Momed80
150
35,046
Snorkel Scissor Lifts S2770RTE S3370RTE S3970RTE Parts Manual 15359-2
Brand: Snorkel
Type of Machine: Scissor Lift
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel S2770RTE S3370RTE S3970RTE Lithium Ion Scissor Lift
Part Number: 15359-2
Number of Pages: 166 Pages
Repair Parts
Chassis Assembly
Wheel Mounting Assembly
Steer Assembly
Swing Arms Assembly
Cabinets Mounting
Hydraulic Cabinet Assembly
Motor Cabinet Assembly
Stabiliser Leg Assembly - Imperial Cylinders
Stabiliser Leg Assembly - Metric Cylinders
Base/Stack/Platform Assembly
Platform Assembly
Platform Rear Handrail Assembly
Emergency Bleed Down - 2770
Emergency Bleed Down - 3970/3370
Scissor Stack Tees
Scissor Stack Assembly - 2770
Scissor Stack Assembly - 3370
Scissor Stack Assembly - 3970
Angle Transducer
Angle Transducer - After May 2024
Plastic Hydraulic Fluid Reservoir Assembly
Aluminium Hydraulic Fluid Reservoir Assembly - No Heater
Aluminium Hydraulic Fluid Reservoir Assembly - With Heater
Placards And Decals
Decal Kit - Ansi - S2770rte
Decal Kit - Ansi - S3370rte
Decal Kit - Ansi - S3970rte
Hydraulics
12570 Drive Motor
12571 Drive Motor W/Brake
Mico Wheel Brakes
Gear Hub Assembly
Main Manifold - No Added Fittings
Main Manifold - With Added Fittings
4wheel Drive Manifold - No Fittings
4wheel Drive Manifold - With Fittings
Auto Stabiliser Manifold - No Fittings
Auto Stabiliser Manifold - With Fittings
Stabilisers Cylinder Assembly - Imperial Cylinders
Stabiliser Cylinder Assembly - Metric Cylinders
Axle Cylinder
Axle Cylinder Assembly
Steer Cylinder
Lower Lift Cylinder
Upper Lift Cylinder Assembly
Hose Tags And Colour Codes
Electrical
Lower Control Box Assembly
Upper Control Box Assembly
Looms List
Gp400 Io Menu
Gp400 Io Allocations
Options
Foam Flotation Tires
240vac Assembly
240vac At Platform
Ac110v Assembly At Platform
Extension Handrails Assembly - No Rollout
Schematics
Motor Control Schematic
Hydraulic Schematic
Wiring Schematics
Appendix A:pages Index
Appendix B:parts Index
