Momed80
150
35,046
Snorkel Scissor Lifts S2770RT to S3970BE Parts Manual 15124-2
Brand: Snorkel
Type of Machine: Scissor Lift
Type of Manual: Parts Manual, Electrical Schematic, Hydraulic Schematic
Model: Snorkel S2770RT S2770BE S3370RT S3370BE S3970RT S3970BE Scissor Lift
Part Number: 15124-2
Number of Pages: 335 Pages
Repair Parts
Sr 70" Be Retrofit Assembly
Wheel Mounting Assembly
Chassis Assembly
Steer Assembly
Swing Arms Assembly
Swing Arms Assembly - After Sn S2770rt-07-200300598/S3370rt-07-200300602/S3970rt-07-200500562
Engine Assembly - Kubota D902
Coupler Assembly
Engine Cabinet Assembly
Engine Cabinet Assembly - After Sn S2770rt-07-200900621/S3370rt-07-200900626/S3970rt-07-200900582
Exhaust Extension
Radiator Guard Assembly - After Sn S2770rt-07-210100631/S3370rt-07-210100647/S3970rt-07-201200583
Hydraulic Cabinet Assembly
Hydraulic Cabinet - After Sn S2770rt-07-200900621/S3370rt-07-200900626 S3970rt-07-200900582
Cabinets Assembly
Stabiliser Leg Assembly - Imperial Cylinders
Stabiliser Leg Assembly - Metric Cylinders
Base/Stack/Platform Assembly
Base/Stack/Platform Assembly - After Sn S3970rt-07-181100510, S3370rt-07-181100524, S2770rt-07-181100530
Platform Assembly
Platform Assembly - After Sn S2270rt-07-181100530/S3370rt-07-181100524/S3970rt-07-181100510
Platform Rear Handrail Assembly
Emergency Bleed Down - 3970/3370
Emergency Bleed Down - 2770
Scissor Stack Assembly - 2770
Scissor Stack Assembly - 3370
Scissor Stack Assembly - 3970
Scissor Stack Tees
Angle Transducers - Before Sn S2770rt-07-200900617 S3370rt-07-200900626 S3970rt-07-200900577
Angle Transducer - After Sn S2770rt-07-200900617 S3370rt-07-200900626 S3970rt-07-200900577
Angle Transducer - After May 2024
Plastic Fuel Tank Assembly - Diesel
Aluminium Fuel Tank Assembly
Plastic Hydraulic Fluid Reservoir Assembly
Steel Fuel Tank Assembly - Diesel
Steel Fuel Tank Assembly - Petrol
Steel Hydraulic Fluid Reservoir - No Heater Assembly
Steel Hydraulic Fluid Reservoir - With Heater Assembly
Aluminium Hydraulic Fluid Reservoir Assembly - No Heater
Aluminium Hydraulic Fluid Reservoir Assembly - With Heater
Decals/Placards - Bi-Energy Machines
Decals/Placards
Decal Kit - Ansi - S2770rt
Decal Kit - Ansi - S3370rt
Decal Kit - Ansi - S3970rt
Decal Kit - S2755be - Ce - Transition - December 2025 And After
Decal Kit - S2755be - Ansi - Transition - December 2025 And After
Decal Kit - S2755rt - Ce - December 2025 And After
Decal Kit - S2755rt - Ansi - December 2025 And After
Decal Kit - S2755be - Ce - December 2025 And After
Decal Kit - S2755be - Ansi - December 2025 And After
Hydraulics
12570 Drive Motor
12571 Drive Motor W/Brake
Mico Wheel Brakes
Gear Hub Assembly
Main Manifold - No Fittings - After Sn S2770rt-07-161200500/S3370rt-07-180300500/S3970rt-180300500
Main Manifold - With Fittings
4wheel Drive Manifold - No Fittings
4wheel Drive Manifold - With Fittings
Auto Stabiliser Manifold - No Fittings
Auto Stabiliser Manifold - With Fittings
Pressure Filter Assembly
Axle Cylinder
Axle Cylinder Assembly - After Sn S2770rt-07-200300598/S3370rt-07-200300602/S3970rt-07-200500562
Steer Cylinder
Upper Lift Cylinder Assembly
Lower Lift Cylinder
Stabilisers Cylinder Assembly - Imperial Cylinders
Stabiliser Cylinder Assembly - Metric Cylinders
Hose Tags And Colour Codes
Electrical
Wg752 Engine Harness - With Woodward Throttle Solenoid
Lower Control Box - Ansi - Diesel
Inverter - 2500w 24v
Inverter Weldment
Inverter Tap Block Plate
Inverter Cover Plate
110 Power To Platform To Inverter Cable
Lower Control Box - As/Nzs/Ce - Diesel
Lower Control Box - Ansi - Petrol/Lpg
Lower Control Box - Ansi/As/Nzs/Ce - Overload Petrol/Lpg
Lower Control Box - Dc - As/Nzs/Ce - Bi-Energy Diesel 24v
24v Dc
24v Dc Cabinet Assembly
24v Dc Battery Box Mounting
Gp400/Io Menus
Gp400/Io Allocations
Loom List
Control Loom
Upper Control Box - Ansi/Nzs/As/Ce - Overload Diesel
Upper Control Box - Ansi/Nzs/As/Ce - Overload Petrol/Lpg
Upper Control Box - Ansi/Nzs/As/Ce - Overload Diesel Reverse Lift
Upper Control Box - Ansi/Nzs/As/Ce - Overload Petrol/Lpg Reverse Lift
Upper Control Box - Ansi/Nzs/As/Ce - Overload - Diesel/24v Reverse Lift
Upper Control Box Cover Assembly
Options
Inverter
Ac110v Platform Assembly
240vac Assembly
240vac At Platform
Inverter
Cabinets Assembly - Lpg
Engine Assembly - Yanmar
Engine Assembly - After Sn S2770rt-07-181100530/S3370rt-07-190100529/S3970rt-07-190100519 - Lpg
Engine Assembly - Before Sn S2770rt-07-181100530/S3370rt-07-190100529/S3970rt-07-190100519 - Lpg
Engine Cabinet Assembly - After Sn S2770rt-07-181100530, S3370rt-07-190100529, S3970rt-190100519 - Lpg
Engine Cabinet Assembly - Lpg
Engine Cabinet Assembly - Yanmar
Engine Cabinet Radiator Guard Assembly - Lpg
Block Heater Upgrade
Extension Handrails Assembly - No Rollout
Swing Gate Installation
Schematics
Wiring Schematic
Hydraulic Schematic
Appendix A:pages Index
Appendix B:parts Index
