Amber Beacon Assembly - Ansi/Ce/As - October 2016 And After
Amber Beacon Harness
Dual Flashing Light
Safety Zone Light
Blue Safety Light Assembly
Red Safety Light Assembly
Schematics
Two-Speed Hydraulic Schematic - S3215l/S3215e S3219e/S3220e/S3226e/S4726e/S4732e - March 22, 2017 And After
Hydraulic Schematic Uses - S3215l/S3215e/S3219e/S3220e/S3226e/S4726e/S4732e
Electrical Schematic Without Pendant - Ansi - S3215l/S3215/S3219e/S3220e/S3226e/S4726e/S4732e
Electrical Schematic - S3215l/S3215e/S3219e/S3220e/S3226e/S4726e/S4732e - Ce
Electrical Schematic With Pendant - Ansi - S3215l/S3215e/S3219e/S3220e/S3226e/S4726e/S4732e
Electrical Schematic Telematics
Appendix A
ages Index
Appendix B
arts Index
Brand: Snorkel
Repair Parts
Assembly - Ansi
Assembly - Ce/As
Platform Assembly
Joystick Controller
Hydraulics
Hose Assembly
Electrical
Stack Harness
Options
Inverter Assembly
Airline
6h Plug And Socket
Panel Carrier
Panel Carrier
Pipe Rack Narrow
Padded Rail Narrow
Dual Flashing Light
Safety Zone Light
Schematics
Appendix A
Appendix B
